(typs of fans) انواع المراوح.
النتائج 1 إلى 10 من 32
    عبير عبد الرحمن
    عبير عبد الرحمن غير متواجد حالياً
    Received: 29
    Types of Fans
    There are several types of fan to choose from in ventilation.
    These are:
    1. Propeller
    2. Axial flow
    3. Centrifugal
    4. Mixed flow
    1. Propeller Fan
    Used in situations where there is minimal resistance to air flow.
    Typical outputs are; up to 4 m3/s and up to 250 Pa pressure.
    Fan efficiency is low at about 40%.
    Suitable for wall, window and roof fans where the intake and discharge are free from obstacles.
    Can move large volumes of air.
    Low installation cost.
    2. Axial Flow Fan
    High volume flow rate is possible with this type of fan with high efficiency, about 60% to 65%.
    Typical outputs are; up to 20 m3/s and up to 700 Pa pressure.
    The fan is cased in a simple enclosure with the motor housed internally or externally.
    Aerofoil blades can be used to increase efficiency.
    Adjustable pitch blades can be used for greater flexibility.
    Ductwork can be simply connected to the flange at either end of the fan.
    3. Centrifugal Fan
    High pressure air flow is possible with this type of fan.
    Used in air handling units and other situations to overcome high resistance to air flow.
    The impeller is made of thin blades which are either forward or backward curved.
    The air changes direction by 90 degrees in a centrifugal fan so more space is required.
    Usually the motor is placed external to the casing and a vee belt and pulley drive is commonly used.
    Centrifugal Blades
    Centrifugal curved fan blades generally have higher efficiencies than if a plain flat blade is used.
    The efficiency of a fan with forward curved blades is about 50% to 60%.
    The forward curve has a scoop effect on the air thus a higher volume may be handled.
    Direction of rotation
    Blade
    FORWARD CURVED BLADE
    Backward curved blades offer even better efficiency, 70% to 75%.
    This improves airflow through the blade and reduces shock and eddy losses.
    High pressures can be developed with backward curved blades.
    Even further improvements may be made by using an aerofoil section blade in which case the efficiency may be 80% to 85%.
    Another feature of backward curved blades is their non-overloading characteristic.
    FAN CHARACTERISTIC CURVES
    Volume Flow rate
    Pressure or
    Power
    Fan Power Characteristic
    Static Pressure Characteristic
    Flat section non-overloading
    A disadvantage is the high blade tip speed, necessary to obtain a comparable rate of discharge to forward curved blades, makes the fan noisy.
    4. Mixed Flow Fan
    Mixed Flow fans can be used for return air, supply, or general ventilation applications where low sound is critical. As compared to similarly sized axial fans, a mixed flow fan can be 5-20 dB quieter.
    عمر محمد3
    عمر محمد3 غير متواجد حالياً
    جزاكى الله خيرا
    كل عام وانتم والامه الاسلاميه بخير
    ahmed helmy
    ahmed helmy غير متواجد حالياً
    أشكرك علي هذا المجهود الجميل
    ahmed helmy
    م.عبدالناصرعجوة
    مشرف واستشارى غلايات
    Received: 50
    شكرا جزيلا وكل عام والجميع بخير بمناسبة الشهر الكريم
    الغلايات البخارية
    م.عبدالناصرعجوة
    Received: 50
    الغلايات البخارية
    م.عبدالناصرعجوة
    Received: 50
    الغلايات البخارية
    م.عبدالناصرعجوة
    Received: 50
    الصور المرفقة
    م.عبدالناصرعجوة
    Received: 50
    الغلايات البخارية
    م.عبدالناصرعجوة
    Received: 50
    الغلايات البخارية
    م.عبدالناصرعجوة
    Received: 50
    الصور المرفقة
