بناء على طلب الطبقة البرجوازية Seismic Analysis of Bridges
النتائج 1 إلى 10 من 17
    زعيم الاسكندرية
    زعيم الاسكندرية غير متواجد حالياً
    Received: 262
    Given: 266
    السلام عليكم ورحمة الله وبركاته ،،،
    WinSEISAB v5.0.7 (Seismic Analysis of Bridges)
    Program Overview
    WinSEISAB (Windows SEISmic Analysis of Bridges) is a computer program specifically developed for the seismic analysis of bridges. The overall objectives in developing WinSEISAB were to provide the practicing bridge engineer with a usable design tool and a vehicle for implementing the latest seismic design methodologies into the bridge engineering profession.
    WinSEISAB contains the Uniform Load (AASHTO Procedure 1), the Single Mode Spectral Analysis (AASHTO Procedure 2) and Multimode, i.e., response spectrum, Spectral Analysis (AASHTO Procedure 3) methods included in the current AASHTO Standard Specifications for Highway Bridges, Division IA [1], which adopted the “Guide Specifications for Seismic Design of Highway Bridges” [10] in 1990. The Guide Specifications are based on the ATC report: “Seismic Design Guidelines for Highway Bridges” [2]. Consequently, the AASHTO response spectra used in WinSEISAB correspond to those that were previously identified as ‘ATC-6.’
    WinSEISAB can be used to analyze simply supported or continuous deck girder-type bridges with no practical limitation on the number of spans or the number of columns at a bent. In addition, earthquake restrainer units may be placed between adjacent structural segments. Horizontal alignments composed of a combination of tangent and curved segments are easily described using alignment data taken directly from roadway plans. Connections between the superstructure and the substructure and between adjacent superstructure segments at span hinges can be specified with either a keyword force release or by using bearing elements on a point-by-point basis. The flexibility of the soil and foundations at the abutments and column bottoms is easily included using stiffness coefficients or individual piles grouped into pile footings.
    WinSEISAB has generating capabilities that will, with a minimum amount of input data, automatically build a model consistent with the modeling techniques currently being used to conduct dynamic analyses. Seismic loadings in the form of acceleration response spectra are stored within WinSEISAB and may be easily referenced by the user, or a site-specific spectrum can be utilized. WinSEISAB can perform a static analysis in which dead load forces are generated using structure mass, but WinSEISAB does not perform a combination of dead load and seismic forces.
    Download:
    http://www.imbsen.com/seisab.htm
    عبد الله 212
    عبد الله 212 غير متواجد حالياً
    الصورة الرمزية عبد الله 212
    الصفحة لا تفتح معي
    هل لانني غي برجوازي
    زعيم الاسكندرية
    Received: 262
    Given: 266
    اقتباس المشاركة الأصلية كتبت بواسطة عبد الله 212 مشاهدة المشاركة
    الصفحة لا تفتح معي
    هل لانني غي برجوازي
    يمكنك تحميل برامج الطبقة الكادحة ههههههههههههههههههههههههههه
    والله الصفحة فتحت معايا و100 فل وعشرة يمكن لأننى برجوازى
    زعيم الاسكندرية
    Received: 262
    Given: 266
    خذ عندك رابط الدواء ولا تزعل يا عم
    http://www.4shared.com/file/12184656...eisABv507.html
    سنا الإسلام
    سنا الإسلام غير متواجد حالياً
    Received: 257
    جزاكم الله خيرا وبارك الله فيك
    وجارى التحميل
    متغيبة عن الملتقى
    أبو نادر
    أبو نادر غير متواجد حالياً
    الصورة الرمزية أبو نادر
    Received: 123
    Given: 307
    جزاك الله خيرا أستاذنا الكبير الزعيم البرجوازي الاقطاعي الذي يحتكر التميز وكل ماهو جديد
    تحية لكل الزعماء السكندرانيين لأجل عيونك يازعيم
    وتحية لمشايخ الاسكندرية وعلى رأسهم الزعيم الدكتور الشيخ محمد اسماعيل المقدم
    أحييك لروحك المرحة وخفت دمك وكون أكيد إذا صر لي طريق على مكة لازم شوفك
    لا تنسونى بدعوه بظهر الغيب لعلها دعوه من القلب فيقبلها رب العزه والجلال
    زعيم الاسكندرية
    Received: 262
    Given: 266
    اقتباس المشاركة الأصلية كتبت بواسطة أبو نادر مشاهدة المشاركة
    اشكرك من قلبى مهندس ابو نادر
    والله اكثر ما يشجع المرء هنا على المشاركة هو الشعور الأسرى بين اعضاء الملتقى
    علما باننى اشارك فى منتديات اخرى كثيرة ولكن ما وجدت نفسى الا هنا
    اشكركم مرة اخرى زملائى الأعزاء
    عبد الله 212
    اقتباس المشاركة الأصلية كتبت بواسطة زعيم الاسكندرية مشاهدة المشاركة
    http://www.4shared.com/file/12184656...eisabv507.html
    ايوه كده تمام
    جاري التحميل
    الحاج فوزي البنا
    الحاج فوزي البنا غير متواجد حالياً
    الصورة الرمزية الحاج فوزي البنا
    Received: 38
    شكرا ياخفيف الدم وخفيف الظل
    ادعوا الله ان يرزقك رحمة منة تلين قلبك ليلتف الناس من حولك ( فبما رحمة من الله لنت لهم ولو كنت فظا غليظ القلب لانفضوا من حولك )
    جزاكم الله خيرا
    اللَّهُ لَطِيفٌ بِعِبَادِهِ يَرْزُقُ مَنْ يَشَاءُ ۖ وَهُوَ الْقَوِيُّ الْعَزِيزُ
    المهندس ابوعمر
    المهندس ابوعمر غير متواجد حالياً
    عضو متميز جداً
    الصورة الرمزية المهندس ابوعمر
    Received: 47
    Given: 16
    شكرا يا باشا وجاري التحميل
