السقالة الخشبية
النتائج 1 إلى 3 من 3
    رامي ياسين
    رامي ياسين غير متواجد حالياً
    السقالة الخشبية
    الرجاء المساعدة في تصميم السقالة الخشبية وحساباته كاملة وشكرا
    هلوتس
    هلوتس غير متواجد حالياً
    Design calculations:
    1- design of decking
    Weights:
    O.W = 900 * 0.025 = 22.5 kg/m²
    Weight of concrete = 25*25 = 625 kg/m²
    Live loads ( ready mix with concrete pump) = 240 kg/m²
    Total dead loads = 647.5 = 650 kg/m²
    Live loads = 240 kg/m²
    Total loads in sq. meter = 890 kg/m²
    Moments = WS²/ 10
    = 890 * .4 ²/10 = 14.24 kg.m
    Max. shear force = .6 w s = .6*890*.4 = 213.6 kg
    F1,2 max. stresses on outer fiber = M/I*Y = M/S where S = I/Y
    ,S =bh³/ (12*h/2) = bh²/ 6 = 100*2.5²/6 = 104 cm³
    F max. = 14.24 * 10 ² /104 = 13.69kg/cm² O.K
    Qmax. = 1.5 Q/A = 1.5*213.6 / (100*2.5) =1.28 kg/cm² O.K
    2 – design of joists :
    Weights:
    O.W = 900 * 0.025 = 2.25 kg/m´
    Weight of decking = 1.10*650*.40 = 286 kg/m´
    ( ready mix with concrete pump) = 1.10*240*.40 = 105.6 kg/m´
    Total loads = 393 kg/m´
    Mmax = Wl²/10
    =393* .7²/10 = 19.3kg.m
    Max. shear force = .6 w s = .6*393*.7 = 165kg
    F1,2 max. stresses = M/I*Y = M/S where S = I/Y
    ,S =bh³/ (12*h/2) = bh²/ 6 = 100*2.5²/6 =41.6 cm³
    F max. = 19.3 * 10 ² /41.6= 46.4 kg/cm² O.K
    Qmax. = 1.5 Q/A = 1.5*165 / (12.5*2.5) =7.92kg/cm² taken 1"*5"
    3- Design of wailing:
    Weights:
    O.W = 900 * 0.025 *.2 = 4.5 kg/m`
    Loads = Rj = 1.10 *393 *.7 = 302 kg
    Mmax = 45 kg.m
    Max. shear force = 302 kg
    ,S =bh³/ (12*h/2) = bh²/ 6 = 20²*2.5/6 = 166.6 cm³
    F max. = 45 * 10 ² /166.66= 27 kg/cm² O.K
    Qmax. = 1.5 Q/A = 1.5*302 / (25 *2.5) =7.25kg/cm² O.K
    Design of prob:
    load on prob :
    Pp = 1.15 (2Rj + Ww*Lw)
    = 1.15 (2*302 + 4.5*.7 ) = 699 kg
    Fpb = 70 (1- Lb/80 bp) Lb = 185 cm
    Fpb = 70 (1-185/(80*7.5)) = 48.4 kg/cm²
    Area required = 699 /48.4 = 14.4 cm²
    3"*3" prob is sufficient @ 700 mm in two direction O.k
    رامي ياسين
    شكرا جزيلا يا طيب والله يجزيك الخير
