the heat exchanger
النتائج 1 إلى 2 من 2
    alamal
    alamal غير متواجد حالياً
    the heat exchanger
    نظرا لاهمية المبادلات الحرارية في معظم التطبيقات الكيماوية
    اتمنى ان نفتح مجال للحديث عنها في كل ما يخصها من اهمية وشكل وحسابات ومجالات الاستخدام
    alamal
    تعريف بسيط عن المبادل الحراري
    Heat Exchanger
    Heat exchangers are devices built for efficient heat transfer from one fluid to another and are widely used in engineering processes. Some examples are intercoolers, preheaters, boilers and condensers in power plants. By applying the first law of thermodynamics to a heat exchanger working at steady-state condition, we obtain:
    mi hi=0
    where,
    mi= mass flow of the i-th fluid
    hi= change of specific enthalpy of the i-th fluid
    There are several types of heat exchanger:
    recuperative type, in which fluids exchange heat on either side of a dividing wall
    regenerative type, in which hot and cold fluids occupy the same space containing a matrix of material that works alternatively as a sink or source for heat flow
    evaporative type, such as cooling tower in which a liquid is cooled evaporatively in the same space as coolant.
    The recuperative type of heat exchanger which is the most common in practice may be designed according to one of the following types:
    Parallel-flow
    Counter-flow
    Cross-flow
