طريقة تصنيع Dettol علمياً "كما تصنعه الشركة الأم"
النتائج 1 إلى 10 من 40
    الصورة الرمزية نعمة الإسلام
    نعمة الإسلام
    نعمة الإسلام غير متواجد حالياً
    السادة إخوانى الأعزاء ...
    أقدم لكم اليوم أول مساهماتى بالمنتدى وهى عبارة عن الطريقة العلمية الصحيحة المؤيدة بالمستندات لتصنيع منتج Dettol كما تصنعه الشركة الأم وهى شركة إنجليزية إسمها Reckitt Benckiser
    ... وأرجو الإستفادة للجميع
    [CENTER]INTRODUCTION TO DETTOL CONCEPT
    Dettol (also called parachlorometaxylenol, or PCMX) is the name of a commercial
    liquid antiseptic belonging to a product line of household products manufactured by
    Reckitt Benckiser and marketed in South Asia, Africa & Middle East, Asia Pacific,
    Europe, Australasia.
    Chemical structure of chloroxylenol
    the key ingredient which defines its unique antiseptic property is an aromatic chemical
    compound in chemistry known as chloroxylenol (C8H9ClO). This makes up 4.8% of
    Dettol's total mixture, with the rest composed of pine oil, isopropanol, castor oil soap,
    caramel, and water. Because several of the ingredients are insoluble in water, Dettol
    produces a white emulsion of oil droplets when diluted during use. It has a characterisitic
    phenolic odour similar to trichlorophenol and the explosive compound known as
    trinitrotoluene (TNT). Apart from its low toxicity and low metal corrosivity, it is also
    relatively cheap compared to other disinfectants and is effective against gram positive
    and gram negative bacteria, fungi, yeast, mildew and even the frightening "super-bug"
    MRSA, thus giving it a broad spectrum of antimicrobial action. It is able to kill 98% of
    microbes in just 15 seconds as shown in agar patch studies, by disrupting the bacterial
    cells' membrane potential, drastically affecting its ability to produce Adenosine
    triphosphate and thus leading to its rapid death.
    Dettol can also be used to treat acne in small quantities. The bottle cap also doubles as a
    container for pouring increments of 10ml for its various uses. However, like other
    household cleaners, it is still poisonous and should not be ingested. In an extreme case, a
    42 year old English man died from Dettol overexposure in May 2007. [1] Overuse of
    Dettol can also cause bacterial resistance, but the risk of infection can be reduced
    considerably by using it in addition to soap and water.
    An indicative formula for BIOCROL PCMX :
    Biocrol PCMX 2%
    Pine oil 4%
    Castor oil soap (30%) 12% (Castor oil +caustic soda+ water)
    Deionized water 82%
    Clarification
    • CASTOR OIL SOAP : Add water to saponify(*)( convert oil into soap ) the
    castor oil with caustic soda till it reaches a concentration of 30%.
    • When facing difficulties in dissolving Biocrol PCMX then it is suggested to
    dissolve it in IPA 95%(isopropyl alcohol ) and add it to Pine Oil then mix it with
    the already prepared Castor Oil soap 30% and add the rest of the Deionized
    water(**).
    (*)Saponification : A reaction in which an ester is heated with an alkali, such as sodium
    hydroxide, producing a free alcohol and an acid salt, especially alkaline hydrolysis of a fat or oil
    to make soap.
    (**)Deionized water (DI water or de-ionized water; also spelled deionised water is water that
    lacks ions, such as cations from sodium, calcium, iron, copper and anions such as chloride and
    bromide. This means it has been purified from all other ions except H3O+ and OH−, but it may
    still contain other non-ionic types of impurities such as organic compounds. This type of water is
    produced using an ion exchange process. Deionized water is similar to distilled water, in that it is
    useful for scientific experiments where the presence of impurities may be undesirable/CENTER]
    مالك محسن مختار
    مالك محسن مختار غير متواجد حالياً
    مجهود طيب منك اخى الكريم
    بس منين الخامات اكرمك الله
    اللهم ان اعوذ بك من زوااال نعمتك. يا مقلب القلوب ثبت قلبى على دينك
    كيميائى /محسن مختار
    skhr
    skhr غير متواجد حالياً
    الصورة الرمزية skhr
    ألف شكر على المشاركة القيمة مع كامل أحترامي وتقديري ولكن أرجو أن تتكرم علينا بالترجمة وجزاك الله الخير
    skhr
    نعمة الإسلام
    الأخوة الأفاضل :
    الخامات الداخلة فى التركيبة كالتالى :
    ** كلوروزيلنول PCMX : وتعتبر هى المادة الفعالة الأساسية فى المنتج. Chloroxylenol
    ** باين أويل : وتعتبر المادة التى تعطى الرائحة النفاذة التى تشتم فى غالبية المطهرات.
    ** أيزوبروبانول : ويعتبر وسط مسئول عن تمام إذابة المواد الأخرى. Isopropanol Aِِِِlcohol
    ** زيت خروع : الدهن الأساسى اللازم لعملية التصبن. Castor oil
    ** صودا كاوية سائلة : العنصر القلوى الأخر اللازم لتمام عملية التصبن. Caustic soda 48%
    ** سائل الكراميل : هو المسئول عن أعطاء المنتج لونه المعروف. " ويمكن عمله ببساطة بوضع كمية من السكر العادى وإذابتها فى نسبة قليلة جداً من الماء مع التقليب والتسخين وإضافة القليل جداً من الماء كلما غلى هذا المحلول.
    ** ماء مقطر : مطلوب لجودة المنتج، ولخلوه أيضاً من الأملاح الزائدة التى توجد فى ماء الصنبور العادى التى قد تتفاعل مع المكونات الأخرى .. وحتى يخلو المنتج من الشوائب.
    عمومـــاً،، الخامات كلها - فيما عدا الماء والكراميل طبعاً - تباع لدى نيرول للكيماويات - باب الشعرية - ش الجيش.
    بالنسبة لطريقة التصنيع : فهى تتم على ثلاث مراحل بسيطة :-
    الأولى : هى عملية التصبن ( زيت الخروع / ماء / الصودا الكاوية ).
    الثانية : هى إذابة الكلوروزيلنول فى أيزوبروبانول الكحول ثم إضافة الباين أويل إلى هذا الخليط ثم باقى كمية الماء.
    الثالثة : إضافة ناتج المرحلة الثانية إلى السائل الناتج عن مرحلة التصبن.
    أرجو المعذرة ... فإننى ولتمام التاكد سأوافيكم بالكميات بالضبط لاحقاً إن شاء اللــه ، وذلك حتى تعم الفائدة إن شاء اللــه.
    1 Not allowed!
    mohammadelrayees
    mohammadelrayees غير متواجد حالياً
    Received: 14
    عفوا اخي نعمة الاسلام بالنسبة لنيرول هو محل كويس لكن زيت الصنوبر الموجود عندة مش كويس وبيعكر لانة مش عصرةاولى او قطفة اولى
    وحضرتك يا اخ نعمة الاسلام لم تقم بتركيب المنتج بدليل انك مش عارف المقادير
    نعمة الإسلام
    أخى الكريم : محـــمد
    من واقع الأمانة العلمية والأخلاقية فى نشر المعلومات فإننى لايمكننى كتابة ولو سطر واح لست متأكد من دقته، ولذلك فإننى أرجو المعذرة من جميع إخوانى للتأخير فى الرد لبعض الوقت حتى يتسنى لى البحث فى أوراقى القيمة ... حيث أننى قمت بعمل هذا المنتج منذ أكثر من سنتين ولم أعد أنتجه.
    مرة أخرى ... أرجو المعذرة
    معلومة هامة جداً: عملية التصبن لا يكمن أن تتم بدون التسخين.
    1 Not allowed!
    البلاتين
    البلاتين غير متواجد حالياً
    Received: 12
    كم هي حرارة التسخين اللازمة للتصبين ؟
    الطريقة غير واضحة المعالم في نسبها ..
    نرجو التكرم بالافادة ..لتعم الفائدة
    وشكرا للجميع ..
    mohammadelrayees
    Received: 14
    الطريقة موضحة
    http://www.arab-eng.org/vb/t152956.html
    مالك محسن مختار
    مشكور اخى الكريم
    بس ياريت تتكرم وتعطى نسب تفصيليه
    وهل الكراميل هو اخر الاضافات
    كيميائى /محسن مختار
    بسامووو
    بسامووو غير متواجد حالياً
    مشكور على هذه المعلومات القيمة
