جميع الدوائر الالكتروتية ؟؟؟
النتائج 1 إلى 10 من 13
    الصورة الرمزية mohamedeko
    mohamedeko
    mohamedeko غير متواجد حالياً
    Morse Code Practice Keyer, I
    Morse Code Practice Keyer, II
    Motor Accu Lader (Dutch language)
    Motorcycle Battery Charger
    Motorcycle Brake Light Flasher
    Motorcycle Low Voltage Warning
    No-Hassle 3rd Brakelight hookup
    Power Supply Converted from a PC - by Andy Batts
    Practical, 2-wire Intercom
    Pulse Timer, 555
    Pulse Width modulator, 555
    Pulse Width modulator, 4093
    Radio Shack Special - Transmitters by Patrick Cambre
    Red Alert Alarm, #1
    Red Alert Alarm, #2
    Relays - Sound Activated, #1
    Relays - Sound Activated, #2
    Relays - Transistor Boosted
    Relays - Dark Activated
    Relays - Delayed Turn-on
    Relays - Automatic Turn-off
    Relays - Long Duration
    Relays - 12 Sec to 90 min
    Relays - Long Duration--1 to 100 min
    Relays - Long Duration--1 min to 20 hrs
    Relays - Self Latching
    RF Transmitter, light sensing
    RJ45 Cable Tester by Bruce Marcus
    Subcarrier Adapter Listen to those hidden FM transmissions
    ScanMate Your (Radio) scanner buddy-pcb available!
    Servo Modification - For contineous rotation
    Simplest R/C Circuit
    Simplest RF Transmitter
    Simple Transistor Audio PreAmplifier
    Single IC Audio Preamplifier
    Single Cell Sealed Lead Acid Charger - by Søren
    Solar Cell NiCad Charger
    Solid State Relay
    Telephone Transmitter (FM)
    Theremin
    Thermo Alarm
    Thermostat
    Third Brake Light Pulser
    Touch Activated Alarm System
    Touch Switch using Transistors
    Two-Tone Trainhorn
    Universal Flasher Circuit
    Variable Power Supply, 1 - 30V @ 1.5A
    Wailing Alarm
    Warble Alarm
    Whooper Alarm
    Water-level Sensing and Control
    Waterpump Safety Guard for Fish-pond
    Weller WLC100 Soldering Station
    Wireless Microphone
    Xmas Lights Tester
    Zap Adapter
    1.5V Tracking Transmitter (with Video Clip)
    2 Transistor 2 LED Flasher
    4 Transistor Tracking Transmitter
    4 Transistor Transmitter R8(1K) 3-03-2007
    7.2V Field Charger (.pdf file)
    8A Regulated Power Supply for 13.8V
    9-V Stabilized Powersupply
    9 to 9 pin (Female) Nullmodem Cable
    12V to 9V with a LM317
    30-Meter QRP Transmitter for Morse Code
    555 DC-AC Inverter
    555 Timer IC Tester
    555 Go No/Go Tester More advanced
    Electronic Symbols Template
    میثم0635417
    میثم0635417 غير متواجد حالياً
    اشکرک
    ولکن مع الاسف لم افهم شیئ لان لیس هناک ای خریطه للموضوع
    صخر العبسي
    صخر العبسي غير متواجد حالياً
    الصورة الرمزية صخر العبسي
    اريد تصميم دارة للتحكم عن بعد بالموجات fm (موجات الراديو)
    سيف مجاهد
    سيف مجاهد غير متواجد حالياً
    عضو متميز جداً
    الصورة الرمزية سيف مجاهد
    Received: 37
    اريد ان اعمل دائرة تحكم عن بعد
    واخذ اشارات
    فكيف لي ذلك
    وجزاكم الله خيرا
    ج عمر
    ج عمر غير متواجد حالياً
    الصورة الرمزية ج عمر
    لو سمحت .................................................. ...
    اين التحميل .................................................. .اسماء الدوائر فقط
    لو سمحت .................................................. ... الدوائر للتحميل
    محمد معن
    محمد معن غير متواجد حالياً
    very gooooooood job
    عبدالله الجنابي
    عبدالله الجنابي غير متواجد حالياً
    الصورة الرمزية عبدالله الجنابي
    مشكوريين اخي العزيز
    ee_ahmad
    ee_ahmad غير متواجد حالياً
    thanx
    عمران22
    عمران22 غير متواجد حالياً
    مشكوووووووووووووووووووووووور ياغالي
    عبد الرزاق الجبوري
    عبد الرزاق الجبوري غير متواجد حالياً
    السلام عليكم الاخ العزيز اين التحميل
