Mig and tig welding
النتائج 1 إلى 10 من 13
    عبير عبد الرحمن
    عبير عبد الرحمن غير متواجد حالياً
    Received: 29
    Mig and tig welding
    GTAW Welding
    Gas Tungsten Arc Welding (GTAW) is frequently referred to as TIG welding. TIG welding is a commonly used high quality welding process. TIG welding has become a popular choice of welding processes when high quality, precision welding is required. In TIG welding an arc is formed between a nonconsumable tungsten electrode and the metal being welded. Gas is fed through the torch to shield the electrode and molten weld pool. If filler wire is used, it is added to the weld pool separately.
    TIG Welding Benefits
    • Superior quality welds
    • Welds can be made with or without filler metal
    • Precise control of welding variables (heat)
    • Free of spatter
    • Low distortion
    Shielding Gases
    • Argon
    • Argon + Hydrogen
    • Argon/Helium
    Helium is generally added to increase heat input (increase welding speed or weld penetration). Hydrogen will result in cleaner looking welds and also increase heat input, however, Hydrogen may promote porosity or hydrogen cracking.
    GTAW Welding Limitations
    • Requires greater welder dexterity than MIG or stick welding
    • Lower deposition rates
    • More costly for welding thick sections
    Common GTAW Welding Concerns
    We can help optimize your welding process variables. Evaluate your current welding parameters and techniques. Help eliminate common welding problems and discontinuities such as those listed below:
    Weld Discontinuities
    • Undercutting
    • Tungsten inclusions
    • Porosity
    • Weld metal cracks
    • Heat affected zone cracks
    TIG Welding Problems
    • Erratic arc
    • Excessive electrode consumption
    • Oxidized weld deposit
    • Arc wandering
    • Porosity
    • Difficult arc starting
    MIG Welding
    Gas Metal Arc Welding (GMAW) is frequently referred to as MIG welding. MIG welding is a commonly used high deposition rate welding process. Wire is continuously fed from a spool. MIG welding is therefore referred to as a semiautomatic welding process.
    MIG Welding Benefits
    • All position capability
    • Higher deposition rates than SMAW
    • Less operator skill required
    • Long welds can be made without starts and stops
    • Minimal post weld cleaning is required
    MIG Welding Shielding Gas
    The shielding gas, forms the arc plasma, stabilizes the arc on the metal being welded, shields the arc and molten weld pool, and allows smooth transfer of metal from the weld wire to the molten weld pool. :
    The primary shielding gasses used are
    • Argon
    • Argon - 1 to 5% Oxygen
    • Argon - 3 to 25% CO2
    • Argon/Helium
    CO2 is also used in its pure form in some MIG welding processes. However, in some applications the presence of CO2 in the shielding gas may adversely affect the mechanical properties of the weld.
    • Undercut
    • Excessive melt-through
    • Incomplete fusion
    • Incomplete joint penetration
    • Porosity
    • Weld metal cracks
    <H4>MIG Welding Problems</H4>
    • Heavily oxidized weld deposit
    • Irregular wire feed
    • Burnback
    • Porosity
    • Unstable arc
    Above are several different representations of weld Cracking
    Below is a representation of a convex fillet weld without discontinuities.
    Shaheen81
    Shaheen81 غير متواجد حالياً
    tanksssssssssssssssssssssssssssssssss
    AHMAD-1976
    AHMAD-1976 غير متواجد حالياً
    Given: 4
    مشكورررررررررررررررررررررررررررررر
    mnci
    mnci غير متواجد حالياً
    تم إيقافه لمخالفة القوانين
    الصورة الرمزية mnci
    Received: 103
    tamereng78
    tamereng78 غير متواجد حالياً
    مشكور
    مشكور.....مشكور
    مشكور.....مشكور.....مشكور
    مشكور.....مشكور.....مشكور.....مشكور
    مشكور.....مشكور.....مشكور.....مشكور.....مشكور
    مشكور.....مشكور.....مشكور.....مشكور.....مشكور..... مشكور
    مشكور.....مشكور.....مشكور.....مشكور.....مشكور..... مشكور.....مشكور
    مشكور.....مشكور
    مشكور
    مشكور.....مشكور
    مشكور.....مشكور
    مشكور
    مشكور.....مشكور
    مشكور.....مشكور
    مشكور
    مشكور.....مشكور
    مشكور.....مشكور
    مشكور
    مشكور.....مشكور
    مشكور.....مشكور
    مشكور
    م.عبدالناصرعجوة
    مشرف واستشارى غلايات
    Received: 50
    موضوع مميز ورائع شكرا جزيلا
    الغلايات البخارية
    هاله المصريه
    هاله المصريه غير متواجد حالياً
    الصورة الرمزية هاله المصريه
    مشكوره مهندسه عبير موضوع جميل
    عبير عبد الرحمن
    Received: 29
    بارك الله فيكم
    م0بشار
    م0بشار غير متواجد حالياً
    موضوع رائع ومميز عن لحام tig , mig مشكورة مهندسة عبير 0
    واحب ان اضيف بعض المعلومات عن كلا النوعين
    لحام tig :-
    1- يتميز بانه من ادق انواع اللحام ويحتاج الى مهارة عالية .
    2- تقلب اقطاب السالب والموجب حيث الموجب على القطعة المشغلة (الحرارة الاعلى ) والسالب مع مسدس اللحام
    (الحرارة الاقل ) لحماية قطب التنجستن من الانصهار .
    3- يستخدم غاز خامل مثل الاركون او الهيليوم والاغلب الارغون لتوفير حماية للقوس من تفاعلات الغازات الموجودة
    في الجو مع منطقة اللحام اي قوس اللحام وبالتالي تشكل منطقة ضعف .
    4- تكون اسطوانات الاركون ذات لون اسود , ويجب ان يكون نقاوة الاركون 99,4 % ويجب ابدال الاسطوانة عند
    وصولها الى ضغط 20 بار لتجنب الخبث في عملية اللحام .
    5- يفضل لحام الانابيب من سمك 6 ملم واقل في لحام tig .
    6- لكون هذا النوع من اللحام دقيق سوف يتعامل مع وصلة اللحام للانبوب بما يسمى gap وهو مسافة الفراغ بين
    قطعتي الانبوبين المراد لحامهما وهذة المسافة من (1,6 - 2,4 ) وكلما كانت اقرب لل 1,6 يستخدم سلك لحام 1,6
    وعندما تكون اقرب لل 2,4 يستخدم سلك لحام قطر 2,4 وسلك اللحام المستخدم هو E13.12
    ويتعامل كذلك مع موازنة الانبوب على الاربع جهات اعلى واسفل ويمين ويسار للانبوبين المراد لحام وصلة بينهما
    ويسمى هذا (high-low) وهو مسموح من 0,4 ملم فدون .
    7- كذلك لكون هذا اللحام دقيق تستخدم الفحوصات البصرية وبالاصباغ النافذة developer+cleanier
    والفحص بالاشعة السينية x- ray وهذه الفحوصات مدرجة من الاقل دقة الى الاعلى دقة , ومن الجدير بالذكر
    ان الفحص بالاصباغ النافذة يطبق على اول pass من اللحام فقط .
    8- يكون معدل تدفق غاز الاركون في مسدس اللحام من( 9-12 )لتر /دقيقة.
    9 - اود ان اذكر هذه المعلومة ان الانابيب المستخدمة في المحركات النفاثة يتم لحامها بواسط لحام tig.
    10-هنالك ايضا معلومة اخرى مفيدة وهي ان اكثر الاشخاص يسمي لحام tig لحام اركون وهو خطا حيث ان الاركون
    هو غاز حماية في هذا الحام وليس طريقة لحام 0.
    لحام mig - mag
    1- ان لحام ال mig هو نفسه لحام ال mag من كل المواصفات والمعدات نفس ماكنة اللحام ولكن الفرق هو الغاز
    الخامل المستخدم للحماية فاذا كان غاز co2 سمي mig و يسمى اذا كان الغاز اركون mag
    2- يتميز لحام ال mig بانه لحام مستمر لوصلات طويلة ومستقيمة وشرائط على الانابيب
    3- ان ماكنة اللحام هي ماكنة لحام عادية ولكن تكون مزودة بجزء اوتوماتيكي يتركب اعلى الماكنة وهو لغرض التغذية
    الاوتوماتيكية لسلك اللحام الذي هو عبارة عن بكرة مثبتة وبواسطة محرك صغير كهربائي ونظومة دشالي gear ورولات ملساء يمر فوقها السلك وبواسطة حركة التروس او الدشالي يتم تغذية سلك اللحام لمسدس اللحام
    4- ان سلك اللحام هو E 7010G
    5- يوجد نوعين من اسلاك اللحام مغلف وغير مفلف بطبقة واقية في حال استخدام الثاني يجب استخدام غاز خامل
    وعند استخدام الاول يمكن استخدام غاز ويمكن عدم استخدامه
    6- لحام ال mig يتصف بصعوبة بدء القوس
    ارجو ان اكون قد افدت بذلك وشكرا مرة اخرى للمهندسة عبير 0
    ليست الانانيية ان يعيش المرء كما يهوى بل يطالب الاخرين ان يعيشو كما يريد
    سبحان الله وبحمده
    م0 بشار
    عبير عبد الرحمن
    Received: 29
    مشكور اخ بشار للاضافه
