غلطة مسمار
النتائج 1 إلى 6 من 6
    زعيم الاسكندرية
    زعيم الاسكندرية غير متواجد حالياً
    Received: 262
    Given: 266
    غلطة مسمار
    شاهدوا مسمار تسبب فى انهيار فندق حياة ريجينسى
    Hyatt Regency Walkways Collapse
    I know again most (may be all) of you have seen these informations/photos or different versions of them on the internet but I think it is important for newbies in civil engineering to see these and realise the importance of the communication in design-manufacture-erection triangle. The informations and photos are from Online Ethics Center.
    Regards
    Hyatt Regency Walkways Collapse (Texas A&M University Engineering Ethics Cases)
    On July 17, 1981, the Hyatt Regency Hotel in Kansas City, Missouri, held a videotaped tea-dance party in their atrium lobby. With many party-goers standing and dancing on the suspended walkways, connections supporting the ceiling rods that held up the second and fourth-floor walkways across the atrium failed. Both the second and fourth-floor walkways collapsed onto the crowded first-floor atrium below while the offset third-floor walkway remained intact. The collapsing of the Kansas City Hyatt Regency walkways is considered the most devastating in the history of the United States. The collapse resulted in millions of dollars in damage, one hundred fourteen people dead and more than two hundred injured, not to mention the thousands adversely affected by the devastating accident.
    An investigation was conducted, and evidence supplied by video tape and witnesses led to a number of principals involved losing their engineering licenses, a number of firms filing bankruptcy, and a great many expensive law suits settled out of court. The case illustrates the importance of meeting professional responsibilities, and the consequences faced by professionals who fail to meet those responsibilities.
    This case is appropriate for structural design, statics and materials classes in addition to its usefulness as a general overview of consequences of professional actions. The Hyatt Regency Walkways Collapse provides a vivid example of the importance of accuracy and detail in engineering design and technical drawings (particularly regarding revisions), and the costly consequences of negligence in this realm.
    Overall collapses resulting from connection failures have occurred only in structures with few or no redundancies. Where low strength connections have been repeated, the failure of one has lead to failure of neighboring connections and a progressive collapse has occurred. The primary causes of connection failures are:
    * Improper design due to lack of consideration of all forces acting on a connection, especially those associated with volume changes.
    * Improper design utilizing abrupt section changes resulting in stress concentrations.
    * Insufficient provisions for rotation and movement.
    * Improper preparation of mating surfaces and installation of connections.
    * Degradation of materials in a connection.
    * Lack of consideration of large residual stresses resulting from manufacture or fabrication.
    (a) The nut only carries the load of the floor above it. (b) The upper nut at the far left carries only the load of the floor above it whereas the nut at the far right carries the load of both floors.
    Photos from the Kansas City Hyatt Regency Walkways Collapse:
    Photo of walkway sections taken from second floor opening. Walkway sections have been moved from their original positions during the attempt to extricate those trapped in the wreckage.
    Photo of intact hanger rods from 4th floor walkway opening.
    Photo of still hanging 3rd floor walkway. Note the free-standing stairs from the 2nd to the 3rd floor in the background. With its columnless design, the stairs seem to be floating in air. The lobby was indeed a masterpiece of architecture and engineering, which had it been executed properly, would have provided its owners with profit and the public with a stunning atmosphere for years.
    General view of the lobby floor, during the first day of the investigation.
    Investigators photograph the hanger rods while standing in an aluminum platform designed to change burned out lights in the 5th floor ceiling. Note that the channel beam sections have completely slipped around the supporting nuts leaving the rods, washers, and nuts completely undamaged. The large white material above the rod is fireproofing material. It was later found that the rods were also defective, in that the material used was of a lower strength material than specified. However, this deficiency played no part in the collapse.
    Close-up photo of the hanger rod threads, washer and supporting nut. Note the deformation caused in the washer as the beam slipped around it.
    Photo of one of the walkway cross-beams, lying on the floor of the lobby. This is one of the 4th floor beams, as evidenced by having two bolt holes drilled through the beam. The 2nd floor beams had a single rod hole.
    Underside view of one of the 4th floor beams.
    Close-up of third floor hanger rod and cross-beam, showing yielding of the material. The flanges have been bent significantly, and the webs are bowed out against the fireproofing sheet rock. It should be remembered that the 3rd floor walkway cross beams were subjected to only half the loading of that induced in the 4th floor beams. The distortion shown below was caused by only very light loading, mostly due to the dead load of the structure.
    رزق حجاوي غير متواجد حالياً
    الصورة الرمزية رزق حجاوي
    Received: 4,986
    Given: 1,442
    اشكر للمهندس الزعيم على هذه المشاركة وبشكل مختصر فقد كانت هناك عددة اخطاء تراكمية حصلت ادت في النهاية لانهيار الممر الواصل بين بين جزأي الفندق من قبل المصمم والمشرف والمقاول والخصها كما يلي:-
    أخطاء المصمم
    • خطأ في تفصيلة التحميل للقضيب الحامل Tie Rode من الناحية التنفيذية
    فكما يلاحظ لتثبيت (العزقة -الصامولة )Nut العلوية يجب (تسنين -قلوظة ) Threaded كامل طول القضيب الحامل وهذا غير ممكن من الناحية العملية ( تحتاج الى تسنين Threaded للقضب Rod مسافة 30 قدم ( بحدود 10 متر) وذلك ليتمكن من ادخال Nut للممر العلوي وهي مكلفة وصعبة التنفيذ وغير عملية )
    • تفصلية Double U Channel Face to Face حيث عملية تنفيذ box ضعيقة حيث يكون التحميل على الشفة Edge الضعيفة وكان الافضل التنفيذ Double U Channel BacK to Back
    • خطأ في تصميم أحمال الممر Catway=walkway حيث تم التصميم على احمال Static Load ( كممر فقط ) وليس على احمال ديناميكية Dainamic Load الناتج عن استخدام الممر كمرقص for dancing
    أخطاء المقاول
    • تعديل تفصلية التحميل لتسهيل العمل دون الالتفات ان ذلك ادى الى تغيير الحمل على Nut
    • العلوية الى الضعف ( حمل الممر العلوي والسلفي )
    التصميم الاساسي ( الصورة على اليسار ) حيث يكون التحمل على Nut من ممر واحد مقداره P حيث ان Tie rode يتحمل حمل الممرين العلوي والسفلي.
    التفصيلة المعدلة من المقاول (على اليمين ) Nut تتحمل ضعف الحمولة ( في المستوي العلوي اي الممر العلوي)
    لاحظ الانهيار في شفة Edge of U Channel
    • ضعف المقاول من الناحية الفنية حيث لم يكن هذا الانهيار الاول له في تنفيذ هذا الفندق فقد سبق وان انهار السقف اثناء التنفيذ.
    • عدم التنسيق الخطي والمباشر مع المصمم عند تعديل تفصيلة التحميل.
    لاحظ ان الممر على اليسار لم يحدث له انهيار حيث كان Tie rode يحمل ممرا واحد فقط اما الذي كان يحمل ممرين في مستويين فقد انهار.
    وللعلم فان حالة انهيار هذا الفندق تم بحثهار كثيرا في الجامعات الامريكية من حيث الاسباب والعبر المستقاة من هذه الحالة.
    وقد قمت في وقت سابق بشرح كامل لاسباب انهيار فندق حياة رنجنسي - امريكا في موضوع "مشاكل تنفيذية وحلول هندسية " المشاركة رقم 158 بتاريخ 11-6-2008
    http://www.arab-eng.org/vb/t85501-16.html
    http://www.arab-eng.org/vb/t85501-19.html
    www.husseinhijjawiest.com
    محمد 977
    محمد 977 غير متواجد حالياً
    تسلم الأيادي على التميز
    مشكوووووووووووووور
    تسلم ايدك
    الف الف شكر من صميم القلب
    مشكوووووووووووووور
    تسلم ايدك
    احمد دار بلين
    احمد دار بلين غير متواجد حالياً
    الصورة الرمزية احمد دار بلين
    مشكور جدا يا مهندس رزق على الشرح الشافي وربنا يحفظ امتنا من المقاولين المستهترين
    زعيم الاسكندرية
    Received: 262
    Given: 266
    عمنا الكبير رزق حجاوى
    السلام عليكم ورحمة الله وبركاته ،،،،
    آسف للتكرار ولم اكن اعلم ان المشاركة موجودة من قبل
    فقط اقتبستها من احد المواقع فاعجبتنى لأنها جمعت كل انواع الغباء بين المصمم والمقاول والمشرف
    شكرا لك وتستحق درجة استاذ مع مرتبة الشرف
    Received: 4,986
    Given: 1,442
    اقتباس المشاركة الأصلية كتبت بواسطة زعيم الاسكندرية مشاهدة المشاركة
    أشكر الاخ المهندس زعيم الاسكندرية على كلاماته وثقته وكل عام وانت بالف خير.
    اشكرك على طرح موضوع انهيار فندق حياة رنجنسي من جديد وان اعادة الطرح لمثل هذا الموضوع وغيره من المواضيع التي توضح الاخطاء وتنبه المهندسين من خطر الوقوع في مثل هذه الاخطاء وقد كتبت أكثر من مشاركة وفي أكثر من مجال في أسباب انهيار المباني الخرسانية او المعدنية منها ولكن وللاسف الشديد توقفت عن الكتابة في مثل هذه المواضيع لاسباب عديدة منها ضغف التفاعل الجدي مع هذه المشاركات .
    وهذا الموضوع من المواضيع التي كما ذكرت تعمقت فيها كثيرا لان هذا الانهيار للمبنى يشكل مثالا صارخا لما يحدث من أخطاء هندسية تبدأ من مرحلة التصميم مرورا بالاستشاري وانتهاءا بالمقاول.
    وكما ذكرت فان انهيار الفندق يشكل نقطة خلاف حول المسبب الحقيقي للانهيار للاطراف الثلاثة .
    ولقد كانت لجنة التحقيق قد انحت باللائمة على الاطراف الثلاثة وسحب شهادات الترخيص بالعمل للمهندس الذين تسببوا في هذه الكارثة.
    وان شاء الله بعد عيد الفطر اعود للكتابة في هذه المواضيع في تحليل اسباب انهيار المنشأت والاخطاء التي تمت وطرق تجنب مثل هذه الاخطاء في المستقبل لتكون عونا لكل مهندس فالكل وارد في الوقوع في الخطأ خصوصا عندما يكون الحل فرديا وبعيدا عن النقاش العلمي الهندسي الجماعي او عندما يكون الحل من قبل مهندس ليس له خبره في جميع مجالات الهندس من تصميم وتنفيذ .
    مع تحياتي للجميع
