محرك دائم الحركة فى احد المعارض الدولية = يعمل بالجاذبية الارضية والماء
صفحة 5 من 5 الأولىالأولى 1 2 3 4 5
النتائج 41 إلى 44 من 44
  1. [41]
    fagrelsabah
    fagrelsabah غير متواجد حالياً
    عضو متميز جداً
    Received: 10
    Thumbs up محرك دائم الحركة
    مع اختراع العالم لينديمان المولد الكهربي الذى يغذي نفسه بالكهرباء ويخؤج فائض
    In the DVD presentation "Electric Motor Secrets", a no Back EMF, Magnetic Attraction Motor, with high torque and high electrical recovery is discussed. Near the end of the presentation, a rotor design called the "S" rotor is shown. In lab tests conducted after the film was finished, it was determined that the "S" rotor is more difficult to fabricate and does not perform better than a simpler design. This design consists of a simple cast iron rotor in the form of two cross bars. I call it the "X" rotor, and the configuration is shown below.
    The basic motor configuration is as follows. The stator pole faces describe 30 degrees of arc. Each rotor cross bar face also describes 30 degrees of arc. There are four power strokes per revolution of the shaft. A power stroke begins when one of the cross bars is in the position shown in the illustration.
    The commutator turns the power coil ON for 15 degrees of rotation, and then turns the power OFF. The power then remains OFF for 75 degrees of rotation. This cycle repeats every 90 degrees of rotation.
    So, the power ON phase draws the cross bar 1/2 of the way into alignment with the stator pole faces. The power coil then turns OFF and discharges its magnetic field during the second half of the way into alignment. By the time full alignment is made, the magnetic field is gone and the iron bar section of the rotor rotates out of alignment with no resistance.
    الصور المرفقة LRAMdiagram4.JPG‏ (330.9 كيلوبايت, المشاهدات 93)
    Free energy in minutes step by step
    http://www.youtube.com/watch?v=QMQqnaWUA98
    الرابط للموضوع هنا
    http://www.arab-eng.org/vb/t147418.html
    الحمد لله الذى جعل فى الماء اسرار الحياة
    سيارة تعمل بالماء بدلا من البنزين - اسرار و خفايا تكشف لاول مرة
    ‏http://www.arab-eng.org/vb/t137893.htm
    l
  2. [42]
    fagrelsabah
    عضو متميز جداً
    Received: 10
    حسبي الله ونعم الوكيل في كل مضلل كذاب يقول لكم لاتجربوا تلك المحركات ولاتدرسوها
    فديو نادر جدا عن الطاقة الحرة
    والمحرك الذى يولد كهرباء اكثر مما يستهلك
    Bob Teal | Magnipulsion| Missing Interview
    http://www.youtube.com/watch?v=aj7oD8JG5xU
    l
  3. [43]
    fagrelsabah
    عضو متميز جداً
    Received: 10
    شرح من خبير روسي لنظرية التنافر للمغانط ومبداء عمل المحركات
    الصور المرفقة وقود الماء 46.jpg‏ (15.3 كيلوبايت, المشاهدات 71) وقود الماء 45.jpg‏ (18.8 كيلوبايت, المشاهدات 0)
    l
  4. [44]
    fagrelsabah
    عضو متميز جداً
    Received: 10
    اليكم المزيد من المحركات بالادله لها - فأين ادلة المكذبين الذين يريدون التخلف والجهل
    واليكم المزيد
    فاين ادلتكم اللتى تويد كذبكم
    لاتوجد لان الكذب لا ادله له
    فحسبي الله ونعم الوكيل في كل من كتم تلك العلوم وعمل على منع نشرها وهو يعلم تماما انها صالحة ولكن خبث نفسه وحقده على العرب يجعله يمضى وقته في التكذيب بدون ادلة لان قلبه قد امتلئ حقدا وحسدا على انتشار تلك العلوم الى المسلمين
    فلا يملك الا كلمة لاتجربوها وهو يبكى لانه يعلم ان تم تجربتها فسنكتشف الخدعه الكبري
    1--
    15000 فولت من الماء مصدر جديد للكهرباء من اكتشاف د Walter Lewin
    http://www.arab-eng.org/vb/t152272.html
    2-----
    Kapanadze 100 KWكهرباء مجانا استطاع المهندسين الاتراك تطوير جهاز استقبال الكهرباء
    http://www.arab-eng.org/vb/t146541.html
    3 ---
    Rotary Attraction Motor كهرباء مجانا
    4----
    المحول الكهربائى المحمول الدكتور اسماعيل سيد احمد
    http://www.arab-eng.org/vb/t143758.html
    5--
    الرجل المعجزة - مهندس نجح فى استخدام الطاقة الحرة والمجانية والمتجدة لكل اغراض الحياة
    http://www.arab-eng.org/vb/t146969.html
    6-
    مخترع الاطباق الطائرة العالم John Searl و لماذا تم اخفاء اختراعاته؟
    http://www.arab-eng.org/vb/t146696.html
    7-------
    محرك دائم الحركة يعمل بالجاذبية الارضية والماء
    http://www.arab-eng.org/vb/t144583.html
    8--
    طرق جديدة للطاقة الشمسية للدول العربية من امكانيات محلية الصنع
    http://www.arab-eng.org/vb/t150794.html
    9-----
    دكتور الDr. Schwartz وتوليد الكهرباء بالمجان =وشرح جهازة للكهرباء الصامته السلام عليك
    http://www.arab-eng.org/vb/t151728.html
    10
    من شعر الرأس = كهرباءمجاناsolar panel
    http://www.arab-eng.org/vb/t153236.html
    11------
    تحويل الموجات إلى كهرباء
    http://www.arab-eng.org/vb/t119529.html
    12-----
    طاقة كهربية مجانا تصنيع محلى وسهل
    http://www.arab-eng.org/vb/t114743.html
    13-----
    انتاج الكهرباء باستخدم دراجة Bicycle Powered Generator
    http://www.arab-eng.org/vb/t154149.html
    14-----
    الطاقة البديلة
    http://www.arab-eng.org/vb/t154910.html
    15----
    محرك مغناطيسي سهل التصنيع ودائم الحركة Free Energy # 2 - Working Magnet Motor
    http://www.arab-eng.org/vb/t144763.html
    16---
    توليد الكهرباء من الرياح ارجو مساعدة ومناقشة الى د باشراحيل ‏(
    http://www.arab-eng.org/vb/t150437.html
    17--
    احصل على كهرباء مجانا وتعلم طريقة الصنع بنفسك
    http://www.arab-eng.org/vb/t117419.html
    18---
    كهرباء بالمجان طاقة كهربية جديدة من احد العلماء
    http://www.arab-eng.org/vb/t156337.html
    19----
    احصل على كهرباء مجانا 3000 Wattوتعلم طريقة الصنع بنفسك
    http://www.arab-eng.org/vb/t118058.html
    20---
    كل المطلوب : موتور يصنع منزلياً يعمل بتقنية طاقة الجاذبية الأرضية ‏(
    http://www.arab-eng.org/vb/t144174.html
    21----
    تصنيع مولد كهربائي يعتمد على البطارية 12 فولت وعاكس .
    http://www.arab-eng.org/vb/t99703.html
    22---
    اول عمل لي لصناعة مروحه لتوليد الطاقه الكهربائية
    http://www.arab-eng.org/vb/t156916.html
    23-----
    شرح كيف تحصل على مغانط نيديوم من القرص الصلب = الهارد ديسك
    http://www.arab-eng.org/vb/t156346.html
    24-----
    آلة ميكانيكية تنتج طاقة كهربائية على مدار اليوم وبتكلفة مجانية
    http://www.arab-eng.org/vb/t143445.html
    25-----
    الحركة الدئمة من المولد والمحرك (هل يمكن )
    http://www.arab-eng.org/vb/t97552.html
    26------
    آلة ميكانيكية تنتج طاقة بتكلفة مجانية
    27----
    شاب يخترع ألواح طاقة شمسية من الشعر
    http://www.arab-eng.org/vb/t158970.html
    28------
    المحرك دائم الحركة........بين الوهم و الحقيقة!
    http://www.arab-eng.org/vb/t37595.html
    29---
    الطاقة المتجددة مستقبلنا المجهول
    http://www.arab-eng.org/vb/t16941.html
    30----
    "شمسون" سيارة شمسية مصرية 100%
    http://www.arab-eng.org/vb/t159236.html
    31--
    الطاقة الحرة
    http://www.arab-eng.org/vb/t151054.html
    32---
    محطة كهربائية توفر الطاقة النظيفة
    http://www.arab-eng.org/vb/t159239.html
    33--
    استخدام طاقة الجاذبية الارضية كمصدر رخيص ودائم ونظيف للطاقة
    http://www.arab-eng.org/vb/t95395.html
    34---
    http://www.arab-eng.org/vb/t154779.html
    35----
    طاقة الرياح ... كتب ومواقع !!! Wind Power
    http://www.arab-eng.org/vb/t149668.html
    36---
    الالية الميكانيكية لتصميم العنفة الريحية.........وكل عام وانتم بخير
    http://www.arab-eng.org/vb/t103919.html
    37------
    تصميم تربينات الرياح- رسالة ماجستير
    http://www.arab-eng.org/vb/t156316.html
    38----
    إلى كل من لم تسنح له الفرصة , محرك كهربائي تلقائي الحركة؟؟؟؟
    http://www.arab-eng.org/vb/t40984.html
    39--
    جهاز لشحن الحاسب بالقدم ــ يحول الطاقة الميكانيكة إلى كهربائية
    http://www.arab-eng.org/vb/t122052.html
    40----
    اول دولة عربية تصنع عنفات ريحية
    http://www.arab-eng.org/vb/t137688.html
    41--
    طرق توليد الطاقة الكهربائية
    http://www.arab-eng.org/vb/t150278.html
    42------
    سوال
    http://www.arab-eng.org/vb/t157024.html
    مغناطيس مولد للكهرباء free energy coil للعالم Steven Mark solid state generator
    http://www.arab-eng.org/vb/t113609.html
    43--
    المرجو الاجابة عن هذه الأسئلة من فضلكم
    http://www.arab-eng.org/vb/t154964.html
    44--
    مروحة تعمل بدون كهرباء
    http://www.arab-eng.org/vb/t21813.html
    45-
    اصنع مولد كهربائي يعمل بالماء بنفسك
    http://www.arab-eng.org/vb/t48817.html
    كهرباء بالمجان مع المحرك العجيب ل Bruce DePalma
    http://www.arab-eng.org/vb/t144674.html
    المحرك المغناطيسي دائم الحركة وتجربة لشرح طريقة عملهperendev
    http://www.arab-eng.org/vb/t144668.html
    المحرك المغناطيسي وبعض اسرارة perendev motor princip
    http://www.arab-eng.org/vb/t144661.html
    http://www.arab-eng.org/vb/t144587.html
    المحرك الدائم الحرك الذى يعمل بالجاذبية الارضية للرد على المكذبين
    http://www.arab-eng.org/vb/t144581.html
    انتاج الكهرباء من حول ماسورة العادم للمحركات GEET coil
    http://www.arab-eng.org/vb/t144568.html
    ايها المحبطون نحن لكم بالمرصاد ....
    http://www.arab-eng.org/vb/t144206.html
    انتاج الكهرباء النظيفة بكلفة قليلة بواسطة تطوير لواقط شمسية
    http://www.arab-eng.org/vb/t94902.html
    توربينات هوائيه لتوليد طاقه كهربائيه
    http://www.arab-eng.org/vb/t152237.html
    آلة ميكانيكية تنتج طاقة كهربائية على مدار اليوم وبتكلفة مجانيةhttp://www.arab-
    eng.org/vb/t148610.html
    http://www.arab-eng.org/vb/t148610.html
    انشاءالمحرك المغناطيسي
    http://www.arab-eng.org/vb/t154292.html
    طريقة مبتكرة لتوليد الكهرباء من الصوت
    http://www.arab-eng.org/vb/t144413.html
    http://www.arab-eng.org/vb/t154761.html
    طاحونة هواء تضاعف من إنتاج الطاقة الكهربائية
    http://www.arab-eng.org/vb/t121990.html
    تصميم لمحطة تعمل على wind energy
    http://www.arab-eng.org/vb/t117352.html
    تخزين الكهرباء
    http://www.arab-eng.org/vb/t154773.html
    صوره متحركة تبين كيفية توليد الكهرباء من الرياح
    http://www.arab-eng.org/vb/t118827.html
    استخدام طاقة الرياح (هل هي ممكن بهذه الطريقة) ... ارجو المشاركة
    http://www.arab-eng.org/vb/t103307.html
    حساب الطاقة الكهربائية المولدة من طاقة الرياح
    http://www.arab-eng.org/vb/t104011.html
    كيف يمكننا الحصول على الكهرباء من الهواء نرجوا المشاركه
    http://www.arab-eng.org/vb/t101782.html
    المانى اخترع دراجة تسير بسرعة 80 كيلومتر ساعة بالطاقة الحرة
    http://www.arab-eng.org/vb/t145977.html
    الجاذبية الارضية لتوليد الطاقة
    http://www.arab-eng.org/vb/t50952.html
    محرك دائم الحركة باستخدام الماء
    http://www.arab-eng.org/vb/t68996.html
    Magnetic Motor
    http://www.arab-eng.org/vb/t113246.html
    شرح المحرك المغناطيسي الدائم
    http://www.arab-eng.org/vb/t89511.html
    عندي مجموعه من الأسئلة ؟؟؟؟؟؟؟؟؟؟؟؟مشرووع
    http://www.arab-eng.org/vb/t153946.html
    inverter العاكس من 12فولت الى 220 فولت
    http://www.arab-eng.org/vb/t25656.html
    استخراج الكهرباء من الماء الساكن
    http://www.arab-eng.org/vb/t145074.html
    موقع رائع جدا يعلمك صناعة pv panels , windmills
    http://www.arab-eng.org/vb/t150265.html
    من فلسطين السيارة الكهربية مشروع تخرج 2009 للمهندسين
    http://www.arab-eng.org/vb/t150018.html
    http://www.arab-eng.org/vb/t148609.html
    مولد كهرباء على الطاقة المغناطيسة
    http://www.arab-eng.org/vb/t146637.html
    رساله إلي المشككين فقط في الطاقه الحرة
    http://www.arab-eng.org/vb/t148441.html
    بطاريات يمكن طباعتها.. وصديقة للبيئة
    http://www.arab-eng.org/vb/t147204.html
    الطريق الى التقدم العلمى الدكتور اسماعيل سيد احمد
    http://www.arab-eng.org/vb/t149239.html
    طلب من المهندسين؟
    http://www.arab-eng.org/vb/t148073.html
    التعاون فيما بيننا حول المحرك دائم الحركة .بعض الملفات
    http://www.arab-eng.org/vb/t98069.html
    موقع فديو للطاقة البديلة والمجانية
    http://www.arab-eng.org/vb/t147511.html
    جارى التكملة والتعديل فى وقت لاحق بأذن الله تعالى
    l
