اسئلة مهمة و اجوبتها : ما هو span sag , slip . Skin effect ,corona
النتائج 1 إلى 10 من 35
    الصورة الرمزية الكترومانو
    الكترومانو
    الكترومانو غير متواجد حالياً
    Received: 53
    Skin Effect: Is the tendency of alternating electric current (AC) to distribute itself within a conductor so that the current density near the surface is greater than its core. That is the electric current tends to flow at the skin of the conductor, the skin effect causes the conductor the effective resistance of the conductor to increase with the frequency of the current. Skin effect is due to eddy current setup by the AC current.
    Corona discharge: an electrical discharge accompanied by ionization of surrounding atmosphere
    Problems caused by corona discharge:
    Coronas can generate audible and radio-frequency noise, particularly near [COLOR=window****]electric power transmission[/COLOR] lines. They also represent a power loss, and their action on atmospheric particulates, along with associated ozone and [COLOR=window****]NOx[/COLOR] production, can also be disadvantageous to human health where power lines run through built-up areas. Therefore, power transmission equipment is designed to minimize the formation of corona discharge. Corona discharge is generally undesirable in Electric power transmission, where it causes:
    1-power loss 2-Audible noise 3- Electromagnetic interference
    4- Purple glow الوهج الأرجواني 5- Ozone production 6- Insulation damage
    Sag: Is defined as the vertical distance between the point
    where the line is joined to the tower and the lowest point on the line.
    The sag is as a result of the tensioning of the line and must not be too low otherwise the safety clearances may not be met. Also, the sag had to be such that it caters for ice loading in the winter of temperate climates. If the sag is large, and the line becomes heavily loaded, then the sag will further increase and breach the safety clearances. Similarly, if the sag is low, then when the line contracts in the winter, a low sag will indicate a high tension, and as a result of this contraction, the line may snap. Sag is inversely proportional to the tension of the line, and is given by the formula below.
    For high tensions, the sag should be small.
    For low tensions, the sag should be high.
    Span is the horizontal distance between two towers
    بالنسبة لانواع تبريد المحولات
    ا- بالنسبة للمحولات الجافة هناك
    تبريد هواءطبيعي AN
    تبريد هواء قسري AF
    ب- بالنسبة للمحولات المغمورةبالزيت
    ONAN دوران زيت طبيعي وتبريد بالهواء طبيعي
    ONAF تبريد زيت طبيعيوتيريد نفخ بالهواء
    OFAN دوران الزيت قسريا والهواء طبيعيا
    OFAF تبريد بالزيتقسريا وبالهواء قسريا
    OFWF تبريد بالزيت قسريا وبالماء قسريا
    علما بانههناك انواع مزدوجة التبريد مثل ONAN/ONAF او ONAN/OFAN ......
    مع ملاحظة انالحرف O يستخدم للزيت المعدني اما العوازل الصناعية فيستخدم لها الحرف L بدل من O
    1-عرف ال skin effect-corona-sag-slip-power factor
    skin effect :
    هي ظاهرة مرورالتيار الكهربي على السطح الخارجي (القشرة لخارجية ) للموصل نتيجة تكون قوة دافعةكهربية induced EMF داخل الموصل تحول دون مرور التيار داخله (-- نتيجة وجود ممانعةحثية -- )
    corona
    هي ظاهرة تفريغ جزئي partial discharge تحدث حول الموصلالكهربي و تتسبب في اهدار الكثير من القدرة الكهربية و لها تأثير على خطوطالتليفونات (يحدث تداخل (interference ) بينهما و لها علامات منها سماع صوت أزيز ورؤية ضوء يختلف تبعا لنوع المجال (dc+ or dc- or ac )
    و هناك مجال معين بعدهيمكن رؤية الكورونا بوضوح
    sag :
    المسافة بين أقرب نقطة من الأرض و المسافةالافقية للموصل بين البرجين
    و يمكن حسابه من المسافة بين البرجين و وزن السلك dead wire weight بالاضافة الى عوامل الجو
    slip : (no load speed -full load speed) / no load speed
    و يساوي صفر في الالات التزامنية و من .03:.08 في induction machines
    -ما هو ال transposition مع الشرح؟
    transposition هو عبارة عن عمل تبديللموصلات نقل القدرة الكهربية في خطوط النقل على مسافات متساوية و البرج الذي يحدثعنده هذا التبديل يسمى برج التبديل transposition tower و يتم ذلك التبديل لكي نضمنالتماثل بين جميع الموصلات حيث تختلف الممانعة الكلية impedence لكل موصل عن الاخرنتيجة الاختلاف في inductance لكل موصل .
    a------- b ---------- -------c
    b------ c-------- ---------a
    c------ a--------- -------b
    3-
    ما هو التوافق وما هى شروطة وما هو الجهاز المستخدم ؟
    اذا كانالتوافق هو synchronism فهو : عند توصيل مولد تزامني مع شبكة كهربي (على Busbar ) أو مولد مع مولد توازي يجب ان تتوافر الشروط التالة
    أن يكون* تردد المولد أعلىقليلا من تردد الشبكة في حالة التوصيل على شبكة (أو مساوي لتردد المولد الاخر عندتوصيل مولدين أو اكثر توازي )
    أن يكون لهم نفس الجهد
    أن يكون لهم نفس phase shift
    أن يكون لهم نفس phase sequence
    و الجهاز لمستخدم هو synchroscope (يمكن اجراء تجربة اللمبات المضيئة في حالة اختبارات المعامل
    6-
    تكلمعن ال conductor- bundled-Ferranti effect-impedance voltage power factor improvement
    ferranti effect
    هي ظاهرة زيادة جهد الاستقبال recieved voltage عنجهد الارسال عندما يكون الحمل غير موصل open-circuit
    أو يكون لحمل capacitive load
    bundled conductor
    هي الموصلات التي تتكون من شعيرات صغيرة في صورة حزم (bundled ) كي نقلل من inductance لها و من ثم نقلل من total impedence و من ثم voltage drop
    7-
    كيف يمكن تحسين جهد الشبكة ؟ وما هو احسن مكان لوضع ال static var compasator فى الشبكة ؟
    يمكن ذلك عن طريق عمل capacitive compensation أو inductive compensation و أحسن مكان لوضع ال compensator هو على طرفي الحمل أي عند recieved side
    ابراهيم ك
    ابراهيم ك غير متواجد حالياً
    الصورة الرمزية ابراهيم ك
    شكرا جزيلا اخي الكريم
    محمد يوسف جرادات
    محمد يوسف جرادات غير متواجد حالياً
    شكرا على المعلومات القيمة اخانا الكريم
    shock
    shock غير متواجد حالياً
    معلومات صحيحة مئة بالمئة وشكرا للتذكير بها
    ashrafsaber
    ashrafsaber غير متواجد حالياً
    شكرا اخى فى الله جزاك الله كل خير لو سمحت من فضلك توضح اكتر علاقه skin effect with inductive load
    الكترومانو
    Received: 53
    skin effect is a phenomenon occuring in solid conductor
    carrying AC supply, which leds the current to flow maximum
    at the surface, this current density difference at the core
    and the surface is due to the flux linkage in the core of
    the conductor is more and leads to greater inductance
    inside the core. And the skin effect occurs!
    and the inductance is dependent on the frequency
    inductive reactance proportional to frequenc,
    hence skin effect is pronounced at higher frequency.
    الكترومانو
    Received: 53
    another answer may be that inductance is proportional to
    rate of change of flux linkages with respect to current. as
    frequency increases change in flux linkages also increases,
    L increases, Xl increases, skin effect is more pronounced
    abo khaled80
    abo khaled80 غير متواجد حالياً
    شكرا على المعلومات القيمة اخى العزيز
    Eng / M7G
    Eng / M7G غير متواجد حالياً
    الف شكر ع المعلومات الجامده دي
    جزاك الله خيرا
    محمود الردينى
    محمود الردينى غير متواجد حالياً
    ممتاز جدااااااااا
    اسئلة مواضع امتحانات شفوى وازكر هنا الدكتور محمد ابو العزم هندسة طنطا ربنا يوفقه هو ال عرفنا كل الحاجات دية
