هدية العشر الأواخر مقدما
النتائج 1 إلى 10 من 12
    زعيم الاسكندرية
    زعيم الاسكندرية غير متواجد حالياً
    Received: 262
    Given: 264
    ايها الأحباب من كافة الطبقات ( الكادحين والبرجوازيين و البلوريتاريا والمعذبون فى الأرض وعامة الشعب )
    ايها الصائمون
    السلام عليكم ورحمة الله وبركاته ،،
    هدية العشر الأواخر من رمضان مقدما
    هدية ولا كل الهدايا السابقة
    عسى الله ان ينفعكم به ولا تنسونى من صالح دعائكم
    RISA-3D v8.1.0
    RISA-3D v8.1.0
    The new triangle is getting closer!
    Info:
    RISA-3D is so popular among structural engineers for many reasons but one in particular stands out: ease of use. We designed our premier product with the daily use of structural engineering professionals in mind.
    User friendliness combined with advanced analysis capabilities make this industry standard software a very powerful tool for the analysis and optimization of all types of structures and all common structural materials, including steel, concrete and wood. It's a tool no structural engineer should be without!
    Analysis Features
    •Accelerated true sparse solver for static analysis
    •Flexible modeling of P-Delta effects
    •Accelerated Sparse Lanzcos dynamics solver, very fast and robust
    •Multiple simultaneous dynamic and response spectra analysis using Gupta, CQC or SRSS with automatic calc of scaling factors
    •Automatic inclusion of mass offset (5% or user defined) for dynamics
    •Automatic generation of wind and seismic forces (IBC 2000/2003/2006)
    •True physical member modeling (members are aware of interior joints)
    •State-of-the-art plate/shell elements with plane stress only option
    •State-of-the-art 8 node solid elements with automatic meshing
    •High end mesh generation — draw a polygon with any number of sides to create a mesh of well formed quadrilateral (NO triangular) elements.
    •Accurate analysis of tapered wide flanges
    •Automatic rigid diaphragm modeling with detachable joints
    •Area loads with one-way or two-way distributions with optional “blow through” distribution for loading open structures
    •Plate thermal loads
    •Simultaneous moving loads, AASHTO/custom for bridges, cranes…
    •Torsional warping calculations for stiffness, stress and design
    •Member end releases, rigid end offsets, top of member offsets
    •Joint master-slave assignments
    •Enforced joint displacements
    •One Way members, for tension only bracing, slipping, etc.
    •One Way springs, for modeling soils and other effects
    •Euler members: Compression up to buckling load, then turn off
    •Stress calculations on any arbitrary shape
    •Inactivate members, plates, solids and diaphragms without deleting them
    •Story drift calculations provide relative drift and ratio to height
    •Automatic self-weight calculations for members, plates and solids
    Design Features
    •Designs/optimizes concrete, hot rolled & cold formed steel, masonry and wood
    •Concrete Design Codes: ACI 1999/2002/2005, BS 8110-97, CSA A23.3-94, IS456:2000,EC 2-1992, NZS3101-1995, AS 3600-2001, NTC-DF2004
    •Maintains consistent bar sizes through adjacent spans
    •Program selected or user defined rebar layouts for flexure and shear
    •Concrete beam detailing (Rectangular, T and L).
    •Concrete column interaction diagrams.
    •Masonry Design Codes: MSJC 1999/2002/05, UBC 97 (ASD & Strength)
    •Masonry wall design for in-plane, out-of-plane & bearing loads (with or without openings)
    •Steel Design Codes: AISC ASD 9th, LRFD 2nd & 3rd, HSS Specification, CAN/CSA-S16.1-1994 & 2004, BS 5950-1-2000, IS 800-1984, Euro 3-1993, NZS 3404-1:1997, AS 4100-1998 including local shape databases.
    •AISC 13th Edition using the Direct Analysis Method.
    •AISI 1999/2001, CSA S136-01 cold formed steel design
    •NDS 91/97/2001/2005 wood design, Glulams, SCL, multi-ply, full sawn
    •Automatic spectra generation for UBC 1997, IBC 2000/2003/2006
    •Extensive user controlled generation of load combinations: ASCE, UBC, IBC, BOCA, SBC, ACI, International
    •Intelligent unbraced length calculations for physical members
    •Automatic approximation of K factors
    •Tapered wide flange design with either ASD or LRFD codes
    •Optimization of member sizes for all materials and all design codes
    •Steel Shapes: AISC, HSS, CAN, ARBED & numerous foreign databases
    •Light Gage Shapes: AISI, SSMA, Dale/Incor, Dietrich, Marino\WARE
    •Wood Shapes: Complete NDS species/grade and Glulam database
    •Complete wood wall design for bearing & shear walls
    •Seamless integration with RISAFoot (Ver 4) for advanced footing design
    What’s New
    •Wood shear wall design using all three approved design methods: Segmented, Perforated and Force Transfer Around Openings
    •Automatic generation of wind and seismic loads per NBCC (Canada)
    •EC3 2005 Euro steel code
    •BSEN 2004 Euro concrete code
    Screenshots:
    Download setup + medicine:
    You should skip checking for update while installation.
    Code:
    http://www.4shared.com/file/13013845...v810part1.html
    http://www.4shared.com/file/13013462...v810part2.html
    Password:
    Code:
    CivilEA
    سنا الإسلام
    سنا الإسلام غير متواجد حالياً
    Received: 257
    جزاكم الله خيرا وبارك الله فك
    متغيبة عن الملتقى
    سنا الإسلام
    Received: 257
    جزاكم الله خيرا وبارك الله فيك
    متغيبة عن الملتقى
    mohy_y2003
    mohy_y2003 غير متواجد حالياً
    الصورة الرمزية mohy_y2003
    Received: 350
    Given: 439
    مشكور يا زعيمنا علي هذه الهديه القيمه - بس الهديه دي ممكن تضيع العشر الاواخر مننا لو سطبنا البرنامج وعيشنا معاه كنت خليتها هدية العيد احسن ه
    لكن علي كل حال الهديه رائعه وجميله وربنا ينفعنا بيها ان شاء الله وجزاك الله خيراً
    الإمام محمد الغزالي
    hassananas
    hassananas غير متواجد حالياً
    Received: 224
    Given: 6
    الهديه رائعه وجميله وربنا ينفعنا بيها ان شاء الله وجزاك الله خيراً وبارك الله فيك
    محمد 977
    محمد 977 غير متواجد حالياً
    جزاك الله خيراً و وفقك لرضاه و رزقك الصبر
    مشكووووووووور
    تسلم ايدك و الف الف الف شكر
    البرنامج هام و واتمنى من زعيم الاسكندرية ان يتحفنا بروابط لشروحات و امثلة عن البرنامج لانه قليل الانتشار نسبياً
    Abo Fares
    Abo Fares غير متواجد حالياً
    Received: 344
    Given: 291
    Thumbs up
    ما شاء الله عليك يا زعيمنا....... مواضيع رائعة جداً، الله يعطيك ألف عافية...
    أكيد ما عم تنسوا التقييم يا جماعة، مو؟؟
    لك خالص التحيـــــات.. وننتظر هدية العيد :D
    زعيم الاسكندرية
    Received: 262
    Given: 264
    مشكور على المجاملة أخى محى وان شاء الله ستكون هناك هدية حلوة فى العيد
    كل عام وانتم بخير وصحة وعافية وستر
    زعيم الاسكندرية
    Received: 262
    Given: 264
    لك خالص التحيـــــات.. وننتظر هدية العيد :d
    عمنا ابو الحلول صاحب المجاملات الرقيقة
    السلام عليكم ورحمة الله وبركاته ،،،
    كل عام وانت بخير وصحة وعافية وسعة رزق
    دائما بترفع من روحنا المعنوية وان شاء الله ستكون هدية العيد حلوة باذن الله
    اشكرك انت واخوانى وزملائي اينما كنتم
    زعيم الاسكندرية
    Received: 262
    Given: 264
    اقتباس المشاركة الأصلية كتبت بواسطة محمد 977 مشاهدة المشاركة
    مشكووووووووور
    اخى المشاكس محمد 977
    ارجو ان لا يكون فى نفسك شيئا تجاهى حيث انتقدت طريقتك فى المشاركات
    فنحن فى بداية العشر الأواخر وارجو ان تسامحنى
    حقيقة لا يتوافر لدى الحين روابط لشرح البرنامج وعندما تتوفر فلن ابخل بها على اخوانى واحبائى
    وكل عام وانتم بخير
