بناء على طلب الجماهير RISAFloor v4.0.3
النتائج 1 إلى 10 من 14
    زعيم الاسكندرية
    زعيم الاسكندرية غير متواجد حالياً
    Received: 262
    Given: 264
    اخوانى الأعزاء
    السلام عليكم ورحمة الله وبركاته ،،
    بناء على طلب الجماهير اهديكم هذا البرنامج
    فقط اسالكم ان تدعوا لى بالهداية فى شهر الهداية
    Now the triangle is complated!
    RISAFloor v4.0.3
    Info:
    RISAFloor designs floor systems and works hand in hand with RISA-3D and RISAFoundation to provide a more complete structural engineering software solution for building design. RISAFloor will manage loads, design beams and columns, create quality CAD drawings, and constantly serve RISA-3D the information that it needs for the design of lateral systems.
    RISAFloor features automatic load attribution based on deck direction, automatic live load reductions, full floor vibration checks, full height column stack design (considering splice locations), export (and import) of CIS/2 detailing files, parent/child relationships between floors, exclusive or additive area loads, concrete rebar detailing, true spreadsheet editing, automatic code based wind and seismic load calculations and much more.
    RISAFloor links to RISA-3D for the design of the lateral system and nonstandard building components, and to RISAFoundation for design of the foundation system. You can move effortlessly back and forth between these three programs, creating and modifying your building model in any manner you wish.
    Design your building floor-by-floor. Graphically assign decks and area loads – RISAFloor automatically manages load distribution and calculates LL reductions per code. Create unlimited user-defined design rules – depth/width, deflection, rebar, and many others. Make changes quickly, locally or throughout your model, and see the results.
    When it comes time to get drawings out the door, rely on RISAFloor. Create DXF floor plans with the design information you need: sizes, camber, studs, reactions – you call the shots. Take your drawing management to the next level with our links to Structural Desktop and Autodesk Revit Structure.
    Multi-story buildings? No problem. Manage relationships between floors; define inheritance with parent-child relationships. Have RISAFloor automatically calculate wind/seismic loads. Define snow drifts, create expansion joints, check floor vibrations all within the familiar RISA environment.
    And because RISAFloor integrates seamlessly with RISA-3D, every beam, column, and load is stored to a common database. Never lose track of changes. Work on trusses or transfer girders, frames or footings – work on many designs with only one model.
    Design Features
    Designs hot rolled steel (composite and non-composite), concrete, cold formed steel, steel joists, wood, wood joists and masonry
    Steel Design Codes: AISC ASD 9th, LRFD 2nd & 3rd, HSS Specification, CAN/CSA-S16.1-1994 & 2001, BS 5950-1 2000, IS 800-1998, Euro 3-1993, NZS 3404-1 1997, AS4100-1998 including local shape databases
    AISC 13th Edition using the Direct Analysis Method
    ACI 1999/2002/2005, BS 8110-97, CSA A23.3-94, IS456:2000,EC 2-1992, NZS 3101-1995, AS 3600-2001 with consistent bar sizes through adjacent spans
    Design for custom rebar layouts
    Concrete beam detailing (Rectangular, T and L)
    Masonry Design Codes: MSJC 1999/2002/05, UBC 97 (ASD & Strength)
    Masonry wall design for in-plane, out-of-plane & bearing loads (with or without openings)
    AISI 1999/2001, CSA S136-01 cold formed steel design
    NDS 91/97/2001/2005 wood design, SCL, multi-ply, full sawn, Glulams
    Wood wall design including customizable databases of hold downs & panel schedules
    Interactive member redesign and updating
    Automatic assignment of unbraced lengths with overrides
    Optimization of members per code, size and deflection criteria
    Steel and Wood joist databases
    Model freezing for evaluation of pre-existing designs
    Screenshots:
    Download setup + medicine (pass: "www.civilea.com" (without quotes)):
    أوج الهندسة
    أوج الهندسة غير متواجد حالياً
    مشكور على البرنامج الذي لا لا لا يعمل
    زعيم الاسكندرية
    Received: 262
    Given: 264
    اقتباس المشاركة الأصلية كتبت بواسطة أوج الهندسة مشاهدة المشاركة
    ما هى المشششششششششششششششششششششششششششششششكلة
    زعيم الاسكندرية
    Received: 262
    Given: 264
    هذا الدواء برابط منفصل
    http://www.4shared.com/file/12656543...403-patch.html
    hassananas
    hassananas غير متواجد حالياً
    Received: 224
    Given: 6
    جزاك الله كل خير اخي الكريم
    ومشكور مره اخري
    وكل عام وانت بخير
    محمد 977
    محمد 977 غير متواجد حالياً
    تسلم الأيادي و ألف ألف شكر
    مشكوووووووووووووووووووووووووو ر
    مشكووووور من صميم القلب
    alaa eldin farag
    alaa eldin farag غير متواجد حالياً
    جزاك الله خير الجزاء وبارك الله فيك وكل عام وانت من الناجين في رمضان
    mrazik9653
    mrazik9653 غير متواجد حالياً
    thanks
    شيرو حميد
    شيرو حميد غير متواجد حالياً
    at first i would like to thank u very much for your wide efforts
    and i would like to get RISACONNECTION if u please
    elhalalsab
    elhalalsab غير متواجد حالياً
    Given: 12
    اقتباس المشاركة الأصلية كتبت بواسطة زعيم الاسكندرية مشاهدة المشاركة
    اخي الزعيم
    الرابط لا يعمل (الملف غير موجود)
    ارجو تزويدنا برابط اخر
