برجاء المساعدة فى نظام الحريق fire detection
صفحة 2 من 2 الأولىالأولى 1 2
النتائج 11 إلى 19 من 19
    الكترومانو
    الكترومانو غير متواجد حالياً
    الصورة الرمزية الكترومانو
    Received: 53
    و للمزيد
    http://www.arab-eng.org/vb/t143254.html#post1177837
    malloka
    malloka غير متواجد حالياً
    شكرا" اخى العزيز
    اود ان اضين ان السقف الاصلى 4.7m وان السقف المعلق يسقط 1.1m
    ahhmedf
    ahhmedf غير متواجد حالياً
    منقول
    How do Apollo fire detectors work?
    Ionisation (ionization) smoke detector
    The sensing part of the detector consists of two chambers - an open, outer chamber and a semi-sealed reference chamber within. Mounted in the reference chamber is a low activity radioactive foil of Americium 241 which enables current to flow between the inner and outer chambers when the detector is powered up. As smoke enters the detector, particles become attached to the ions, causing a reduction in current flow in the outer chamber and hence an increase in voltage measured at the junction between the two chambers. The voltage increase is monitored by the electronic circuitry which triggers the detector into the alarm state at a preset threshold. An externally visible red LED lights up when the detector changes to alarm state.
    Ionisation smoke detectors are good general-purpose detectors which respond well to fast-burning (flaming) fires and are widely used for property protection.
    Integrating ionisation smoke detector
    Available in the Series 60 and Series 65 ranges, this type of detector works on the same principles as the ionisation smoke detector, but has modified signal processing circuitry which allows an alarm threshold to be present for up to 20 seconds without initiating an alarm.
    This type of detector is suitable for use in areas where transient high levels of smoke may be expected.
    Integrating effect in analogue addressable systems
    In XP95 systems, the integrating effect can be mimicked in both ionisation and optical smoke detectors by adjusting the control equipment software to cause an appropriate delay. Discovery smoke detectors should be set to Mode 2 or Mode 4 to achieve this effect. Click here to find out more.
    Optical (photo-electric) smoke detector
    Optical smoke detectors incorporate a pulsing infra-red LED located in a chamber within the housing of the detector. The chamber is designed to exclude light from any external source. At an angle to the LED is a photo-diode which normally does not register the column of light emitted by the LED. In the event of smoke from a fire entering the chamber, the light pulse from the LED will be scattered and hence registered by the photo-diode. If the photo-diode "sees" smoke on the two following pulses, the detector changes into alarm state and the indicator LED lights up. The detector housing is identical to that of the ionisation detector but has an indicator LED which is clear in quiescent state but produces red light in alarm.
    Optical smoke detectors respond particularly well to slow-burning (smouldering) fires. They are widely used for life protection.
    Heat detector
    Most conventional heat detectors (all Series 60 and Series 65 & AlarmSense A1R, BR and CR) operate by using a matched pair of thermistors to sense heat. One thermistor is exposed to the ambient temperature, the other is sealed. In normal conditions the two thermistors register similar temperatures, but, on the development of a fire, the temperature recorded by the exposed thermistor will increase rapidly, resulting in an imbalance of the thermistors, causing the detector to change into alarm state. Rate-of-rise detectors are designed to detect a fire as the temperature increases, but they also have a fixed upper limit at which the detector will go into alarm if the rate of temperature increase has been too slow to trigger the detector earlier.
    The Series 65 and AlarmSense CS (static response) heat detectors have only one thermistor. They change to the alarm state at a preset temperature.
    Externally, the heat detectors are distinguishable from the smoke detectors by having wide openings to the surrounding atmosphere to allow good movement of air around the external thermistor.
    A heat detector may be more appropriate than a smoke detector where the environment is dirty or smoky under normal conditions. It must be recognised, however, that any heat detector will respond only when a fire is well established and generating a high heat output.
    Multisensor detector
    Available in the XP95 and Discovery ranges, this type of detector is basically an optical smoke detector - so it will respond well to smouldering fires. The addition of a heat sensing element allows the multi-sensor to give a response to fast burning (flaming) fires which is comparable to that of an ionisation detector.
    Multisensor detectors are general purpose detectors which respond well to a wide range of fires.
    Carbon Monoxide (CO) detector
    Carbon Monoxide (CO) is a poisonous gas produced by combustion and a CO fire detector is used to indicate the outbreak of a fire by sensing the level of CO in the air. The detector has an electrochemical cell which senses CO, but not smoke or other combustion products. The cells do not require much power, so the detector can be made electrically compatible with ordinary smoke and heat detectors. Apollo manufacturers a CO detector as part of the Discovery range.
    CO detectors are particuarly good at detecting deep-seated, smouldering fires.
    To find out more, visit the CO Detectors page.
    Beam detector
    A beam detector is designed to protect large, open spaces and is made up of three main parts: the transmitter, which projects a beam of infra-red light; the receiver which registers the light and produces an electrical signal; and the interface, which processes the signal and generates alarm or fault signals. When a fire develops, smoke particles obstruct the beam of light and, once a pre-set threshold has been exceeded, the detector will go into alarm.
    To find out more, visit the XP95 Beam Detector page.
    Flame detector
    A flame detector is designed to detect either ultraviolet (UV) or infra-red (IR) radiation emitted by a fire. The XP95 Dual IR flame detector is sensitive to low-frequency, flickering infra-red radiation. This means that the detector can operate even if the lens is contaminated by a layer of oil, dust, water vapour or ice.
    Flame detectors are effective in protecting areas where flaming fires may be expected.
    malloka
    اشكرك اخى العزيز احمد
    ولكن ممكن اعرف ازاى اوزعهم واين اضعهم؟
    المغيره احمد
    المغيره احمد غير متواجد حالياً
    الصورة الرمزية المغيره احمد
    شكـــــــــــــــرا جزيلا
    enwaijee
    enwaijee غير متواجد حالياً
    الصورة الرمزية enwaijee
    Given: 30
    والله الموضوع شيق شكرا لكم على ماقدمتموه
    mostafa2021
    mostafa2021 غير متواجد حالياً
    الصورة الرمزية mostafa2021
    أشكرا يا خى على المعلومات التى افادتنا بها
    alssafee
    alssafee غير متواجد حالياً
    جزاكم الله كل خير
    mena hanaa
    mena hanaa غير متواجد حالياً
    Thank u
