Weldig اللحام من الالف
صفحة 38 من 91 الأولىالأولى ... 2834 35 36 37 3839 40 41 42 4888 ... الأخيرةالأخيرة
النتائج 371 إلى 380 من 902
  1. [371]
    weldit
    weldit غير متواجد حالياً
    Received: 42
    Processes
    Generally, brazing processes are specified according to heating methods (sources) of industrial significance. Whatever the process used, the filler metal has a melting point above 840°F (450°C) but below the base metal and distributed in the joint by capillary attraction. The most common brazing processes are
    (a) Torch brazing
    (b) Furnace brazing
    (c) Induction brazing
    (d) Resistance brazing
    (e) Dip brazing
    (f) Infrared brazing
    SOLDERING (Same as Brazing but the difference is in the amount of heat applied and the type of filler wire used)
    Definition
    A group of welding processes which produce coalescence of materials by heating them to suitable temperature and by using a filler metal having a liquidus not exceeding 450 °C (842 °F) and below the solidus of the base materials. The filler metal is distributed between the closely fitted surfaces of the joint by capillary action
    The most common Soldering processes are Iron, Torch, Furnace, Induction, Resistance, Dip, Infrared and wave
  2. [372]
    weldit
    Received: 42
    وهذه محاضرة عن اشهر انواع اللحام
  3. [373]
    weldit
    Received: 42
    Resistance welding defects
    Cracks, porosity or cavities
    Electrode deposit on work, deep electrode indentation
    Improper weld penetration
    Surface appearance
    Weld size
    Irregular shaped welds
  4. [374]
    weldit
    Received: 42
    اقتباس المشاركة الأصلية كتبت بواسطة العشق الالهي مشاهدة المشاركة
    شكرا جزيلا على المعلومات القيمة لكني كنت اريد موضوع معين ولم اراه عندكم وهو ما هي معنى الارقام الموجودة على سلك اللحام بالتفصيل رجاءا وشكرا
    Prefix R: Indicates a welding rod
    Prefix E: Indicates a welding electrode
    Prefix RB: Indicates use as either a welding rod or for brazing filler metal
    Prefix ER: Indicates either an electrode or welding rod
    The system for identifying bare carbon steel electrodes and rods for gas shielded arc welding is as follows
    ER: Prefix indicates an electrode or welding rod
    70: Indicates the required minimum as-welded tensile strength in thousands of pounds per square inch (psi)
    S: Indicates solid electrode or rod
    C: Indicates composite metal cored or stranded electrode or rod
    1: Suffix number indicates a particular analysis and usability factor
    The system for identifying solid bare carbon steel for submerged arc is as follows
    The prefix letter E is used to indicate an electrode
    This is followed by a letter, which indicates the level of manganese, i.e., L for low, M for medium, and H for high manganese.
    This is followed by a number, which is the average amount of carbon in points or hundredths of a percent
    Flux-cored or tubular electrodes
    Example for mild steel
    E: Prefix indicates an electrode
    70: Indicates the required minimum as-welded tensile strength in thousands of pounds per square inch (psi).
    T: Indicates tubular, fabricated, or flux-cored electrode
    1: Suffix number indicates the chemistry of the deposited weld metal, gas type, and usability factor
    Shilded Metal Arc Welding
    E-7018
    1: In which position should the electrode be used
    1 for all positions
    2 for flat and horizontal positions
    3 only in the flat positions
    4 all psitions and vertical-down
    last digit 8 from 0-8 indicates the welding characteristics such as type of current, type of flux etc
  5. [375]
    weldit
    Received: 42
    اقتباس المشاركة الأصلية كتبت بواسطة ghasan12 مشاهدة المشاركة
    الأخ Weldit شكراً للمعلومات القيمة التي تطرحها بخصوص اللحام
    أرجو منك إن أمكن أن ترشدني إلى الكود الأمريكي ASME الخاص بقبول ورفض اللحامات /التحقق من جودة اللحام/
    ASME Section 9
    Boiler & Pressure Vessel Code
    ASME Section 2
    Welding and Brazing Qualification
    and more
    check this
    http://store.asme.org/category.asp?c...Vessels&Page=1
  6. [376]
    ghasan12
    ghasan12 غير متواجد حالياً
    شكرأ لك يا أخي weldit لإرشادي إلى هذا الموقع ..
    ولكن هل بإمكانك أن ترفق لي هذه المواصفات ..
  7. [377]
    يقظان القيسي
    يقظان القيسي غير متواجد حالياً
    شكرا جزيلا اخي الكريم و بارك الله فيك
    اخوك
    يقظان القيسي
    العراق
  8. [378]
    خبير.ص
    خبير.ص غير متواجد حالياً
    الى اخي weldit و اخي ghasan12
    إرشادك له الى الموقع جيد لكنه غير مجاني , فإن اردت ادلك على موقع اكثر من رائع تجد فيه ASME welding
    و هو مجــــــــــــــــــــــــــــــــــــــــــــــــ ــــــــــــــــــــانى ي ي ي ي ي ي ي
  9. [379]
    ghasan12
    الأخ نوار ..
    نعم أريد أن تدلني على موقع مجاني
    وشكراً
  10. [380]
    خبير.ص
