How Steel is Made
النتائج 1 إلى 2 من 2
    الصورة الرمزية احمد عباس الخطيب
    احمد عباس الخطيب
    احمد عباس الخطيب غير متواجد حالياً
    How Steel is Made
    How Steel is Made
    There are fourteen manufacturing committees, each dealing with a step in the steelmaking process, e.g., Coke Oven Practice, Hot Strip Mills and Ironmaking. The chairmanship is on a rotating basis among the members of the committees and is for a duration of two years. These committees meet 2-3 times in a year to discuss areas of common interest including: technical and operating issues, safety, environmental, and benchmarking. The members as well as suppliers and customers present new developments and technologies.
    The meeting agendas are worked out in advance and are published as Work Plans. Similarly, the location and dates of the meeting are published as Meeting Calendar. Occasionally, joint meetings of committees as well as meetings with groups of European steel industry representatives are held.
    Steel Processing Operations
    Coal Utilization in the Steel Industry
    Coke Production For Blast Furnace Ironmaking
    Continuous Casting of Steel: Basic Principles
    Electric Arc Furnace Steelmaking
    Electric Arc Furnace Steelmaking (cont.)
    How A Blast Furnace Works
    Iron Ore Processing for the Blast Furnace
    The following describes operations at the National Steel Pellet Company, an iron ore mining and processing facility located on the Mesabi Iron Range of Minnesota.
    Secondary Refining
    For purposes of this article, secondary Refining or Secondary Metallurgy is defined as any post steelmaking process performed at a separate station prior to casting and hot metal desulfurizaion.
    Steelmaking Quicklinks
    The Basic Oxygen Steelmaking (BOS) Process
    The Coke Oven By-Product Plant
    mecoengineer
    mecoengineer غير متواجد حالياً
    اخي الفاضل ممكن تحمل كتب تشرح بتفصيل المعادلات الكيميائية ل صناعة الحديد
    ونشكركم ................
