Autodesk Moldflow 2010
النتائج 1 إلى 7 من 7
    الصورة الرمزية أبوعبدالله
    أبوعبدالله
    أبوعبدالله غير متواجد حالياً
    Given: 9
    Set Autodesk Moldflow Products 2010 is designed for the simulation process and the plastic parts produced by injection and is a part of Autodesk solutions company for electronic prototyping.
    The increased accuracy of simulation and the improvement in the analysis of three-dimensional surfaces allow significantly improving the quality of finished plastic products. Integrated support package Autodesk Inventor for the design of mechanical systems, as well as models from other CAD design ensures the full integration of Autodesk Moldflow 2010 with the processes of designing and preparing for production. Using Autodesk Moldflow 2010 customers can eliminate defects and optimize plastic products, ranging from the first stage of construction, as well as at all stages of the manufacturing process. The unique properties of plastic materials allow manufacturers to create high-quality, lightweight and durable parts with a high degree of reproducibility, ie, the next piece almost indistinguishable from the previous one. Nevertheless, in the production of such details can often be problematic. For example, the plastic may have visual impairments, can even the details, so that they would be unsuitable for the assembly of the finished design. Package Autodesk Moldflow 2010 helps designers and engineers to prevent these defects, providing the necessary balance of aesthetic and structural soundness. These properties are particularly important for consumer goods, details of the interior of automobiles and major products for the building.
    With the 2010 version of the company Autodesk Optimize line Moldflow. Now the set consists of two programs - Moldflow Insight and Moldflow Adviser:
    - Autodesk Moldflow Insight provides an in-depth modeling of the most advanced technological processes for manufacturing plastic components, using the world's largest database of plastics.
    - Autodesk Moldflow Adviser facilitates the simulation of casting parts under pressure, giving designers a detailed analysis of the modeled process and interpret the results. As a result, designers can avoid delays in the production cycle and rid themselves of costly rework otlivochnyh forms.
    An updated version of Autodesk Moldflow 2010 became one of the first class products CAE, fully utilizing all the advantages of modern graphics accelerators. In particular, the use of graphics processor allows twice to expedite the completion of the calculations .
    Watch video on http://www.youtube.com/watch?v=5LDXRDWnRNc
    download from here www.lavteam.com
    for easy account go to http://www.arab-eng.org/vb/t140838.html
    احمد الجزار2007
    احمد الجزار2007 غير متواجد حالياً
    الصورة الرمزية احمد الجزار2007
    مجهود يشكر يابشمهندس
    جزيت خيرا
    مدونه تخص كل اعمال MEP
    http://wiki-mep.blogspot.com/
    أبوعبدالله
    Given: 9
    ايه يا اخوانا مفيش حد بقى بيصمم مولد ولا ايه يا ريت اللي يدخل يقول رأيه
    EHSAN020
    EHSAN020 غير متواجد حالياً
    شكراً لك أخي.......
    ولكن أين الكراك او السيريال
    vague_boy
    vague_boy غير متواجد حالياً
    الصورة الرمزية vague_boy
    ابووووو العريف تحيااااااتي الغاليه
    بس طلب انا نزلت moldflow بس عندي مشكله في ال licence
    يا ريت لو تفهمني كيف اشغلوو
    وشكرا جزيلا اخي
    كثيرون هم الذين نلتقي بهم فيذهبون .. وقليلون هم الذين يحتكرون الجلوس على ناصية القلب "احتراما" و "حبا" ..:)
    kindheart186
    kindheart186 غير متواجد حالياً
    جزاكم الله كل الخير
    محمد2000
    محمد2000 غير متواجد حالياً
    انتظار
    مشكور
    بس فين التحميل
