قرأءة الجدول الزمني
النتائج 1 إلى 10 من 15
    خالد بوزهرة
    خالد بوزهرة غير متواجد حالياً
    قرأءة الجدول الزمني
    الأخ حازم و جميع الاخوة المختصون كأستشاري عندما يقدم لي جدول زمني كيف يمكن قرأة هذا الجدول المنجز بواسطة p3 بأختصار كيف اعرف هذا الجدول جيد او لا او ما هي عيوب الجدول الزمني و ما هي مزاياه التي تمكنني من الموافقة عليه
    mohamedsaid78
    mohamedsaid78 غير متواجد حالياً
    Dear Khaled
    Follow the following steps to analyis any Program of works
    A.Check in the program if there any relations is SF(Start to finish)this a wrong relation ,because in the real practise there isn't any use of that relation
    B.Check for -ve Lags (it is not prefered to use -ve lags,it is a sign of bad planning)
    C.Check for Constrains(using unnecassary constrians is also a sign of bad planning)most of the acceptable constrains are early finish constrains which is only used at partial finishing milestones point
    D.The total float for the activities shouldn't exceed 10%of the project total duration for any activity,(i prefer that the total float is less than 120 days for the long projects exceeding 2 years duration & around 60-90 days for the projects less than 2 years)
    E.u must review the relations between the construction activites,and make sure it is following the comman engineering procedures
    F.for the Submittals predessores if it related to the starting point of the project don't accept more than 90 days as lag(ex.:Tiles Sample Submittals has FS relation with moblization 150 days ,this in my point of view is irrelivant informations cuz if u face any problem with moblization so the activity hasn't any finish date so when u start ur updating it will always showing delays for the project finish date due to that, but in reality there isn't such a thing)
    G. u must make sure that the duration for the different activities is suitable not to much or very less(by knowing the Quantity of the activity and the manpower loaded to achieve it & and also compar it with the productivity rates u have)
    h. don't allow to use lags over 60 days without any good reasons
    خالد بوزهرة
    شكرا لك اخي محمد سعيد و بارك الله فيك و جعلها في ميزان حسناتك و اعتقد ان هذا ما كنت ابحث عنه و لكن لدي استفسار بسيط علي اي أساس بنيت هذة الثوابت في الارقام و لك الشكر الجزيل مرة اخرى
    خالد بوزهرة
    نسبة critical activities
    الاخ محمود السيد
    هل ممكن لنا ان نسأل ما هي نسبة الانشطة الحرجة المسموح بها في كل جدول زمني الي عدد الانشطة الكلي و لك الشكر مجددا
    مهندس مصطفى
    مهندس مصطفى غير متواجد حالياً
    الصورة الرمزية مهندس مصطفى
    Received: 9
    الأخ المهندس محمد سعيد أعتقد أن هذا سهو منك أن تقول أن إستخدام negative Lag خطا لماذا خطااااا negative Lag = overlap وهو من أهم الأمور المعروفة فى العلاقات المنطقية بين الأنشطة ما هو الخطا مثلا فى ان اقول اننى سابدا باعمال الردم لاساسات سور قبل خمسة ايام من انتهاء اعمال الاساسات ؟؟؟
    و أعتقد أنه ضرورى جداااا إستخدامه مثلا فى أن أعمل تداخل لمدة يوم عند ربط المعالجة بصب الخرسانة حيث ان السبعة ايام معالجة محسوب ضمنها يوم الصب فقل لى كيف ستحقق ذلك بدون عمل تداخل؟؟
    من الممكن ان يكون قصدك negative total float نعم هذا هو الجريمة بعينها
    و الله ولى التوفيق
    anwerbasha
    anwerbasha غير متواجد حالياً
    الصورة الرمزية anwerbasha
    Given: 6
    اقتباس المشاركة الأصلية كتبت بواسطة مهندس مصطفى مشاهدة المشاركة
    الأخ المهندس محمد سعيد أعتقد أن هذا سهو منك أن تقول أن إستخدام negative lag خطا لماذا خطااااا negative lag = overlap وهو من أهم الأمور المعروفة فى العلاقات المنطقية بين الأنشطة ما هو الخطا مثلا فى ان اقول اننى سابدا باعمال الردم لاساسات سور قبل خمسة ايام من انتهاء اعمال الاساسات ؟؟؟
    و الله ولى التوفيق
    كلام منطقي و لكن قد يكون قصدة انها غير محبذة في اغلب الاحيان
    Engr./M O H A M E D
    مهندس مصطفى
    Received: 9
    لا طبعا هذا امر ليس فيه تحبيذ او عدم تحبيذ
    الاربعة انواع من العلاقات المنطقية بين الانشطة بالاضافة الى overlap & lag بمثابة الحروف الابجدية بالنسبة للغة العربية او اى لغة
    هل من الممكن ان نقول ان حرف النون غير محبذ استخدامه فى اللغة العربية؟
    والله ولى التوفيق
    mohamedsaid78
    و الله ولى التوفيق
    السلامعليكم ,اخىالعزيزمهندسمصطفى
    ساشرح لك لماذا قلت ان
    اولا انا لم اقل ان ذلك خطأ ,ان قلت انه دليل على ضعف فى التخطيط
    مثال : سابدا باعمال الردم لاساسات سور قبل خمسة ايام من انتهاء اعمال الاساسات
    العلاقة هنا علاقة غير سليمه تطبيقيا , اى من ناحية العمل بالموقع , لان العلاقة هنا اغفلت انه لتمام اكتمال الردم يجب ان يتم اكتمال الاساسات,بمعنى ابسط فى تلك الحاله بعد بداية الردم اذا توقف العمل بالاساسات ولم تكتمل الاساسات لاى سبب ,ستجد ان الاساسات و الردم سينتهينا تقريبا فى نفس الوقت ,و هوا منطقيا لا يحدث ,لذلك فان استخدام Negative lags ضعيف تخطيطيا ,و يفضل فى تلك الحاله استخدام العلاقات التاليه
    SS with lag +FF with Lag
    فتلك العلاقة المزدوجه تحافظ دائما على التسلسل المنطقى للانشطه
    mohamedsaid78
    والله ولى التوفيق
    السلام عليكم ,اخى العزيز مهندس مصطفى
    رياضيا العلاقات الاربعه صحيحة ,لكن عمليا لا وجود اى استخدام منطقى لعلاقة sf فى الواقع,لتوضيح معنى علاقة sf
    (a sf b)انه النشاط b سينتهى عندما يبداالشاط a ,فتلك العلاقة منطقيا غير مقبولة لكنها صحيحة رياضيا,و العلاقة المنطقية هى (b fs a ) اى ان النشاط a سيبدأ بعد انتهاء النشاط b
    مهندس مصطفى
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة mohamedsaid78 مشاهدة المشاركة
    العلاقة هنا علاقة غير سليمه تطبيقيا , اى من ناحية العمل بالموقع , لان العلاقة هنا اغفلت انه لتمام اكتمال الردم يجب ان يتم اكتمال الاساسات,بمعنى ابسط فى تلك الحاله بعد بداية الردم اذا توقف العمل بالاساسات ولم تكتمل الاساسات لاى سبب ,ستجد ان الاساسات و الردم سينتهينا تقريبا فى نفس الوقت ,و هوا منطقيا لا يحدث ,لذلك فان استخدام negative lags ضعيف تخطيطيا ,و يفضل فى تلك الحاله استخدام العلاقات التاليه
    ss with lag +ff with lag
    جزاك الله خيرا
    كده اكتملت وجهة نظرك
