مهندس كيمياوي عنده سؤال للاخوة البحريين
النتائج 1 إلى 10 من 11
    حيدر الملاح
    حيدر الملاح غير متواجد حالياً
    اخواني الاعزاء قبل فتره سألتكم عن Surging Engine والحمد لله محدش جاوبني وارجو لا تكسفوني المرة دي في عندنا محطة كهرباء متكونه من محركات ديزل MAN B&W 18V/60/48Bالمشكله اللي تتكرر دائما عندنا هي يحصل كراك Crack في المضخة injection pump الوقود المستخدم هو الوقود الثقيل HFO ممكن حد يعرف السبب
    مع جزيل الشكر والامتنان
    حيدر الملاح
    رد واحد ولو يامعلمين..................
    Egy Mine
    Egy Mine غير متواجد حالياً
    الصورة الرمزية Egy Mine
    Have No Idea
    Eng-Maher
    Eng-Maher غير متواجد حالياً
    مشرف قسم الهندسة البحرية.
    الصورة الرمزية Eng-Maher
    Received: 103
    Given: 408
    Lightbulb
    Symptom: The engine surges or misfires while moving.
    The engine seems to start fine and will normally accelerate fine. As you are driving and maintaining a steady speed, the engine seems to "speed up" slightly or it seems to miss and buck.
    Possible causes:
    1. If you have a carburetor (there are still a few out there), the choke may not be set properly, or the choke may not be working correctly.
      The fix: Check the choke plate and make sure it is opening completely.
    2. The engine may be running too hot.
      The fix: Check and repair cooling system.
    3. The fuel pressure regulator may be operating at low pressure.
      The fix: Check fuel pressure with a fuel pressure gauge. Replace fuel pressure regulator. (Generally not a DIY job)
    4. The ignition timing may be set wrong.
      The fix: Adjust ignition timing.
    5. Ignition system problem.
      The fix: Check and replace distributor cap, rotor, ignition wires and spark plugs.
    6. There may be a fault in the computerized engine control system: Check engine control systems with a scan tool. Test circuits and repair or replace components as required. (Generally not a DIY job)
    7. The fuel filter may be partially clogged.
    8. Torque converter (automatic transmission only) may not be locking at the right time, or it may be slipping.
      The fix: Check lock up circuit or replace torque converter. (Not a DIY job)
    9. There may be a vacuum leak.
      The fix: Check and replace vacuum lines as required.
    10. Possible internal engine problems.
      The fix: Check compression to determine engine condition.
    11. EGR valve may be stuck open.
      The fix: Replace EGR valve.
    12. Drive axles may be loose or worn.
      The fix: Check and replace CV/universal joints as required.
    13. The fuel injectors may be dirty.
      The fix: Clean or replace fuel injectors.
    ولمزيد من التفاصيل اليك هذا الموقع ومرحبا بيك اخى الكريم
    الحمد لله
    Fawaz.merey
    Fawaz.merey غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة حيدر الملاح مشاهدة المشاركة
    اخواني الاعزاء قبل فتره سألتكم عن surging engine والحمد لله محدش جاوبني وارجو لا تكسفوني المرة دي في عندنا محطة كهرباء متكونه من محركات ديزل man b&w 18v/60/48bالمشكله اللي تتكرر دائما عندنا هي يحصل كراك crack في المضخة injection pump الوقود المستخدم هو الوقود الثقيل hfo ممكن حد يعرف السبب
    غالبا من الوقود لأنو حصلت معانا مرة و كان السبب الوقود. نسبة الشوائب"فانديوم , صوديوم" عالية
    Alakkawi
    Alakkawi غير متواجد حالياً
    الأخ الكريم،
    انا كبير مهندسين بحريين، و بالنسبة للمشكلة، ارجو التوضيح اكثر لمعرفة المشكلة، و لكن هناك تفسيرين للمشكلة:
    - الأول: صيانة خاطئة لمضخات حقن الوقود و عدم اتباع تعليمات الصانع و استخدام قطع غيار غير اصلية.
    الثاني: المشكلة تتعلق بالوقود المشتخدم، ينبغي اخذ عينة من الوقود و ارساله للمختبر و تحليله و من ثم اتباع تعليمات المخبر فيما يتعلق بتنقية الوقود و درجة الحرارة المثلى للتسخين و الحقن، على الأغلب هناك تسخين خاطئ للوقود، يؤدي لحدوث تكهف عند المضخات و تأكلها.
    حيدر الملاح
    اقتباس المشاركة الأصلية كتبت بواسطة Alakkawi مشاهدة المشاركة
    الأخ الكريم،
    شكرا جزيلا على الرد
    تبين ان المشكله هي تكهف كما ذكرت والسبب هو وجود بافل سكرو Baffle screw والذي يتاكل مع الوقت لكي يسيطر على الوقود الراجع حيث اذا تزايد الوقود الراجع سبب التكهف Cavitation لذلك فان المصنع يوصي بتبديلها كل 3000 ساعة عمل والان والحمد لله تجاوزنا هذا المشكله وحتى الشركه المصنعة غيرت تصميم المضخة والبافل سكرو ليتحمل الجريان ولن يبدل الا مع تبديل المضخة بحدود 30000 ساعة عمل
    كيرو عبده
    كيرو عبده غير متواجد حالياً
    تم إيقافه لمخالفة القوانين
    الصورة الرمزية كيرو عبده
    Received: 19
    Given: 5
    تسلم يا غالى
    mostaafyeg
    mostaafyeg غير متواجد حالياً
    برجاء توضيح نسبة تحميل كل مولد الى الحمل الكلى
    مصطفى عبدالغفار
    نبيل عواد الغباري
    نبيل عواد الغباري غير متواجد حالياً
    مشرف الهندسة الكيميائية
    Received: 63
    من اسباب انكسار قاعدة مضخة الوقود على المحركات هو عدم وجود رنديلة زمبركية على البراغي المثبتة لها ولذلك ينصح بتركيبها لمنع البراغي من الارتخاء وبالتالي انكسار القاعدة او حصول تشققات بها .
    ربي اني ظلمت نفسي فاغفر لي
