المجمع الشمسي ذو القطع المكافئ! Solar Parabolic Trough
النتائج 21 إلى 30 من 42
  1. [21]
    د.محمد باشراحيل
    إستشاري الملتقى
    Received: 127
    Given: 15
    Dish/Engine Systems
    The dish/engine system is a concentrating solar power (CSP) technology that produces relatively small amounts of electricity compared to other CSP technologies—typically in the range of 3 to 25 kilowatts. Here you will learn about the basic operation of dish/engine systems. A parabolic dish of mirrors directs and concentrates sunlight onto a central engine that produces electricity. The two major parts of the system are the solar concentrator and the power conversion unit.
    Solar Concentrator
    A dish/engine power plant.
    The solar concentrator, or dish, gathers the solar energy coming directly from the sun. The resulting beam of concentrated sunlight is reflected onto a thermal receiver that collects the solar heat. The dish is mounted on a structure that tracks the sun continuously throughout the day to reflect the highest percentage of sunlight possible onto the thermal receiver.
    Power Conversion Unit
    The power conversion unit includes the thermal receiver and the engine/generator. The thermal receiver is the interface between the dish and the engine/generator. It absorbs the concentrated beams of solar energy, converts them to heat, and transfers the heat to the engine/generator. A thermal receiver can be a bank of tubes with a cooling fluid—usually hydrogen or helium—that typically is the heat-transfer medium and also the working fluid for an engine. Alternate thermal receivers are heat pipes, where the boiling and condensing of an intermediate fluid transfers the heat to the engine.
    The engine/generator system is the subsystem that takes the heat from the thermal receiver and uses it to produce electricity. Currently, the most common type of heat engine used in dish/engine systems is the Stirling engine. A Stirling engine uses the heated fluid to move pistons and create mechanical power. The mechanical work, in the form of the rotation of the engine's crankshaft, drives a generator and produces electrical power.
    Learn more about DOE's dish/engine R&D.
  2. [22]
    م سامى زكى
    م سامى زكى غير متواجد حالياً
    الصورة الرمزية م سامى زكى
    Given: 55
    جزاك الله كل خير يا دكتور
    وجعل ذلك فى ميزان حسناتك
    وأسكنك الفردوس الاعلى
  3. [23]
    د.محمد باشراحيل
    إستشاري الملتقى
    Received: 127
    Given: 15
    اقتباس المشاركة الأصلية كتبت بواسطة م سامى زكى مشاهدة المشاركة
    اللهم آمين ..
    وأثابك الله على دعواتك خيرا منه..
    وجمعنا وإياك مع المصطفى عليه افضل الصلاة وأزكى التسليم
    في الفردوس الأعلى.
  4. [24]
    د.محمد باشراحيل
    إستشاري الملتقى
    Received: 127
    Given: 15
    اقتباس المشاركة الأصلية كتبت بواسطة نزار ابوفاتح مشاهدة المشاركة
    jazak allah ana kul khayr
    المهندس نزار ابو فاتح ..
    وجزاك الله الف خير...
  5. [25]
    مهندسة بدوية
    مهندسة بدوية غير متواجد حالياً
    Given: 11
    د. محمد الله يعطيك العافية على هذه الاضافة
  6. [26]
    د.محمد باشراحيل
    إستشاري الملتقى
    Received: 127
    Given: 15
    اقتباس المشاركة الأصلية كتبت بواسطة مهندسة بدوية مشاهدة المشاركة
    الأخت المهندسة البدوية
    ويعطيكِ مليون عافية
    وتستحقين تقييم
  7. [27]
    دلوفان69
    دلوفان69 غير متواجد حالياً
    بارك الله فيك
  8. [28]
    المهندس المنيني
    المهندس المنيني غير متواجد حالياً
    د. محمد انا أحضر لرسالة ماجستير عن طبيعة التدرج الحراري على طول المحرق للمركز
    اذا كان لديك معلومات تخص هذا الموضوع الرجاء تزويدنا بها مع جزيل الشكر
  9. [29]
    د.محمد باشراحيل
    إستشاري الملتقى
    Received: 127
    Given: 15
    اقتباس المشاركة الأصلية كتبت بواسطة دلوفان69 مشاهدة المشاركة
    بارك الله فيك
    مشكور مرورك م.دلوفان ..بوركت وعوفيت وجزيت خيرا.
  10. [30]
    د.محمد باشراحيل
    إستشاري الملتقى
    Received: 127
    Given: 15
    اقتباس المشاركة الأصلية كتبت بواسطة المهندس المنيني مشاهدة المشاركة
    وعليكم السلام ..
    الأخ المهندس المنيني
    حقيقة ليس عندي حاليا
    ولكن سوف ابحث لك علني اجدها وأضعها لاحقا.
    شاكرا ثقتك .. وفقك الله.
