Machinery's Handbook
النتائج 1 إلى 10 من 25
    المهندس شبراوى
    المهندس شبراوى غير متواجد حالياً
    كتاب قيم جدا جدا
    وتقريبا لا يوجد شى
    خاص بالهندسه
    مش موجوده فى الكتاب دا
    المهم ناتى لمحتوى الكتاب
    COPYRIGHT
    PREFACE
    ACKNOWLEDGMENTS
    MATHEMATICS
    • NUMBERS, FRACTIONS,AND DECIMALS
    •ALGEBRA AND EQUATIONS
    • GEOMETRY •
    • SOLUTION OF TRIANGLES
    •LOGARITHMS
    • MATRICES
    • ENGINEERING ECONOMICS
    MECHANICS AND STRENGTH OF MATERIALS
    •MECHANICS
    • VELOCITY, ACCELERATION, WORK, AND ENERGY
    •FLYWHEELS
    • STRENGTH OF MATERIALS
    •PROPERTIES OF BODIES
    • BEAMS
    • COLUMNS
    • PLATES, SHELLS, AND CYLINDERS
    •SHAFTS
    • SPRINGS
    • DISC SPRINGS
    • WIRE ROPE, CHAIN, ROPE, AND HOOKS
    PROPERTIES, TREATMENT, AND TESTING OF MATERIALS
    •THE ELEMENTS, HEAT, MASS, AND WEIGHT
    •PROPERTIES OF WOOD, CERAMICS, PLASTICS, METALS, WATER, AND AIR
    •STANDARD STEELS
    • TOOL STEELS
    • HARDENING, TEMPERING, AND ANNEALING
    • NONFERROUS ALLOYS
    • PLASTICS
    DIMENSIONING, GAGING, AND MEASURING
    • DRAFTING PRACTICES
    • ALLOWANCES AND TOLERANCES FOR FITS
    •MEASURING INSTRUMENTS AND INSPECTION METHODS •SURFACE TEXTURE
    TOOLING AND TOOLMAKING
    •CUTTING TOOLS
    • CEMENTED CARBIDES
    •FORMING TOOLS
    • MILLING CUTTERS
    •REAMERS
    •TWIST DRILLS AND COUNTERBORES
    •TAPS AND THREADING DIES
    •STANDARD TAPERS
    • ARBORS, CHUCKS, AND SPINDLES
    •BROACHES AND BROACHING
    •FILES AND BURS
    • TOOL WEAR AND SHARPENING
    •JIGS AND FIXTURES
    MACHINING OPERATIONS
    • CUTTING SPEEDS AND FEEDS
    •SPEED AND FEED TABLES
    •ESTIMATING SPEEDS AND MACHINING POWER
    •MACHINING ECONOMETRICS
    • SCREW MACHINE FEEDS AND SPEEDS
    •CUTTING FLUIDS
    •MACHINING NONFERROUS METALS AND NON- METALLIC MATERIALS
    •GRINDING FEEDS AND SPEEDS
    •GRINDING AND OTHER ABRASIVE PROCESSES
    •KNURLS AND KNURLING
    •MACHINE TOOL ACCURACY
    •NUMERICAL CONTROL
    •NUMERICAL CONTROL PROGRAMMING
    •CAD/CAM
    MANUFACTURING PROCESSES
    •PUNCHES, DIES, AND PRESS WORK
    •ELECTRICAL DISCHARGE MACHINING
    •IRON AND STEEL CASTINGS
    •SOLDERING AND BRAZING
    •WELDING
    •LASERS
    •FINISHING OPERATIONS
    FASTENERS
    •NAILS, SPIKES, AND WOOD SCREWS
    •RIVETS AND RIVETED JOINTS
    • TORQUE AND TENSION IN FASTENERS
    •INCH THREADED FASTENERS
    • METRIC THREADED FASTENERS
    • BRITISH FASTENERS
    • MACHINE SCREWS AND NUTS
    • CAP AND SET SCREWS
    •SELF-THREADING SCREWS
    • T-SLOTS, BOLTS, AND NUTS
    • PINS AND STUDS
    •RETAINING RINGS
    •WING NUTS, WING SCREWS, AND THUMB SCREWS
    THREADS AND THREADING
    •SCREW THREAD SYSTEMS
    •UNIFIED SCREW THREADS
    •METRIC SCREW THREADS
    •ACME SCREW THREADS
    •BUTTRESS THREADS
    • WHITWORTH THREADS
    •PIPE AND HOSE THREADS
    •OTHER THREADS
    •MEASURING SCREW THREADS
    • TAPPING AND THREAD CUTTING
    •THREAD ROLLING
    •THREAD GRINDING
    •THREAD MILLING
    •SIMPLE, COMPOUND, DIFFERENTIAL, AND BLOCK INDEXING
    GEARS, SPLINES, AND CAMS
    •GEARS AND GEARING
    •HYPOID AND BEVEL GEARING
    •WORM GEARING
    •HELICAL GEARING
    •OTHER GEAR TYPES
    •CHECKING GEAR SIZES
    •GEAR MATERIALS
    •SPLINES AND SERRATIONS
    •CAMS AND CAM DESIGN
    MACHINE ELEMENTS
    •PLAIN BEARINGS
    •BALL, ROLLER, AND NEEDLE BEARINGS
    •STANDARD METAL BALLS
    •LUBRICANTS AND LUBRICATION
    •COUPLINGS AND CLUTCHES
    •FRICTION BRAKES
    •KEYS AND KEYSEATS
    •FLEXIBLE BELTS AND SHEAVES
    •TRANSMISSION CHAINS
    •STANDARDS FOR ELECTRIC MOTORS
    •ADHESIVES AND SEALANTS
    •MOTION CONTROL
    •O-RINGS
    •ROLLED STEEL SECTIONS, WIRE, AND SHEET-METAL GAGES •PIPE AND PIPE FITTINGS
    MEASURING UNITS
    •SYMBOLS AND ABBREVIATIONS
    • MEASURING UNITS
    •U.S. SYSTEM AND METRIC SYSTEM CONVERSIONS
    INDEX
    INDEX OF STANDARDS
    INDEX OF INTERACTIVE EQUATIONS
    INDEX OF MATERIALS
    ADDITIONAL INFORMATION FROM THE CD
    •MATHEMATICS CEMENT, CONCRETE, LUTES, ADHESIVES, AND SEALANTS SURFACE TREATMENTS FOR METALS
    •MANUFACTURING
    •SYMBOLS FOR DRAFTING
    •FORGE SHOP EQUIPMENT
    • SILENT OR INVERTED TOOTH CHAIN
    • GEARS AND GEARING
    •MISCELLANEOUS TOPICS
    ناتى الان للتحميل
    اولا
    http://www.4shared.com/file/12683823...h_Edition.html
    ثانيا
    http://www.4shared.com/file/12683519...h_Edition.html
    الحمد لله رب العالمين
    اللهم اغفر لنا ذنوبنا
    واكتب لنا جنات عرض السموات والارض
    اللهم ارزقنا الخير
    اللهم اكفينا بحلالك عن الحرام
    اللهم اتنا فى الدنيا حسنه وفى الاخره حسنه
    اللهم اغفر لنا ولوالدينا ولمن سبقنا بالايمان
    اللهم استرنا فوق الارض وتحت الارض ويوم العرض عليك
    اللهم لا تحملنا ما لاطاقه لنا به
    اللهم نستغفرك بعدد ما كان وما سيكون
    جميل عبد الشهيد
    جميل عبد الشهيد غير متواجد حالياً
    الصورة الرمزية جميل عبد الشهيد
    بارك الله فيك استاذ شبراوي على هذه المجلدات القيمه وجعل هذا العمل في ميزان اعمالك اقدم لك في هذا العيد اطيب الاماني واجمل التبريكات واسال الله ان يتقبل صيامك ويغفر لك ويعيده عليك بالخير والعافيه..والسلام عليكم ورحمة الله وبركاته
    JAMIL A ALSHAHED NAMA
    ابو سرويه
    ابو سرويه غير متواجد حالياً
    سلام من الله عليك وبركاته وكل سنة وانت طيب
    جزيت خيرا واعطيت رضا الوالدين
    كليبات
    كليبات غير متواجد حالياً
    الصورة الرمزية كليبات
    thank you ya boooooooooob
    مريم هاشم
    مريم هاشم غير متواجد حالياً
    Given: 7
    thank you very much I hope more succeful for you
    Ahmed Refaie
    Ahmed Refaie غير متواجد حالياً
    جاري التحميل .... جزاك الله خيرا
    ابو زياد وعمر
    ابو زياد وعمر غير متواجد حالياً
    فيه مشاكل فى تنزيل الكتب دى . ياريت تعديل الرابط وشكرا
    م\محمدسلطان
    م\محمدسلطان غير متواجد حالياً
    الصورة الرمزية م\محمدسلطان
    م/ محمد أحمد عبد الرازق سلطان
    8gates
    8gates غير متواجد حالياً
    الصورة الرمزية 8gates
    thanks
    فيه مشاكل فى تنزيل الكتب ياريت تعديل الرابط وشكرا
    thanks
    دكتور صبرى سعيد
    دكتور صبرى سعيد غير متواجد حالياً
    Received: 805
    جهد مشكور بارك الله لك
    ياريت تحولها لملفات مرفقة و تريحنا من عذاب المواقع اللي بتضيع علينا فرحة العثور على شئ قيم
    منتظرين ياسيدي
