هدية عظيمة لمنتدنا الكريم : Earthquake Engineering: Application to Design
النتائج 1 إلى 10 من 15
    الصورة الرمزية مهندس/أيمن قنديل
    مهندس/أيمن قنديل
    مهندس/أيمن قنديل غير متواجد حالياً
    Received: 129
    Given: 26
    Charles K. Erdey: Earthquake Engineering: Application to Design
    Posted By : iBook | Date : 21 Feb 2009 2100 | Comments : 1
    Wiley | ISBN: 0470048433 | 2007-01-09 | PDF | 448 pages | 2.6 Mb
    Learn to design code-compliant, earthquake-resistant structures with this practical guide
    Earthquake Engineering demonstrates how to design structural members and joints for seismic resistance. The text guides readers through dozens of structural designs, documenting how to perform each step, make the necessary calculations, and adhere to relevant design codes. Most other texts on seismic design focus on theory and the construction of idealized structures; this text is a radical departure, presenting actual tested design methodologies that protect structures from the devastation of earthquakes.
    All the design methods presented by the author comply with the current U.S. building codes. References to these codes are provided throughout the text, helping readers understand how they are integrated into an overall structural design.
    Everything readers need to create sound designs, from analysis to design implementation, is provided, including:
    * Dozens of worked problems throughout the text
    * Complete reference chapters dedicated to matrices, differential equations, and numerical analysis
    * Latest results of ongoing seismic research, including how these studies are likely to influence future design projects
    * The latest 2006 IBC, highlighting significant variations from the 2000 and 2003 editions of the code
    * Detailed coverage of seismic design for steel moment-resisting frame structures (SMRF), as well as braced-frame steel, concrete, masonry, and wood-framed structures
    This text, with its many worked problems, is ideal for upper-level undergraduates and graduate students. Now that the seismic engineering provisions of the IBC Code apply to the entire United States, this text should also guide practicing engineers not yet exposed to seismic design in designing code-compliant, earthquake-resistant structures.
    http://rapidshare.com/files/234023940/Earthquake_Engineering_-_Application_to_Design.pdf
    (منقول)
    سنا الإسلام
    سنا الإسلام غير متواجد حالياً
    Received: 257
    جزاكم الله خيرا وبارك الله فيك
    وجارى التحميل
    متغيبة عن الملتقى
    أحمد عصام الدين
    أحمد عصام الدين غير متواجد حالياً
    الصورة الرمزية أحمد عصام الدين
    Received: 17
    مشكور م ايمن جعله الله في ميزان حسناتك ان شاء الله
    نبيه زهوة
    نبيه زهوة غير متواجد حالياً
    جزاك الله خيرا ولكن الرابط لا يعمل ... أرجو منك استخدام موقع آخر
    ولك جزيل الشكر
    بسام محمد منصور
    بسام محمد منصور غير متواجد حالياً
    السلام عليكم مشكوووووووووووووووووور علي المجهود العظيم
    بسام محمد منصور
    الرابط لا يعمل في الامارات ممكن رابط اخر
    brahim_
    brahim_ غير متواجد حالياً
    وجارى التحميل
    محمودشمس
    محمودشمس غير متواجد حالياً
    عضو متميز جداً
    Received: 14
    جزاك الله خير جاري التحميل
    م.طاهر
    م.طاهر غير متواجد حالياً
    الصورة الرمزية م.طاهر
    Received: 11
    Given: 64
    ماشاء الله ايه الحلاوه دي
    engibrahim
    engibrahim غير متواجد حالياً
    جزاكم الله خير على هذا المجهود
