بعد فشلى الذريع فى الحملة الانتخابية اهديكم احدى الروائع AutoPADDS Extension for Auto
النتائج 1 إلى 10 من 17
    زعيم الاسكندرية
    زعيم الاسكندرية غير متواجد حالياً
    Received: 262
    Given: 266
    ايها الأحباب
    السلام عليكم ورحمة الله وبركاته ،،
    كل عام وانتم بخير
    بعد فشلى الذريع فى الحملة الانتخابية ضد ابو الحلول وانس - قررت التنازل عن خوض الانتخابات
    ولكن قبل التنازل احببت ان اهديكم هذا البرنامج المتبقى معى من حملتى الانتخابية
    خذوه هدية لكم ولا تنسونى من صالح دعائكم
    AutoPADDS Extension for AutoCAD
    info:
    AutoPadds
    AutoPadds is an extension for AutoCAD® with reinforcement detailing functionality similar to that of
    Padds. AutoPadds complements and extends the reinforcement functionality of Revit®.
    With AutoPadds, you can detail reinforcement directly in AutoCAD®. You can open Padds drawings and work
    with bending schedules generated by the PROKON ®concrete design modules. You can also link
    reinforcement layouts created with AutoPadds into your Revit ® model.
    AutoPadds Bending Schedule PaletteReinforcement Shape Codes
    With AutoPadds, you can create your own libraries of reinforcement shape codes. Shape codes for the
    following codes of practice are included by default:
    * BS 4466 - 1989
    * BS 8666 - 2005
    * SANS 282 - 2004
    Rebar Properties Palette
    AutoPadds has a properties palette for rebar objects (similar to other AutoCad® object such as lines
    and circles) for easy editing of rebar properties such as diameter, shape code and dimensions. And like
    other objects, rebar objects can be filtered out of a multiple object selection by selecting type
    “Rebar” from the type dropdown at the top of the properties palette.
    Schedule Palette
    AutoPadds has a scheduling calculator is contained in a AutoCAD ® docking palette, making it easy to
    access. The palette's purpose is to read all the rebar objects in the drawing, help you sort the
    information, and output it in tables on the AutoCAD® drawing.
    screenshots:
    Download Links:
    Code:
    http://www.4shared.com/file/13136493...ds_081108.html
    أحمد عصام الدين
    أحمد عصام الدين غير متواجد حالياً
    الصورة الرمزية أحمد عصام الدين
    Received: 17
    مشكور يا زعيم وميهمكش سواء فزت او فشلت وراك وراك يا زعيم
    بالروح بالدم نفديك يا زعيم
    Abo Fares
    Abo Fares غير متواجد حالياً
    Received: 344
    Given: 291
    لك على راسي عمنا الزعيم :) ......... جزاك الله كل خير.....
    جاري التحميل للاطلاع، وسيتم سؤالك للاستعانة بمعرفتك بالبرنامج حتى نتمكن من التأكد من قوة الحملة الانتخابية :d
    سنا الإسلام
    سنا الإسلام غير متواجد حالياً
    Received: 257
    جزاكم الله خيرا وبارك الله فيك
    وجارى التحميل بإذن الله
    متغيبة عن الملتقى
    علي رياض التميمي
    علي رياض التميمي غير متواجد حالياً
    الصورة الرمزية علي رياض التميمي
    Received: 22
    زعيم الاسكندرية اعرض عليك مقترح بأن امول لك حملتك الانتخابية السنة المقبلة اذا جاوبت على سؤال ابو الحلول\\\\ابو الحلول سؤال صعب ما اوصيك بعد
    اقدم لكم موقعي على الانترنت وهو موقع هندسي شامل
    http://engaliriyadh.weebly.com/
    زنوبيا 11
    زنوبيا 11 غير متواجد حالياً
    الصورة الرمزية زنوبيا 11
    Received: 124
    Given: 131
    السلام عليكم زعيمنا الكبير
    ما شاء الله عليك لو خسرت الانتخابات بس روحك رياضية ولساتك عم تقدم هدايا للناخبين
    وبعدين الأخوة أبو الحلول وأنس و م.أبو بكر عندون كتير معجبين
    بارك الله فيك أخي عالبرنامج الاين إنو مهم
    بس ممكن أعرف شو بيفيد؟؟؟ وممكن أستفاد منه حاليا لأني أنا والتكنولوجيا مو صحاب كتير
    *الله لا إله إلا أنت سبحانك إني كنت من الظالمين*
    *اللهم لا سهل إلا ما جعلته سهلا ، وأنت إن شئت تجعل الحزن سهلا*
    *أستغفر الله العظيم وأتوب إليه*
    **أشهد ألا إله إلا الله وحده لا شريك له وأن محمدا عبده ورسوله**
    تامر عبدالعظيم
    تامر عبدالعظيم غير متواجد حالياً
    الصورة الرمزية تامر عبدالعظيم
    Received: 8
    جامد وبكرة تنولها
    بس اوعى تطبق الديموقراطية
    HCIVILENG
    HCIVILENG غير متواجد حالياً
    برنامج جميل ومفيد جدا... بانتظار بعض الشرح..
    زعيم الاسكندرية
    Received: 262
    Given: 266
    على الرغم من ان الناخبين لم يعطونى اصواتهم الا انى لن ابخل عليهم بذكر فائدة البرنامج
    البرنامج يعمل تحت الاوتوكاد من اصدار 2007 وحتى 2010 وهو مفيد جدا لرسم تفاصيل التسلح ويعمل بصورة متكاملة مع برنامج بروكون
    انا لم اجرب البرنامج حتى الان لضيق الوقت ولكنه فيما يبدو مفيد جدا جدا
    نصيحة تجنبوا استخدام الاصدرارت الفردية من الاوتوكاد
    ebdaa4eim
    ebdaa4eim غير متواجد حالياً
    شكرا على برنامج انتظرة من مدة ولكن هل يحتاج اكراك!
