i need urgent help in >> telephone signaling module
النتائج 1 إلى 2 من 2
    k_general
    k_general غير متواجد حالياً
    hi all
    i got this task today and i have to solve it within two days i really need any help
    the task :
    Design and implement a telephone signaling module that generates standard signaling tones ( dial, ringing, ringing back, busy tone).that is to say to bring us a complete circuit that generates those tones through a speaker. Use any hardware which will help from your point of view ( Ics , Microcontroller or anything you need).
    ماجد عباس محمد
    ماجد عباس محمد موجود حالياً
    Received: 151
    It is a set of audio oscillators , generate the following frequencies
    350Hz+440Hz for dial tone
    480+620 for busy tone
    440+480 for ring back
    24 ring tone
    Dial tones can not be generated this way for their higher accuracy, so use This chip UM91214 and a standered crystal 3.58MHz
    download its data sheet from
    http://www.alldatasheet.com
    http://www.alldatasheet.com/datashee...C/UM91214.html
