Additive Lubricant
النتائج 1 إلى 10 من 10
    الصورة الرمزية محمدجاسم العامري
    محمدجاسم العامري
    محمدجاسم العامري غير متواجد حالياً
    Received: 38
    Given: 117
    Additive Lubricant
    Lube Oil: Additives
    Below is a list of the most commonly found additives in lubricating oil.
    Detergents
    Detergents serve to hold the acid-neutralising compounds in solution in the oil. They are usually alkaline and react with the strong acids (sulphuric and nitric) which form during the combustion of the fuel and which would cause corrosion to the engine internals if left unchecked. Neutral detergents are also used to impart anti-corrosion, anti-wear and even extreme pressure properties to an oil. Overbased detergents are salts of alkaline earth metals such as calcium and magnesium that contain more alkaline metal than is required for their manufacture. They thus have both a good detergent property and an excellent ability to neutralise strong acids.
    Dispersants
    Dispersants keep soot and combustion products in suspension in the body of the oil charge and therefore prevent deposition as sludge or lacquer. These dispersants become depleted with time; one important reason for regular oil changes in heavily contaminated systems.
    Antioxidants
    Antioxidants delay or inhibit the processes of decomposition that occur naturally in lubricants as they 'age' or oxidise in the presence of air. These oxidation processes give rise to formation of gums, lacquers and sludge resulting in an increase in acidity and viscosity. Excessive oxidation is a common reason for condemning a lubricant, usually because acidity and/or viscosity have exceeded the permissible limits. Some antioxidants also function at temperatures above about 100°C by de-activating metal surfaces. ZDTP is an example of this.
    Anti-Foam Additives
    Substances that prevent foaming. Air entrapment in lubricating oil can cause oil starvation due to the presence of air bubbles at the contacting surfaces. This may lead to catastrophic failure of moving components. It is of particular importance for gear box systems where airation is often severe during normal running conditions.
    Pour Point Depressants
    Mineral oils, especially the higher viscosity and less refined ones, contain paraffin waxes that start crystallising at low temperatures. This process rapidly increases the viscosity of the oil and leads to faster crystallisation as the temperature decreases further. Pour point depressants prevent this rapid viscosity increase, usually by preventing agglomeration of the initial wax crystals that form.
    Anti-Wear and Extreme Pressure Additives
    Both types reduce wear of contacting surfaces. This is attributed to reactions on the contacting surfaces in the presence of the additive. The most common anti-wear additives are zinc and phosphorus-based, although other chemicals have been tried. Extreme pressure (EP) additives perform their task in a similar manner and are commonly made from varying proportions of chemically bound sulphur and phosphorus. They bind with exposed metal surfaces to form low rupture strength films that limit damage from micro-seizure if the oil film ruptures. Sulphur in fuel provides a similar protective function for fuel injection components.
    Polymer Thickeners
    These additives are used if the viscosity characteristic of an oil at different temperatures needs to be altered. Multigrade oils, with few exceptions, contain polymers to thicken a monograde oil of a lighter grade and give it multigrade properties, i.e. they are able to function better at much lower temperatures whilst retaining their high temperature characteristics. Some authorities stipulate the use of multigrade oils in emergency equipment due to their excellent viscosity/temperature characteristics. This type of additive is also used in some hydraulic oils to adjust the viscosity/temperature characteristics.
    Corrosion Protection
    Included to protect vulnerable metal surfaces from atmospheric corrosion, especially when machinery is idle or during overhaul. Also include alkaline materials to neutralise strong acids as they are formed during combustion. This group of materials also provide detergency.
    Characteristics of Additives AdditiveNameCharacteristicsDetergency & cleaning actionPhenaltes, Sulphonates, NaphthenatesInteracts with varnish or sludge to neutralise and solubilise.DispersancyPBI (Polyisobutylene) SuccinimidesDispersants are soluble in the oil and have a polar end which attracts and binds to contaminants preventing settling and adhesion to metal surfaces.AntifoamingSilicone Polymers (very low concentrations)Not really necessary for diesel engines in properly designed systems, but provides anti-foam in gearbox and also at the refinery during blending.Pour PointPolymethylacrylateUsed in SAE 30 grades and below to ensure point criteria are met.Anti-wear load carryingZDTP (Zincdialkyldithiophosphate)ZDDP (Zincdiethlydithiophosphate)Chemicals react with surfaces forming films which have a slower shear strength than parent metal.VI ImproversPolymers of: Methacrylate Acrylate Olefin Styrene-ButadieneIncrease in relative viscosity more at high than low temperature.Rust and corrosion inhibitionSulphates, Thiourea type chemicalsChemically absorbed onto bare metal surfaces providing protection and neutralisation.
    Comment: Those indicated on this page are the ones most commonly found in industrial and marine applications. Some companies use different additives and components but generally the list is correct.
    مهندس المحبة
    مهندس المحبة غير متواجد حالياً
    Received: 157
    موضوع مهم جدا ومفيد شكرا لك وإلى الأمام .....
    CHE Amjad
    CHE Amjad غير متواجد حالياً
    مشكور اخي الكريم و يعطيك العافيه
    محمدجاسم العامري
    Received: 38
    Given: 117
    Smile
    اقتباس المشاركة الأصلية كتبت بواسطة مهندس المحبة مشاهدة المشاركة
    شكرا"على زيارتكم الموضوع واتمنى ان يكون عند حسن ظنكم
    لنرجع الى لااله الا الله محمد رسول الله
    ونترك الشرك والذنوب
    (لا خير في لذة من بعدها النار )
    محمد جاسم العامري
    محمدجاسم العامري
    Received: 38
    Given: 117
    Smile
    اقتباس المشاركة الأصلية كتبت بواسطة che amjad مشاهدة المشاركة
    ونترك الشرك والذنوب
    محمد جاسم العامري
    مرتضى الموسوي
    مرتضى الموسوي غير متواجد حالياً
    اخي العزيز محمد جاسم العامري
    اولا الشكر الجزيل لك لطرحك الموضوع وعندي سؤال طرحته عليك سابقا ولم تصل لي الاجابة وهو مضافات الزيوت لانني اعمل في احدى شركات وزارة الصناعة والمعادن العراقية وكلفت في البحث وتم الانتاج حول مضافات الزيوت التي تقلل انجماد الزيوت في فصل الشتاء وبعد مراجعة مصفى الدورة عرفت ان المادة المضافة هي مادة بوليمرية ولم اعرف شنو هي المادة ؟
    واما سؤالي الثاني هو هنالك مواد سليكونية تضاف الى الزيوت ضد الرغوة فأن لديك اي معلومات عن اسم المادة او اي شي فلا تبخل عني وجزاك الله خيرا
    a_a_k
    a_a_k غير متواجد حالياً
    بارك الله فيك,,,,,,,,,
    محمدجاسم العامري
    Received: 38
    Given: 117
    Smile
    اقتباس المشاركة الأصلية كتبت بواسطة مرتضى الموسوي مشاهدة المشاركة
    ماده الpour point depresent ماده البوليمر محتكره الصنع لعده دول عالميه .
    اما محسن مانع الرغوة فيحوي ضمن تركيبه الداخلي مركبات السيليكون لكن الاضافه تكون حساسه جدا" وتصل الى 0,05 وهذه النسبه قليله نسبه الى بقيه المحسنات التي تصل الى 20% والمحسن هو anti foam وانها متوفره في مكاتب الشركات النتجه مثل شركه السجايا وسلفوكيم في العراق
    واعذرني على التاخير
    ونترك الشرك والذنوب
    محمد جاسم العامري
    محمدجاسم العامري
    Received: 38
    Given: 117
    اقتباس المشاركة الأصلية كتبت بواسطة a_a_k مشاهدة المشاركة
    مشكور اخي على الزيارة
    ونترك الشرك والذنوب
    محمد جاسم العامري
    hend30
    hend30 غير متواجد حالياً
    Anti foam ,detergents,solvents,lubricants,water treatments,
    ليمـــــــــرامنذ عام 1980،و لدينا فريق من المستشارين والخبراء والمصنعين المحترفين للمنتجات الكيميائية عالية الجودة والتقنية والمستخدمة لكافة اغراض الصيانه.
    الاستماع
    قراءة صوتية للكلمات
    نحن نقوم بالتوريد وتشغيل المواد الموردة
    1 -- المواد الكيميائية
    أ- للمعادن
    -- إزالة الترسبات (التخليل وPassivation على الفولاذ المقاوم للصدأ وفقا للنشرة A380 الجمعية الأمريكية)
    -- مزيلات الصدأ ، ومحولات الصدأ Looseness'
    -- مثبطات التآكل
    -- الجلفنة على البارد
    -- مواد إزالة الدهون (القلويات والمذيبات)
    -- اللواصق والحشو والمبردات.
    -- كل مواد التشحيم (الشحوم المقاومة للضغط)وذلك لانزلاق المحامل والعتلات والمفاصل والتروس.
    -- مواد التشحيم للاحبال المعدنية والاوناش
    -- Antiseize التكنولوجيا العالية 1200-1400
    -- المواد الكيميائية للاختبار الإتلافي للتفتيش(NDT )
    ب- معدات كهربائية
    -- ماكينة متخصصه للتنظيف بالبخار الجا ف
    -- مواد عازلة للمعدات الكهربائية من الرطوبة
    -- مواد لادمصاص الرطوبة
    ج- الغلايات وابراج التبريد (Schiller )
    -- المواد الكيميائية لتنظيف كلا النظامين
    -- مثبطات الحامضية ومضاد الرغوة
    -- المواد الكيميائية لمعالجة المياه الصناعية
    -- تطهير وتنظيف نظم التبريد (الماء والهواء)
    -- مضافات الوقود الغلاية
    -- مثبطات الرغوة
    د. صهاريج الوقود
    -- Desludging وتنظيف الرواسب والطفله
    ﻫ- مواد أولية لمختلف الأغراض
    -- حمض الهيدروكلوريك -- كلوريد الميثيل
    -- مونو وجلايكول الايثيل -- حامض النيتريك
    -- حمض الكبريتيك -- بروبيلين غليكول
    -- هيدروكسيد الصوديوم -- النيتروجين
    -- هيدروكسيد البوتاسيوم ...............الخ
    2 - الخدمات التقنية
    - توفير الخبراء والاستشاريون .
    - توفير برامج التدريب التقني.
    3 -- خدمات التنظيف
    أ- في كل أنحاء المباني خدمات التنظيف.
    ب- خدمات التنظيف للفنادق .
    ج- خدمات التنظيف للمطاعم والمطابخ .
    شركة ليمرا للكيماويات والخدمات البترولية
    المدير العام
    د/ هند صادق مصطفى
    0191037613
    [email protected]
