Autodesk Robot Structural Analysis Professional 2010 Multilingual x86 DVD
النتائج 1 إلى 10 من 22
    الصورة الرمزية نايف علي
    نايف علي
    نايف علي غير متواجد حالياً
    عضو فائق التميز
    Received: 11
    Given: 10
    Autodesk Robot Structural Analysis Professional 2010 Multilingual x86 DVD / ~1.6 Gb
    Autodesk® Robot™ Structural Analysis Professional software offers powerful analysis with exceptional finite element auto-meshing capabilities, providing structural engineers with a faster means for tackling the most complex simulations and model calculations. Core features of Autodesk Robot Structural Analysis Professional include:
    * Seamless bidirectional links with Autodesk Revit Structure software
    * Advanced finite element auto-meshing capabilities
    * Wide range of analysis capabilities
    * State-of-the-art analysis solvers
    * Extensive output of analysis results
    * Multiple languages and units for global markets
    * Country-specific preferences and design codes
    * Integrated design solution for reinforced concrete and steel
    * Integrated workflow from structural analysis and design to fabrication drawings
    * Open and flexible API (application programming interface)
    Seamless Bidirectional Links with Autodesk Revit Structure
    Seamlessly import and export structural models between Autodesk® Robot™ Structural Analysis Professional software and Autodesk® Revit® Structure software with the Revit® Extensions for Autodesk Revit Structure analysis integration tool. Bidirectional linking enables analysis and design results to be updated throughout the building information model for more coordinated construction documentation.
    Advanced Finite Element Auto-meshing Capabilities
    Powerful mesh generation techniques enable a structural engineer to more effortlessly work with even the most complex models. Automatic mesh generation and manual definition of meshing parameters can be manipulated independently for each panel, providing the ability to create a high-quality finite element mesh for more precise analysis results.
    Wide Range of Analysis Capabilities
    Investigate the linear and true nonlinear behavior of any structure. The software allows the simple and effective analysis of many types of nonlinearity, such as P-delta analysis; tension/compression members; and supports, cables, and plastic hinges. Also explore the response of your structures to dynamic loading such as harmonic frequencies, seisms, and earthquakes.
    State-of-the-Art Analysis Solvers
    State-of-the-art fast dynamic solvers help ensure that structural dynamic analysis can be more easily carried out for any size of structure. The more efficient analysis algorithms of Autodesk Robot Structural Analysis Professional are designed and optimized for quad-core and multicore computer processors, giving structural engineers the calculation speed to deliver more accurate results for demanding structures in minutes versus hours.
    Extensive Output of Analysis Results
    Autodesk Robot Structural Analysis Professional provides flexibility in obtaining analysis results. Review results as visualizations and raw data in varying outputs, including:
    * Tabulated, which enables easy filtering and sorting
    * Diagrams on bars
    * Cuts through shells
    * Illustrated color maps
    * Stresses for the entire structure in a beam or column
    * Illustrated stresses in a selected direction shown for solids and shells
    Documents can be presented in Microsoft® Word® format or as an HTML document. Table *******s can be saved to a Microsoft® Excel® format file.
    Multiple Languages and Units for Global Markets
    Autodesk Robot Structural Analysis Professional supports multinational design teams using many languages, including English, French, Romanian, Spanish, Dutch, Russian, Polish, Chinese, and Japanese. Structural analysis can be performed in one language and output in another, and Imperial and metric units can be used in combination within the same structural model.
    Country-Specific Preferences and Design Codes
    Autodesk Robot Structural Analysis Professional includes more than 60 sections and materials databases from around the world. With an array of 70 built-in design codes, structural engineers can work with country-specific section shapes, Imperial or metric units, and country-specific building codes within the same integrated model.
    Integrated Design Solution for Reinforced Concrete and Steel
    Autodesk Robot Structural Analysis Professional contains integrated reinforced concrete design and steel design modules based on more than 40 international steel codes and 30 reinforced concrete codes, helping to simplify the design process and assist with the selection, verification, and optimization of structural elements.
    Integrated Workflow from Structural Analysis and Design to Fabrication Drawings
    Create structural models and perform structural analysis and design within Autodesk Robot Structural Analysis Professional and seamlessly transfer the model and results to AutoCAD® Structural Detailing software to generate fabrication drawings. Within this ecosystem of structural engineering software, the structural engineer can take advantage of an integrated workflow from design, through analysis, to fabrication.
    Open and Flexible API
    Autodesk Robot Structural Analysis Professional uses Microsoft COM (Component Object Model) technologies, enabling an open and flexible API (application programming interface). Possible uses include:
    * Linking Autodesk Robot Structural Analysis Professional with external programs, such as Microsoft® Excel, Microsoft® Word, and AutoCAD® software.
    * Extracting results from Autodesk Robot Structural Analysis Professional
    * Writing post-processing software, such as special codified analysis for steel, concrete, timber, and aluminum
    * Creating parametric structures in Autodesk Robot Structural Analysis Professional
    Download:
    http://rapidshare.com/files/23022526...com.part01.rar
    http://rapidshare.com/files/23022480...com.part02.rar
    http://rapidshare.com/files/23022464...com.part03.rar
    http://rapidshare.com/files/23022528...com.part04.rar
    http://rapidshare.com/files/23022483...com.part05.rar
    http://rapidshare.com/files/23022535...com.part06.rar
    http://rapidshare.com/files/23022519...com.part07.rar
    http://rapidshare.com/files/23022473...com.part08.rar
    http://rapidshare.com/files/23022524...com.part09.rar
    http://rapidshare.com/files/23022552...com.part10.rar
    http://rapidshare.com/files/23022538...com.part11.rar
    http://rapidshare.com/files/23022546...com.part12.rar
    http://rapidshare.com/files/23022481...com.part13.rar
    http://rapidshare.com/files/23022519...com.part14.rar
    http://rapidshare.com/files/23022529...com.part15.rar
    http://rapidshare.com/files/23022529...com.part16.rar
    http://rapidshare.com/files/23022450...com.part17.rar
    http://up-file.com/download/3f697a8e...b2286cd9d5c5e7
    http://up-file.com/download/7cbb5390...ace804fd32f686
    http://up-file.com/download/3da46328...6a1a7233afc69c
    http://up-file.com/download/7c7a6ef7...f850937d9740d8
    http://up-file.com/download/9788d968...f6242490e03725
    http://up-file.com/download/7bea3c62...ddcc6deb0461ed
    http://up-file.com/download/084d426a...71df3230815682
    http://up-file.com/download/8f575f63...7b73027d1afd14
    http://up-file.com/download/1ddd7f91...3cad7c1845950f
    http://up-file.com/download/5d2b8d77...524984c8c3c46b
    http://up-file.com/download/3c0977f0...f39156ab9afeb3
    http://up-file.com/download/1094289f...7feef803464756
    http://up-file.com/download/12e62177...a76af557bfe33b
    http://up-file.com/download/0941c326...bd40f2993d31e7
    http://up-file.com/download/45b34468...959d3a4e1d315f
    http://up-file.com/download/265f780a...d0dfa013051c9d
    http://up-file.com/download/22114ecd...4f82791a6db4b6
    http://hotfile.com/dl/8190895/2a49b3...art01.rar.html
    http://hotfile.com/dl/8190952/b55e29...art02.rar.html
    http://hotfile.com/dl/8190967/93c0b8...art03.rar.html
    http://hotfile.com/dl/8190987/b774a8...art04.rar.html
    http://hotfile.com/dl/8191013/added3...art05.rar.html
    http://hotfile.com/dl/8191057/56b071...art06.rar.html
    http://hotfile.com/dl/8193500/754af8...art07.rar.html
    http://hotfile.com/dl/8193545/f6b3b5...art08.rar.html
    http://hotfile.com/dl/8193579/e32e91...art09.rar.html
    http://hotfile.com/dl/8193642/a9c41e...art10.rar.html
    http://hotfile.com/dl/8193857/99cc33...art11.rar.html
    http://hotfile.com/dl/8193884/5d8a9b...art12.rar.html
    http://hotfile.com/dl/8194237/959012...art13.rar.html
    http://hotfile.com/dl/8194258/98f735...art14.rar.html
    http://hotfile.com/dl/8194282/002999...art15.rar.html
    http://hotfile.com/dl/8194319/dd0c5a...art16.rar.html
    http://hotfile.com/dl/8194344/73b586...art17.rar.html
    keygen
    http://rapidshare.com/files/223105896/RaK-x-force.rar
    مصيلحى
    مصيلحى غير متواجد حالياً
    Received: 11
    Given: 8
    يا أخي تم جميلك...........يعني يعقل الواحد ينزل مئات الميجا بايت من الروابط اللي غير الرايبد شير الممنوع أساساً ومحجوب هنا في الإمارات.....ويجي علي ملف الكراك أو الكيجين........برضه ملهوش حل أنه ينزلهمن الرابيد شير............يعني مش عارف أقووولك أيه؟؟؟؟ الله يهديك ويهدينا
    نايف علي
    عضو فائق التميز
    Received: 11
    Given: 10
    اقتباس المشاركة الأصلية كتبت بواسطة مصيلحى مشاهدة المشاركة
    أعصابك ياعمي :d
    أهوه يابشا
    دنا رفعته على الملتقى
    ماتعصبش تاني
    إذا اعتاد الفتى خوض المنايا ::: فأهون مايمر به الوحول
    علي الوهبي
    علي الوهبي غير متواجد حالياً
    الأخ نايف أمل المساعدة تم تحميل البرنامج وإدخال (serial number&key genrator) واكمل البرنامج وتم تنزيل البرنامج كاملا وظهرت صورة البرنامج على سطح المكتب وعند تشغيل البرنامج بالضغط على الصورة لا يفتح البرنامج وشكرا على مجهودك الطيب.
    moh'd_kamel
    moh'd_kamel غير متواجد حالياً
    شكرا كتير وجزاكم الله عنا خيرا
    م.صهيب
    م.صهيب غير متواجد حالياً
    السلم عليكم
    يأخ نايف انا نزلت البرنامج ومش رايد يفتح بالله عليك فيدني ................
    nizar_mahameed
    nizar_mahameed غير متواجد حالياً
    مشكور جدا . لكن البرنامج لا يعمل . لا مع xp ولا vista
    الأستشاري\ابراهيم
    الأستشاري\ابراهيم غير متواجد حالياً
    Received: 144
    ا
    رجو اعادة تحميل الجزء 16 للاهمية انا تعب خالص من تحميل الجزء دا ارجوكم الجزء 16
    توفى الى رحمة الله تعالى أخينا المهندس ابراهيم - وقد قدم لنا الكثير والكثير من العلم النافع لمساعدة اخوته الأعضاء بالملتقى
    نسألكم قراءة الفاتحة له والدعاء له بالرحمة والمغفرة وأن يسكنه الله فسيح جناته
    وأن يتقبل ما قدمه صدقة جارية خالصة لله تعالى
    اللهم آمين
    rahmeh
    rahmeh غير متواجد حالياً
    الى الأخ العزيز
    شكرا على البرنامج اولاً ولكن البرنامج لا يعمل
    يتم تحميل البرنامج وتنزيله على الجهاز بشكل طبيعي
    ولكن عند الضغط على الايقونة على سطح البرنامج فان لا يشيء يظهر "فقط يظهر شعار البرنامج وكأنه سيعمل انتظر لفترة طويلة ولا يظهر شيء"
    استعملت برنامج magicDisc لعمل سواقة وهمية
    أرجو الافادة وشكراً
    rahmeh
    يعني فعلاً انا ندمان على تحميل اكتر من واحد ونص جيجا على الفاضي
    على الأقل يا اخي ابعتلني احكيلني انه الملف مضروب أو اي شي مش تحط المشاركة وتسكت
    استغرق التحميل معي اكتر من 3 ايام على شي فاضي
    الرجاء من الأخوة عدم تحميل الملفات لأنها مضروبة ولا تعمل عند تنزيل البرنامج وانا متأكد من هذا الكلام 100%
    الرجاء البحث عن موقع اخر او مشاركة صادقة اخرى
