برنامج Registry Nerds PC Cleaner برنامج لحل مشاكل Iexplore, system32, DLL32, Kernel32, svchost, lsass اى مشكلة تواجهك فى الجهاز يقوم هذا البرنامج الرائع بحلها ويقوم بتنظيف مكتب التسجيل فهو برنامج رائع لاصلاح الجهاز
متوافق مع Windows 2000/XP/Vista
PC Cleaner is professional Registry Cleaner, Windows 2000/XP/Vista Compatible
If you said yes this means you have seen them enough times so you would remember them. And this means it’s time for registry cleaner! Yes, there is a good chance that your Windows registry needs repair and PC Cleaner from Registry Nerds will help you to make this process a breeze. Get a FREE SCAN TODAY!
Slowdowns, weird error messages, issues connected wiith Iexplore, system32, DLL32, Kernel32, svchost, lsass. All these troubles are often caused by misconfigurations in the Windows registry. Over time they accumulate and clog the registry and slow your PC down. Simple diagnostic can prevent that. Another symptoms of registry problems are frequent “freezes”, programs that you tried to uninstall but are still around and sloggish PC.
Registry Nerds PC Cleaner 2009.09
