RISABase v2.0.2
النتائج 1 إلى 10 من 19
    زعيم الاسكندرية
    زعيم الاسكندرية غير متواجد حالياً
    Received: 262
    Given: 266
    RISABase v2.0.2
    السلام عليكم ورحمة الله وبركاته ،،،
    اهديكم هذا البرنامج الرائع لتصميم قواعد الأعمدة
    وكل عام وانتم بخير
    RISABase v2.0.2
    Info:
    RISABase Features
    When accuracy counts, RISABase delivers. RISABase uses an automated finite element solution to provide exact bearing pressures, plate stresses, and anchor bolt pull out capacities, eliminating the guess work of hand methods. Define bi-axial loads and eccentric column locations. Choose from several connection types and specify custom bolt locations.
    Base Plate Design
    •Plate and bolt design per AISC 13th Edition criteria
    •Color-coded stress & bearing profiles
    •Customized report generation
    •Biaxial analysis, custom bolt locations, clearance checking, stiffeners, load reversal, etc.
    Anchor Bolt Pull Out Capacity
    •Anchor bolt pull out capacity calcs per Appendix D of the ACI 05 code
    •Failure pyramid diagrams display the concrete breakout strength
    Base Plate Design
    RISABase Specifications
    •Steel design dodes: AISC 13th LRFD & ASD, 9th ASD, 2nd LRFD
    •Concrete design Code: ACI 318-05
    •Fully customizable (create program defaults to match your common settings)
    •More than 20 different units available for display (imperial and metric)
    •Comprehensive column shape database including international shapes
    •Automatic baseplate size optimization based on specified max/min length, width, thickness
    •“Square Baseplate” option for easier fabrication
    •Finite element analysis of baseplate for the most realistic and accurate results
    •Rigid analysis option to match hand calculation results
    •Column eccentricity (from baseplate center)
    •Automatic allowable bearing pressure calculations per AISC
    •Stiffened connections using plates, clip angles, or channels
    •Custom anchor bolt layout (great for accommodating misplaced anchor bolts in the field)
    •Anchor bolt layout optimization (based on minimum spacings, edge distances)
    •Shear lug analysis
    •Anchor bolt strength checks for tension/shear per AISC
    •Anchor bolt pullout capacity calculated per ACI 318 Appendix D, considering all seven dominant failure modes (cone breakout, side face blowout, pryout, etc) including group failure calculations
    •Anchor bolt pullout seismic requirements checks and supplemental seismic reinforcement design
    •Biaxial loading and design for both shears and moments.
    •Uplift design
    •Load combination generator for five different codes, with load reversibility
    •Printable detail report lists all input and output (great for plan checking)
    •Color stress contours for bending/bearing stresses
    •Color bolt group failure diagrams for each failure mode
    Screenshots:
    Download setup + medicine ( pass: "www.civilea.com" (without quotes) ) :
    essam awad11
    essam awad11 غير متواجد حالياً
    الصورة الرمزية essam awad11
    جزاك الله خيرا اخانا الحبيب ، ولو امكن تزويدنا بأمثله لكيفيه التعامل مع البرنامج بالصورة المطلوبه أو أى طريقه تجدها سهله لفهمه
    والسلام عليكم ورحمه الله وبركاته
    محمد 977
    محمد 977 غير متواجد حالياً
    تسلم الأيادي على التميز
    مشكوووووووووووووور
    تسلم ايدك
    الف الف شكر من صميم القلب
    hassananas
    hassananas غير متواجد حالياً
    Received: 224
    Given: 6
    تسلم ايدك
    if any one has risa floor please
    زعيم الاسكندرية
    Received: 262
    Given: 266
    اقتباس المشاركة الأصلية كتبت بواسطة essam awad11 مشاهدة المشاركة
    البرنامج مدرج معه عدة امثلة ومشروحة فى قائمة help وهذا البرنامج هو الأكثر سهولة من بين برامج تصميم القواعد الحديدية للأعمدة مثل prokon وهو يخص المهتمين بالمنشآت المعدنية اكثر من غيرهم
    فقط البرنامج يطلب منك ادخال القوى المؤثرة على القاعدة والمفروض اننا حصلنا عليها من برنامج تحليل انشائى مثل sap ومن ثم يتم ادخال هذه القوى للبرنامج
    زنوبيا 11
    زنوبيا 11 غير متواجد حالياً
    الصورة الرمزية زنوبيا 11
    Received: 124
    Given: 131
    بارك الله فيك أخي الزعيم
    مشكور جدا
    *الله لا إله إلا أنت سبحانك إني كنت من الظالمين*
    *اللهم لا سهل إلا ما جعلته سهلا ، وأنت إن شئت تجعل الحزن سهلا*
    *أستغفر الله العظيم وأتوب إليه*
    **أشهد ألا إله إلا الله وحده لا شريك له وأن محمدا عبده ورسوله**
    essam awad11
    اقتباس المشاركة الأصلية كتبت بواسطة زعيم الاسكندرية مشاهدة المشاركة
    جزاك الله خيرا على الرد وسأراجع ذلك ان شاء الله
    Abo Fares
    Abo Fares غير متواجد حالياً
    Received: 344
    Given: 291
    جزاك الله عنا كل خير..... الله يعطيك العافية..
    لك خالص التحيــــات
    هادي المهندس
    هادي المهندس غير متواجد حالياً
    الصورة الرمزية هادي المهندس
    Received: 50
    مشاركه مفيده اخي الزعيم بارك الله بك................
    مع تحياتي
    mustafa101
    mustafa101 غير متواجد حالياً
    الصورة الرمزية mustafa101
    الرابط لا يعمل ممكن ياأخي ترفعه ثانية
    بارك الله فيك
