شرح مفصل لسيارة خلايا الوقود من شركة شل
النتائج 1 إلى 10 من 14
    حسن الطاهر
    حسن الطاهر غير متواجد حالياً
    How does it work
    Whereas most of the other fuel economy vehicles burn fuel in an ICE (Internal Combustion Engine), PAC-Car II uses a fuel cell to convert hydrogen into electricity to power its electrics motors. The main advantages are greater efficiency, much more silent operation and most importantly, zero emission but pure water as the only by-product
    Aerodynamics
    PAC-Car II is equipped with 3 wheels; the single rear wheel is powered and steered, and the front wheels have a camber angle of -8°.
    This solution allows the reduction of the frontal surface area because the room needed to steer the wheels is not needed. Some experiments on a test bench have shown that this camber angle does not provide too much rolling resistance.
    From then, 5 iterations, combining CFD and windtunnel tests have been performed to reach a Cd close to 0.09. The shape of PAC-Car II is optimized for air flow of up to 15° from the longitudinal axis
    Lightweight Construction
    Reducing weight is a constant preoccupation because it affects the rolling resistance and the torque required for upward gradients.
    Body Shell
    PAC-Car II does not have a chassis as its body is self-supporting. FEM structure computations have allowed us to minimize the amount of material and to choose the best direction for the carbon fibre layers which form the shell of the car
    Endplates
    In collaboration with our industrial partner Tribecraft AG we constructed new, ultralight endplates for the fuel cell stack.
    The 20 membranes of the fuel cell stack of PAC-Car II need to be pressed together with a force of more than three tons. This force needs to be evenly distributed over the whole area of the membranes. In PAC-Car I the stack was held together by long screws and Aluminium plates with a thickness of 30mm.
    The system of the new endplates is based on Tribecraft's D.bow patent. The PAC-Car II endplates use glass fiber belts to press the membranes together. Due to these belts the tension part of the D.bow is not needed anymore and the resulting "C.bow" Aluminium part is stressed only under compression.
    To apply the 1.7 tons on each belt (the belt is just 0.8mm thick and 20mm wide!) a newly invented construction with sledges (pulled together with a screw) has been added on top of the Aluminium bows:
    The new endplates weigh only 0.855 kg which is a weight reduction of 739% from the PAC-Car I endplates!
    Powertrain and Control
    The whole fuel cell system (including control and power electronics) has been designed at the ETH Zurich.
    The fuel cell, a by-product of the PowerPac project, is of the PEM type (Proton Exchange Membrane) and benefits from an embedded auto humidifying area specially designed by PSI. The stack efficiency is exceptional, close to 70%.
    All the fuel cell system auxiliaries have been chosen for their reliability, light weight and energy efficiency
    PAC-Car II fuel cell system layout
    In accordance with the race regulations, some auxiliaries are powered by battery
    Control of the whole system is managed by a microcontroller main board
    The transmission uses a gear pair. Its speed ratio depends on the track and on the target average speed. It can be “open” to reduce the drag torque, for instance when the vehicle is gliding downhill.
    The use of the powertrain is optimized by working backwards from a model based on measured efficiency maps of the fuel cell system and the motors, and on the track topography. The approach used requires simulation tools developed on Matlab Simulink
    Car manufacturing
    The manufacturing of the shell has been entrusted to the best specialist in Switzerland: Esoro. Other metallic or composite material parts have mainly been manufactured at the ETH
    اتمنى ان يعجبكم الموضوع
    واتمنى منكم التفاعل معنا
    ولاتنسونا من دعائكم بان يهدينا الله الى الخير
    حسن الطاهر
    لا اله الا الله محمد رسول الله
    حسن الطاهر
    اتمنى من الجميع اامشاركة بما لديهم من معلومات حول هذا الموضوع ذلك لما له من اهمية بالغة في المستقبل القريب
    فرافيرو56
    فرافيرو56 غير متواجد حالياً
    اكثر من رائع ، بل ممتاز جداً ، بارك الله فيك
    حسن الطاهر
    شكرا على المرور اخي الكريم
    حسن الطاهر
    كل عام والجميع بخير و
    رعد الحجاج
    رعد الحجاج غير متواجد حالياً
    مشكور احسنت وبارك الله فيك اخي الكريم نتمنى منك المزيد
    حسن الطاهر
    عفوا لكل المهندسين ولكي ادع الموضوع اكتر تشويقا
    هناك خطأ موجود في الشكل الذي يوضح PAC-Car II fuel cell system layout
    من يتمكن من معرفة هذا الخطأ بالتاكيد هو مهندس ميكانيكي ويمتلك فهم كامل لسيارات خلايا الوقود
    اتمنى منكم التفاعل مع الموضوع
    حسن الطاهر
    الحل موجود في هذا الكتاب
    http://www.4shared.com/file/132537975/60ce2884/625516.html
    البورتسوداني
    البورتسوداني غير متواجد حالياً
    ما شاء الله مجهود مقدر
    و كل عام و انتم بخير
