حكاية حمام السباحة ببساطة ..... هتتعلم يعني هتتعلم
صفحة 7 من 13 الأولىالأولى ... 3 4 5 6 78 9 10 11 ... الأخيرةالأخيرة
النتائج 61 إلى 70 من 125
  1. [61]
    aati badri
    aati badri غير متواجد حالياً
    Received: 861
    Given: 384
    بالنسبة لتحت الارض ايضا هناك انواع من حيث مادة الصناعة
  2. [62]
    aati badri
    Received: 861
    Given: 384
    يمكن ان يبنى من مادة الخرسانة/الخرصانة
    منقول
    Inground Pools
    Turn a Boring Backyard Into a Beautiful Oasis
    CONCRETE OR GUNITE POOLS offer the most design flexibility. They can be built in any shape, from traditional to free form, and are able to fit into irregular spaces, if needed. Gunite pools give you the most opportunity to customize your pool design — from fun and functional built-in featuresto textured pool surfaces. Gunite pools allow for maximum creativity, and typically take about 12 weeks to build.
  3. [63]
    aati badri
    Received: 861
    Given: 384
    ويمكن ان يكون مسبق الصنع
    وهذا ايضا انواع من حيث مادة التصنيع
    1- الفايبر جلاس المقوى
    2-
    Inground Pools
    FIBERGLASS POOLS arrive in one pre-formed, pre-finished piece, so installation is fast (usually 1 to 3 weeks)! Fiberglass pools come in a variety of shapes and styles to fit your lifestyle, as well as designer textures and colors to match your personal style. Besides the quick installation, one of the biggest benefits of fiberglass pools is their surface. The smoothness makes it difficult for algae to cling to it — and that means easier maintenance and fewer chemicals.
  4. [64]
    aati badri
    Received: 861
    Given: 384
    2- ويمكن ان يصنع من الفينيل
    Inground Pools
    VINYL POOLS are pre-engineered, less labor-intensive than concrete pools, and, usually, are your least-expensive inground pool option. Vinyl pools are available in dozens of pre-designed shapes, from classic to curvaceous, and can be customized with built-in features and with durable vinyl liners that come in a beautiful array of designer colors and patterns. Because vinyl pools are constructed from pre-fabricated materials and a simpler construction process, vinyl pools can be constructed in about 3 weeks.
  5. [65]
    aati badri
    Received: 861
    Given: 384
    الحماية
    يستوجب عمل حماية حول الحوض
    لمنع الاطفال والعجزة وضعيفي البصر والحيوانات المنزلية وخلافه من الوقوع في الحمام
    وبعض الاوساخ
  6. [66]
    aati badri
    Received: 861
    Given: 384
    والحماية اقلها عمل سور من الشبك
    ويفضل ان لا يقل ارتفاعه من خمسة امتار
    وهذا اقل حماية مطلوبة
  7. [67]
    aati badri
    Received: 861
    Given: 384
    ويجب عمل بوابة
    تقفل ذاتيا
    وذات مزلاج يقفل ذاتي
  8. [68]
    aati badri
    Received: 861
    Given: 384
    ويمكن ان تتطور الحماية الى اتوماتيكية وبها اجهزة انذار
    اقلها بالبوابة لتعطي انذار عند فتحها
  9. [69]
    aati badri
    Received: 861
    Given: 384
    ويمكن وصل اجهزة الانذار حول سور الشبك
  10. [70]
    aati badri
    Received: 861
    Given: 384
    ويمكن وصل اجهزة الانذار لتعطي اشارة عند حركة الماء
    كما يمكن عمل غطاء للحماية ولحفظه نظيفا
    عند عدم الاستخدام
    ويوجد نوعان من الاغطية بالسوق
    عادي
    واتوماتيكي
