الجزء الرابع ( لا تراجع ولا اسستسلام ) CAST v0.9.11 رأيكم يهمنى جدا
النتائج 1 إلى 5 من 5
    زعيم الاسكندرية
    زعيم الاسكندرية غير متواجد حالياً
    Received: 262
    Given: 266
    السلام عليكم ورحمة الله وبركاته ،،،
    الى المهتمين بالمنشآت المعدنية ( الشبكية )
    اليكم هذه الرائعة المجانية
    استمتعوا باوقاتكم ولا تنسونى من صالح دعائكم
    CAST v0.9.11
    CAST v0.9.11
    info:
    CAST v0.9.11
    Win | English | .rar | 5 mb
    CAST utilizes a single interface for creation or modification of strut-and-tie models, truss analysis, selection of reinforcing steel, and capacity checks of the struts and nodes.
    Graphical User Interface ”
    Define D-Region boundaries graphically
    Define strut-and-tie models graphically and numerically
    Guidelines, grid points, and snap tools for accurate dimensioning
    Toolbars and dialog boxes for defining common elements, such as the imposed loadings, material properties, supports, and bearing plates
    Templates for common truss models
    Standard drawing and editing features, such as cut, copy, paste, delete, undo, redo, move, find, glue, and unglue
    Easy access to member information by mouse right button click
    Display of structural model, including reinforcement positions, labels, and areas, in multiple windows with various zooming and panning options
    Context sensitive online help
    Analysis Types
    Design calculations (evaluation of truss member forces and truss member dimensions)
    Detailed analysis of nodal zones
    Simple truss capacity prediction
    Load-deformation analysis
    Truss Solution
    Truss analysis and stress check at command
    Statically indeterminate trusses
    Truss stability checked with warning messages
    Illustration of member forces and identification of member characteristics for dimensioning
    Pushover analysis per user-defined stress-strain relationships of struts and ties with options to use load-controlled or displacement-controlled
    Multiple Load Cases and/or Strut-and-tie Models
    Organize multiple load cases and/or strut-and-tie models in one database
    Present multiple load cases and/or strut-and-tie models in multiple windows
    Truss Member Dimensioning
    Manual or automatic selection of effective widths of struts
    Single or multiple layers of tie reinforcement
    Checks of bearing plate stresses
    Quick check of the adequacy of strut-and-tie model components through color identification
    Support explicitly ACI Code requirements
    Output Features
    Graphical and tabular output
    Create customized text input echo and/or output files
    Created design summaries including graphics in Microsoft Word Document format
    Create input echo and/or output tables in Microsoft Excel format
    Create graphics printout with print preview
    Export graphics into AutoCAD DXF and Bitmap files
    Create response quantity plots obtained from load-deformation analysis in Microsoft Excel format
    Display response history obtained from load-deformation analysis
    Miscellaneous
    Support SI, US customary, and old metric units interchangeable during the design
    Support user-defined and ASTM Standard Reinforcing Bars (ASTM A615/A615M)
    Unit converter for helping convert physical quantities from one unit to another
    Built-in calculator for editable text boxes
    Customizable windows and toolbars
    screenshots:
    Download Links:
    Cast is free version. If I am wrong, please fix it.
    let us download and enjoy.
    Abo Fares
    Abo Fares غير متواجد حالياً
    Received: 344
    Given: 291
    لا حرمنا الله من مجهودك أيها الزعيم الكريم :)
    جزاك الله خيراً، وكل عام وأنت بألف خير..
    لك تحيــــــــاتي..
    خالد الأزهري
    مسلم
    الصورة الرمزية خالد الأزهري
    Received: 1,068
    Given: 724
    وتقبل الله منا جميعا الصيام والقيام ...
    الصراحة رغم أن خبرتي في الستيل قليلة جدا واطلاعي عليه أقل من الخرسانة لكني متأكد أن هذه البرامج تكفي مصمم المنشئات المعدنية لمدة عشر سنين قادمة...شاملة للمشاريع الكبيرة والدراسات العليا...لأنها تتراوح بحسب وصفها من البرامج ذات الاستخدام المباشر والبرامج ذات الاستخدام المعقد ...والظاهر أن هناك مجلد فرعي ستوضع فيه هذه السلاسل باسم Steel programs
    بمناسبة البرامج عندي نية لبدء موضوع في مقارنة التصميم بالبرامج والتصميم اليدوي وهي مناقشة أتمنى أن تكون مفيدة للمبتدئ والخبير وأنت من المرشحين للمشاركة بصفتكم من مرشحي الانتخابات ...(صدقني ستعطيكم إضافة لسمعتكم الطيبة كداعم للغلابة بالبرامج وربما تتمكن من منافسة أبي الحلول وأنس الانتخابات القادمة )..بس خلي العيد ينتهي...
    كل عام وأنتم بخير...
    ما دعوة أنفع يا صاحبي .... من دعوة الغائب للغائب
    ناشدتك الرحمن يا قارئاً .... أن تسأل الغفران للكاتب
    الحياة الطيبة
    دوره عن الزلازل وبرنامج الايتابس وبرنامج السيف -للمهندس أسامه نواره
    مسافر.....لا تنسونا من الدعاء
    hassananas
    hassananas غير متواجد حالياً
    Received: 224
    Given: 6
    بحلول عيد الفطر المبارك ،،، كل عام و أنتم بخير ،،
    strut & tie model is widley used for concrete structure analysis
    الحاج فوزي البنا
    الحاج فوزي البنا غير متواجد حالياً
    الصورة الرمزية الحاج فوزي البنا
    Received: 38
    جزاكم الله خيرا يازعيم الاسكندرية ووسط وشمال وغرب وجنوب افريقيا والشرق الاوسط وحفيد سبعة الاف سنة حضارة واهرامات الجيزة وانجازات مبارك وتوث عنخ امون ومعابد فيلا والكرنك والاقصر وحتشبسوت
    اطال الله في عمركم على طاعتة
