Lateral Earth pressures .
النتائج 1 إلى 4 من 4
    صفاء مدني
    صفاء مدني غير متواجد حالياً
    The pressures exerted by an earth backfill against a retaining wall can bf commuted with reasonable accuracy on the basis of theory only for conditions rarely encountered in practice . in the first place , the designer must know what material are to be used for the backfill and in what state they will be place .
    Lateral earth pressure represents pressures that are “to the side” (horizontal) rather than vertical. The objective of this course is to familiarize primarily the non-geotechnical engineer such as civil engineers, structural engineers, architects and landscape architects
    with simple background theory and considerations.
    Calculating lateral earth pressure is necessary in order to design structures such as:
    • Retaining Walls
    • Bridge Abutments
    • Bulkheads
    • Temporary Earth Support Systems
    • Basement Walls
    At the end of this course you will have learned:
    • Basic method of calculating lateral earth pressure
    • Other considerations when developing the total lateral force against a structure
    Categories of Lateral Earth Pressure
    There are three categories of lateral earth pressure and each depends upon the movement
    experienced by the vertical wall on which the pressure is acting. In this course, we will
    use the word wall to mean the vertical plane on which the earth pressure is acting. The
    wall could be a basement wall, retaining wall, earth support system such as sheet piling
    or soldier pile and lagging etc.
    The three categories are:
    • At rest earth pressure(Ko)
    • Active earth pressure(Ka)
    • Passive earth pressure(Kp)
    The at rest pressure develops when the wall experiences no lateral movement. This
    typically occurs when the wall is restrained from movement such as a basement wall that
    is supported at the bottom by a slab and at the top by a floor framing system prior to
    placing soil backfill against the wall.
    The active pressure develops when the wall is free to move outward such as a typical
    retaining wall and the soil mass stretches sufficiently to mobilize its shear strength. On
    the other hand, if the wall moves into the soil, then the soil mass is compressed
    sufficiently to mobilize its shear strength and the passive pressure develops. This
    situation might occur along the section of wall that is below grade and on the oppositeside of the wall from the higher section. Some engineers use the passive pressure that develops along this buried face as additional restraint to lateral movement.
    At Rest Coefficient
    Ko = 1 – sin(φ) (1.0)
    Where: Ko is the “at rest” earth pressure coefficient and φ is the soil friction value.
    Active and Passive Earth Pressure Coefficients
    When discussing active and passive lateral earth pressure, there are two relatively simple
    classical theories (among others) that are widely used:
    • Rankine Earth Pressure
    • Coulomb Earth Pressure
    The Rankine Theory assumes:
    • There is no adhesion or friction between the wall and soil
    • Lateral pressure is limited to vertical walls
    • Failure (in the backfill) occurs as a sliding wedge along an assumed failure plane
    defined by φ.
    • Lateral pressure varies linearly with depth and the resultant pressure is located
    one-third of the height (H) above the base of the wall.
    • The resultant force is parallel to the backfill surface.
    The Coulomb Theory is similar to Rankine except that:
    • There is friction between the wall and soil and takes this into account by using a
    soil-wall friction angle of δ. Note that δ ranges from φ/2 to 2φ/3 and δ = 2φ/3 is
    commonly used.
    • Lateral pressure is not limited to vertical walls
    • The resultant force is not necessarily parallel to the backfill surface because of the
    soil-wall friction value δ.
    The general cases for calculating the earth pressure coefficients can also be found in
    published expressions, tables and charts for the various conditions such as wall friction
    and sloping backfill. The reader should obtain these coefficients for conditions other
    than those discussed herein.
    The Rankine active and passive earth pressure coefficient for the condition of a
    horizontal backfill surface is calculated as follows:
    • (Active) Ka = (1 – sin(φ)) / (1 + sin(φ)) (2.0)
    • (Passive) Kp = (1 + sin(φ)) / (1 - sin(φ))
    Some points to consider are:
    • For the Coulomb case shown above with no soil-wall friction (i.e. δ = 0) and a
    horizontal backfill surface, both the Coulomb and Rankine methods yield equal
    results.
    • As the soil becomes stronger the friction value (φ) increases. The active pressure
    coefficient decreases, resulting in a decrease in the active force and the passive
    pressure coefficient increases, resulting in an increase in the passive force.
    • As the soil increases in strength (i.e. friction value increases) there is less
    horizontal pressure on the wall in the active case.
    م عبد الحكيم مواس
    م عبد الحكيم مواس غير متواجد حالياً
    الصورة الرمزية م عبد الحكيم مواس
    Received: 269
    Given: 472
    جزاء الله خير اختنا العزيزة و مرحباً بك أختاً جديدة على هذا المنتدى
    نتمنى لك التوفيق و الفائدة
    و السلام عليكم ورحمة الله وبركاته
    ام اسامة
    ام اسامة غير متواجد حالياً
    الصورة الرمزية ام اسامة
    Given: 34
    شكرا" لكى وبارك الله فيك .
    :)ربى اجعلنى مقيم الصلاة ومن ذريتى ربناوتقبل دعائى:)
    اللهم اهدنا واهدبنا واهدلنا ويسر الهدى لنا يا ارحم الراحمين.
    علي عبد الجواد
    علي عبد الجواد غير متواجد حالياً
    بارك الله فيكي ياريت كيفية حساب القوي
