2009-Repair, Retrofit and Inspection of Building Exterior Wall Systems
النتائج 1 إلى 5 من 5
    الصورة الرمزية majdiotoom
    majdiotoom
    majdiotoom غير متواجد حالياً
    Received: 66
    Repair, Retrofit and Inspection of Building Exterior Wall Systems (ASTM special technical publication, 1493)
    By Paul G. Johnson
    Publisher: ASTM International | 242 pages | 2009-01 | ISBN: 0803134185 | English | PDF | 19.31 MB
    Eighteen peer-reviewed papers address the complex issues of design, construction, maintenance, evaluation, and repair of building exterior wall systems, both old and new.
    Topics cover:
    • Survey and assessment techniques
    • Establishing the integrity of cladding systems and components
    • Case studies of system deterioration and remediation
    • Serviceability issues
    • Seismic retrofit
    • Energy savings attributable to fa?ade upgrades
    • Re-cladding of existing buildings.
    System types addressed include facades comprised of vintage masonry, limestone, precast concrete panels, thin stone, exposed cast-in-place concrete, aluminum framing, EIFS, and glass and metal walls.
    SciTech Book News June 2009 Vol.33, No.2 ISSN 0196-6006 Review
    This work contains papers from an October 2006 symposium on the
    design, construction, and maintenance of building exterior wall systems,
    grouped in sections on testing and evaluation techniques, rehabilitation
    and detailing, case studies, and exterior insulation and finish systems.
    Papers address diverse topics including survey and assessment techniques
    and sampling, establishing the integrity of cladding systems and
    components, case studies of system deterioration and remediation, serviceability
    issues, seismic retrofit, energy savings, and re-cladding of
    existing buildings. Materials addressed include vintage masonry, limestone,
    aluminum framing, and glass and metal walls.
    *******s
    Overview vii
    TESTING AND EVALUATION TECHNIQUES
    Case History of the Use of Electronic Survey Techniques to Assess Planar Distortions
    in Building Façades—KEVIN S. COLL AND DAVID A. VANOCKER 3
    Qualitative Sampling of the Building Envelope for Water Leakage—
    LONNIE L. HAUGHTON AND COLIN R. MURPHY 12
    Applying C1601-06 ‘‘Standard Test Method for Field Determination of Water
    Penetration of Masonry Wall Surfaces in Practice—GERALD A. DALRYMPLE
    AND A. RHETT WHITLOCK 21
    The Identification of Corrosion-Related Damage from Cramp Anchors in a Limestone-
    Clad Building Façade Using NDE Techniques—DAVID A. VANOCKER,
    ERIN M. JOHNSON, AND TRACY D. MARCOTTE 35
    Snap, Crackle, Pop: Remediation of a Noisy Curtain Wall—MARK K. SCHMIDT
    AND W. ROBERT HANNEN 47
    Techniques for Predicting Cladding Design Wind Pressures—MATTHEW BROWNE,
    PETER IRWIN, JASON GARBER, MICHAEL CICCI, JAN DALE, AND RUSS PARNELL 55
    INVESTIGATION, REHABILITATION AND DETAILING CASE STUDIES
    Erroneous Design Assumptions and Construction Defects in a Thin Stone Façade
    System—MARK K. SCHMIDT AND JILL H. MURPHY 69
    Energy Savings Resulting from Building Envelope Upgrades in Mid-Rise
    Construction—A Case Study—J. ERIC PETERSON AND WILLIAM H. BLODGETT 77
    Delayed Ettringite Formation (DEF) within Pre-cast Concrete Cladding Panels on a
    Mid-Rise Commercial Office Building: A Case Study—WARREN R. FRENCH
    AND JOSHUA S. SCHROEDER 85
    Sill Pan Flashing for Block-Frame Windows in Recessed Concrete Openings
    Case Studies—ROBERT BATEMAN 107
    Envelope RemediationA Case Study in Support of an Over-Cladding Approach—
    JARED B. LAWRENCE AND PAUL G. JOHNSON 121
    Over-Cladding of Aluminum Framed Curtainwalls and Skylights—JON M. BOYD 139
    Façade Renovation of the Wexner Center for the Arts—SHAWN S. LI
    AND NEIL MCCLELLAND 154
    A Form to Follow Function: Recladding A Regional Healthcare Facility
    —TAMMY D. FORNER 161
    Repair of an Earthquake Damaged Building Façade in Coordination with FEMA: A
    Case Study Including Stabilization, Evaluation, Historically Sensitive
    Restoration, and Hazard Mitigation—C. HENDRYX AND S. VLOTHO 173
    EXTERIOR INSULATION AND FINISH SYSTEMS EIFS
    Design of Engineered Drainable Exterior Insulation and Finish System (EIFS)
    Cladding—STEPHEN S. RUGGIERO AND ANNEMARIE L. RABAZZI 197
    Evaluation of Debonding of Lamina from Foam and Repairs to Exterior Insulation and
    Finish System Façade—LINDA MCGOWAN, SCOTT RILEY, JIM CONNOLLY AND
    WILLIAM SHALKOWSKI 213
    Retrofitting Barrier Exterior Insulation and Finish System: Methodology and
    Performance Assessment—ERIC K. OLSON AND JUDSON A. TAYLOR 229
    Author Index 239
    Subject Index 241
    http://ifile.it/4rhyvcj/9780803134188.rar
    http://rapidshare.com/files/27554615...ll_Systems.rar
    http://rapidshare.com/files/27553179...188_2.rar.html
    http://hotfile.com/dl/11471968/bbaed..._2.rar.html%0A
    أبو الجنادين
    أبو الجنادين غير متواجد حالياً
    مشكور جزاكم الله خير
    سبحان من لو سجدنا بالعيون له *** على حمى الشوك والمحمى من الإبر
    لم نبلغ العـشر من معشار نعـمته *** ولا العشير ولا عشراً من العشر
    بسام.م.ب
    بسام.م.ب غير متواجد حالياً
    الصورة الرمزية بسام.م.ب
    Received: 36
    بارك الله بك أخي الكربم
    بسام
    سنا الإسلام
    سنا الإسلام غير متواجد حالياً
    Received: 257
    جزاكم الله خيرا وبارك الله فيك
    متغيبة عن الملتقى
    engabogabr
    engabogabr غير متواجد حالياً
    Received: 12
    جزاك الله خيرا
    اللهم انصر الحق حيث كان
