Product of performance
النتائج 1 إلى 2 من 2
    eyadamk
    eyadamk غير متواجد حالياً
    Received: 9
    The Product of Your Performance
    Your personal productivity cannot be measured simply by what you are
    doing.
    If what you are doing is not getting you to where you want to go
    your time is not being spent productively.
    Rather, personal productivity is measured by what is produced from that performance, the product of
    your performance.
    For example, I work with a laptop. I write articles, develop
    spreadsheets and update my database about as fast and efficiently as
    anyone I know. During the first six months I owned the laptop I loaded
    it with an incredible amount of data, pounding away at the keyboard
    like it was a fine piano. On a scale of one to ten, I would initially rate
    my personal productivity with respect to this task, as a nine or a ten. I
    was a super achiever.
    Well, except for one small detail. I did not back up my work. I don’t
    why I neglected this task because I have always backed up my work. The
    hard drive on the laptop crashed, burned and died and I lost everything
    I had put into it for six months.
    Now, what was my productivity on a scale of 1-10? Zero. Nothing. See my
    performance was a nine or a ten but neglecting to do a key step,
    backing
    up the work, resulted in the product of my performance being a zero, as
    if I had not done it at all.
    If you are working at a job that is not fulfilling for you, you are
    doing it because of the paycheck only, then you are not operating at a
    high level of personal productivity. 80% of those who go to work on
    Monday morning would rather be somewhere else. You are a cog that makes
    money. You may be able do that dreaded job quicker, faster and better
    than anyone else but if it’s a job that doesn’t excite you and fulfill
    you, you’re not at a high level of personal productivity.
    If you are on a path where your marriage may end in divorce, (and 50%
    of all marriages end up in divorce), through which you may have to give up
    a significant percentage of everything you have ever worked for in your
    adult life, you are not being very productive. Making all that money
    over the years only to give much of it away to a person you have
    learned to hate is not an example of high personal productivity. The
    performance was making all that money in the first place. But the product of the
    performance was to create a property settlement fund in your divorce.
    Examine everything you are doing. Is it getting you to where you want
    to go in your life? Is your performance creating the product you want to
    achieve? If not, fix it. Change your performance to deliver the right
    product to you and truly operate at high productivity levels.
    Want to get better focus and increase your productivity now? You can
    easily get more of the important things done, in less time, with less
    stress.
    amuhanna
    amuhanna غير متواجد حالياً
    شكرا على هذا الموضوع المفيد
    اخوك
    ابو عبد الله
    غزة فلسطين
