PMHUB-G Errata in PMBOK 4th edition - IMPORTANT
النتائج 1 إلى 1 من 1
    الصورة الرمزية شريف مصطفى إبراهيم
    شريف مصطفى إبراهيم
    شريف مصطفى إبراهيم غير متواجد حالياً
    Received: 59
    Given: 25
    الإخوة الزملاء الأعزاء
    جاءتني هذه الرسالة عبر البريد الإليكتروني:
    Many still are NOT aware ... so excuse me for resending
    For those studying for the exam, it is critical that you know what the printing errors are.
    Firstly you need to know your print run.
    This is how to determine your print run:
    “In order to determine the print run of your book, refer to the bottom of the copyright page (which precedes the Notice page and Table of C o n t e n t s). You will see a descending numerical string of numbers beginning with 10. The first printing of the PMBOK® Guide will show the numerals 10 through 1. With each subsequent print run, the lowest numeral is removed from the string. Therefore, if your copy of the PMBOK® Guide has all 10 numerals, you have the first printing and you will need the errata sheet.
    10 9 8 7 6 5 4 3 2 1 (need the errata sheet)
    10 9 8 7 6 5 4 3 2 (do not need the errata sheet)”
    The list of ERRATA is here: http://linkbee.com/BOKerrors
    الملف بالمرفقات
    والله الموفق
