تعرف على Tracking Systems of radar
النتائج 1 إلى 4 من 4
    الصورة الرمزية المهندس اون لاين
    المهندس اون لاين
    المهندس اون لاين غير متواجد حالياً
    Tracking Systems
    The purpose of a tracking system is to determine the location or direction of a target on a near-continuous basis. An ideal tracking system would maintain contact and constantly update the target's bearing (azimuth), range and elevation. The output of the tracking system can be sent to a fire control system, which stores the information and derives the target's motion and therefore its future position. As we shall see, tracking systems not only provide an automatic target following feature but also determine the target's position with sufficient accuracy for weapons delivery.
    Radar Servo Tracking System
    One of the most basic tracking system designs is the servo tracking system. Here, the radar antenna is initially trained on a target after which it automatically remains pointed at the target as it follows its motion. Furthermore, the system provides continuous position information to the operator and possibly to a fire control system. The antenna is rotated by a motor which provides a negative position feedback signal to a controller. This subsystem is known as a servo-mechanism.
    Figure 1. Servo mechanism
    The commanded input signal is the desired azimuth of the antenna. The error signal drives the motor to reposition the antenna until the position feedback indicates the antenna is at the desired azimuth, at which point the error signal is zero and the motor stops. This servo-mechanism can be combined with a tracker, which determines the azimuth a the target, which the system now uses as the input.
    Figure 2. Servo tracking
    mechanism.
    This is the same servo-mechanism block diagram, but the input comes from the tracker. The combination is called a radar servo-tracking system. The heart of this system is the tracker, which takes the return signal and position information and determines the location of the target. There are several ways to do this, with varying degrees of complexity and accuracy.
    Consider the following data which might be obtained as a circular sweep radar panned across a target.
    Figure 3. Return strength as
    beam sweeps over target.
    The individual returns are shown as the vertical lines. As the beam sweeps across the target, there are eight returns generated, whose strength increases until the target is centered in the beam and then falls off. The target location can be determined from the point of maximum return strength. However, the region of maximum return is broad and therefore the exact location of the target cannot be determined with high accuracy. Certainly, one could locate the target within some fraction of the beamwidth, but using this system the tracking accuracy would not be much better than about one-quarter of the beamwidth. This still would be insufficient for weapons delivery.
    The accuracy can be improved by using a dual-beam system. The two beams are offset in angle by a small amount to either side. The center between the beams is known as the boresight axis.
    Figure 4. Dual beams.
    The two beams can be created by a dual-feed system, where the two parallel beams are fed into the reflector slightly to one side or the other. When the beam is reflected, the offset in the feed axis will cause the beam to be reflected off at an angle relative to the boresight.
    Figure 5. How offset feed changes
    beam.
    Now when a dual-beam system scans across a target, the return will be the sum of the two beams. If one of the beams if inverted (or made out-of-phase), the result will have a well-defined location of the target, namely where the difference between the beams is zero.
    Figure 6. Constructing the dual
    beam output.
    Since the return strength is changing rapidly to either side, the location of the target can be determined with great accuracy. For a typical radar beam that is 30 wide, a dual-beam system could track the target with 0.10 accuracy, which is sufficient for weapons delivery.
    Another nice feature of the dual-beam system is that the return strength varies nearly linearly in the vicinity of the target. Therefore it is easy to measure the target location even if the boresight is not directly on the target. The difference in target location and the boresight will be linearly proportional to the return strength as long as the target is not too far off center. Using the maximum strength method, it is not even clear how to determine the correction direction to reposition the antenna, since the return strength varies equally to either side of the boresight.
    The dual-beam system can also be used for tracking in elevation. In fact, a monopulse system uses two dual-beam systems, one for elevation and one for azimuth. This requires four beams which are measured in pairs.
    Figure 7. Monopulse radar.
    Dual-beam systems are generally used for fire control tracking, where high accuracy is required. A dual beam system has a limited range because the target is not in the maximum power portion of the beam. The target is off-axis for either beam.
    Range Tracking
    Range tracking is accomplished in a similar manner to dual-beam angle tracking. Once the range has been measured, the tracking system attempts to predict the range on the next pulse. This estimate becomes the reference to which the next measurement will be compared. The comparison is made by using two range windows called the early and late range gates.
    Figure 8. Range gates.
    The area of the return in each gate is computed by integration. The difference between the area in the early and late gates is proportional to the error in the range estimate. If the two areas are equal, the return is centered directly on the range estimate, and there is no error. If the return has more area in the early gate, the range estimate is too great, and therefore the range error is positive. In the near vicinity of the range estimate, there will be a linear relationship between the range error and the difference in the areas.
    Figure 9. Range error.
    As long as the range estimate is not too far off, the tracking error can be determined and the target range updated. Again, like dual-beam tracking, the range tracking system can measure the target range with greater accuracy than the range resolution of the system, Rres, which is determined by the pulse width and possibly the pulse compression ratio.
    Track-while-scan (TWS)
    In many cases, it would be undesirable to dedicate the entire radar system to tracking a single target. We have already seen that the servo tracking system maintains the antenna pointed in the vicinity of the target at all times. Unfortunately, there is no search capability when tracking using this method. The track-while-scan (TWS) system maintains the search function, while a computer performs the tracking functions. The TWS system is capable of automatically tracking many targets simultaneously. Furthermore, the TWS system can also perform a variety of other automated functions, such as collision or close CPA warnings.
    The TWS system manages targets using gates. We have already seen an example of gates used in the range tracking system. A TWS system may use range, angle, Doppler and elevation gates in order to sort out targets from one another. When a target is first detected, the computer will assign it an acquisition gate, which has fixed boundaries of range and bearing (angle), and possibly other parameters, depending on the system. When the radar sweeps by the target again, if the return still falls within the acquisition gate, the computer will initiate a track on the target.
    Figure 10. Tracking and acquisition
    gates.
    By following the history of the target positions, the course and speed of the target can be found. The combination of range, bearing, course and speed at any one time is known as the target's solution. It is used to predict where the target will be at the next observation. Once a solution has been determined, the computer uses a tracking gate about its predicted position. If the target falls within the predicted tracking gate, the computer will refine its solution and continue tracking. If the target is not within the tracking gate at the next observation, it will check to see if the target is within a turning gate which surrounds the tracking gate.
    Figure 11. Use of a turning gate
    to maintain track on a maneuvering target.
    The turning gate encompasses all the area that the target could be in since the last observation. If the target is within the turning gate, the computer starts over to obtain the new solution. If the target falls outside of the turning gate, the track will be lost. The system will continue to predict tracking gates in case the target reappears. Depending on the system, the operator may be required to drop the track.
    The process of assigning observations with established tracks is known as correlation. During each sweep, the system will attempt to correlate all returns with existing tracks. If the return cannot be correlated, it is assigned an acquisition gate, and the process begins again. On some occasions, a new target may fall within an existing tracking gate. The system will attempt to determine which return is the existing target and which is the new target, but may fail to do so correctly. It is common for TWS systems to have difficulty when there are many targets, or when existing tracks cross each other. In the later case, the computer may exchange the identity of the two crossing tracks. In all these cases if mistaken identity, the operator must intervene to correct the problem.
    Figure 12. Crossing tracks.
    The TWS system uses a track file for each established target that it tracks. The track file contains all of the observations that are correlated with that particular target. For example, the range, bearing and time of observation. The track file is given a unique name known as the track designation. This is usually either a simple number, like "track 25". Depending on the system, the track file may contain other useful information, such as the classification of the target, such as "ship" or "aircraft". This information may be used by the computer when determining the track and turning gates. Finally, the track file also contains the current solution to the tracks motion. Some systems maintain a history of solutions which can be useful in determining the pattern of a maneuvering target. For example, if a target alters course every 15 min, such as a preset "zig" pattern.
    Phased Array Tracking
    We have already seen that a phased array radar system can electronically steer the beam. But the system can also perform a track-while-scan function. Since the planar array has many independent elements, they need not all be used to form a single beam. In fact, the great advantage of the phased array system is its flexibility. The SPY-1 phased array radar has over 4,000 elements, any number of which may be combined into a single beam. Suppose for instance, that the array was split into groups of 40 elements each. That would give about 100 independent beams. Granted the beamwidth of the 40 element array would not be as small as the 4000 element beam, but at shorter range could function more than adequately.
    In the phased array radar, some beams could be dedicated to search functions, while other could perform dedicated tracking functions. Therefore you have the search-while-track features, but with the added benefit of continuous contact on the targets. Essential to the SPY-1 capability is a computing system powerful enough to perform all of the necessary functions to control more than 100 independent tracking beams.
    Figure 13. Multiple beams
    of phased array radar.
    Tracking Networks
    It is a natural extension of the track-while-scan system to create a system which shares tracking information between users. All that is required is to transmit the *******s of the track file, since it contains all of the observations and the current solution. The sharing of tracking information has been incorporated extensively into modern combat. There are now global command and control networks that share this information between users all over the world.
    Tracking networks have adopted a standardized set of symbols for identifying types of targets. Some are shown below:
    Figure 14. Some standard
    tracking symbols.
    These symbols appear on the common operational picture displays now used for command and control functions.
    من مواضيع المهندس اون لاين :
    ذكرتك لأني نسيتك لمحة وأيسر مافي الذكرذكر لساني
    فكدت بلاوجد أموت من الهوى وهام على القلب بالخفقان
    فلما أراني الوجد أنك حاضري شهدتك موجودا بكل مكان
    فخاطبت موجودا بغير تكلم ولاحظت معلوما بغيرعيان
    wahwah68
    wahwah68 غير متواجد حالياً
    الصورة الرمزية wahwah68
    بارك الله فيك أخي الكريم ونسأل الله عز وجل أن يجعل ذلك في ميزان حسناتك
    آمـــــــــــــــــــــــــــــــــــــــــــين يارب العالمــــــــــــــــــــــــــــــــــــــــــــ ـــــيـن
    المهندس ثاني يوسفي
    المهندس ثاني يوسفي غير متواجد حالياً
    السلام مفتاح الكلام
    بترك الله فيكم
    دمتم في فضاء ترقية العلم و المعرفة
    المهندس عبد العزيز ثاني يو سفي- جزائري
    Eng. TANI YOUCEFI Abdelaziz
    Telecom Engineer
    King Fisal Street Industrial Area No.1
    P.O.Box 4499 Sharjah , United Arab Emirates
    Tel: [IMG]file:///D:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/msohtmlclip1/01/clip_image001.gif[/IMG][IMG]file:///D:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/msohtmlclip1/01/clip_image002.gif[/IMG][IMG]file:///D:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/msohtmlclip1/01/clip_image002.gif[/IMG][IMG]file:///D:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/msohtmlclip1/01/clip_image002.gif[/IMG][IMG]file:///D:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/msohtmlclip1/01/clip_image002.gif[/IMG][IMG]file:///D:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/msohtmlclip1/01/clip_image002.gif[/IMG][IMG]file:///D:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/msohtmlclip1/01/clip_image002.gif[/IMG][IMG]file:///D:/DOCUME%7E1/ADMINI%7E1/LOCALS%7E1/Temp/msohtmlclip1/01/clip_image002.gif[/IMG]+971501737210
    Email: [email protected]
    [email protected]
    CV –French
    http://www.doyoubuzz.com/abdelaziz-tani-youcefi
    faroo
    faroo غير متواجد حالياً
    Hello,
    Im currently working on a project for a tracking systems company, but as I majored in marketing and business administration, I have no idea what im working on,
    I read what was added in this page and I might need some help, if that was possible,
    Can you pleas3e provide me with some standard symbols for ( GPS/GSM/GPRS technology used to tracking vehicles on roads through a tracking device installed in the vehicle )
    Or maybe some more information about how this technology works.
    Thank you very much J
