Could you help me?
النتائج 1 إلى 3 من 3
    الصورة الرمزية الموحد
    الموحد
    الموحد غير متواجد حالياً
    Could you help me?
    Dear all mechatronics engineers,
    I have a problem and I would like to know if you can help me to get a solution:
    Our system consists of a fixed plate, a mechanism, and a mobile plate. When the force applied to the mobile plate is equal to Fa =150 N, the mobile plate is stable (Case 1). As this force decreases, the mobile plate must move upward till the applied force is once again equal to Fa (Case 2). The mechanism should be locked after this movement. What type of mechanism could we use to achieve this giving that the initial distance between the plates is 5 mm and the maximum allowed distance is 10 mm?
    The dimensions of the lower and upper plate are:
    Width: 32 mm
    Length: 37 mm
    Height: 2 mm
    I need the distractor to fit into this space. For the pneumatic and hydraulic way, I don't think that it works because I don't have enough space for the accumulator tank. A miniature electric actuator may work, but are there linear motors that can fit into this space?
    Thank you in advance for your help
    الموحد
    Never mind, thank you anyway. Have a nice day
    De même que le fleuve retourne à la mer, le don de l'homme revient vers lui
    الموحد
    Metal bellows are the best solution.
