شرح انواع الضواغط بالصور المتحركة لايفوتكم
مشاهدة نتائج الإستطلاع: ماهو تقيمك للمضوع
المصوتون
8. أنت لم تصوت في هذا الإستطلاع
  • ممتاز
    3 37.50%
  • جيد
    5 62.50%
  • متوسط
    0 0%
  • ضعيف
    0 0%
إستطلاع متعدد الإختيارات.
النتائج 1 إلى 10 من 13
    العراقي1982
    العراقي1982 غير متواجد حالياً
    Air compressor tools are gaining in popularity, while electric tools are losing. With the popularity of the air compressor has come a reduction in price that makes them more affordable for both businesses and homeowners. Electric tools, which have a motor built in, weigh much more than compressor tools.
    Air tools can make more revolutions per minute and are capable of much more torque. Tasks done with such tools are completed faster and more efficiently than those done with electric tools.
    When properly maintained, compressor tools are long-lasting, and somewhat indestructible. They have very few moving parts, so maintenance is usually limited to oiling, and they do not tend to overheat. Most of the tools attach to the air line with an accessory called a quick coupler, making changes very simple and very fast.
    There are many different sizes, ranging from mini air compressors, to truck air compressors, to industrial sized compressors. There are also different types of air compressors, including the electric compressor, the gas compressor, and the rotary screw compressor.
    There are many different air compressor tools. Two of the most convenient are the inflation kit and the impact wrench. You can inflate a variety of different objects with the inflation kit, including tires, balls and air mattresses.
    The impact wrench, similar to the air ratchet wrench, is used mainly in automotive and construction work and is good for adding torque and tightening bolts. When you have an area that is hard to clean, the blow gun is a good option. It can clean dirt, grease and dust from hard to reach areas because it can pump air in high pressure streams.
    Air nailers are an efficient way of nailing down shingles, or drywall. The air stapler is similar to the nail gun. Automotive body shops use the air sander in their work.
    Sandblasters are used for removing old paint or rust. Most sandblasters have an adapter kit for use with water and detergents for power washing. The ratchet wrench is similar to the impact wrench and is another very popular tool. Both are used mainly in automotive and construction work, and are good for tightening bolts and adding torque.
    Air hammers or chisels work well in masonry applications. Air drills allow for effortless drilling into any surface. The simplicity of changing the attachments and the use of one source of power for all makes owning an air compressor and air compressor tools a good investment.
    Mike Selvon has some great air compressors articles. Find out more tips on air compressor tools at his resourceful site. We appreciate your feedback at our
    هذا الرابط يشرح بالصور زوروه
    http://www.compair.com/About_Us/Compressed_Air_Explained--03The_three_types_of_compressors.aspx
    http://www.geocities.com/mojju/me797/Compressors101.swf
    misho42442
    misho42442 غير متواجد حالياً
    thanks
    appreciate it
    Hydra
    Hydra غير متواجد حالياً
    الصورة الرمزية Hydra
    مشكوور اخي على الموضوع و بارك الله فيك
    بلال مهدي
    بلال مهدي غير متواجد حالياً
    شكرا عالمجهود يالعراقي واتمنى من جميع الاخوة المشتركين طرح اسئلة تخص السيارات لكي اساعدكم على قدر الامكان فانا مهندس سيارات وعندي خبرة 3 سنوات حيث اعمل بشركة مرسيدس , الورشة الفنية.
    SGMAH
    SGMAH غير متواجد حالياً
    thank you for your great subject
    مساعد فني
    مساعد فني غير متواجد حالياً
    المواقع ممتازة
    والصور الموضحة ممكن تبين طريقة العمل حتى لو كان الإنسان مبتدئ
    في هذا المجال
    بارك الله فك وتسلم اياديك
    بس سؤال لك ولللإخوان
    كيف أقدر أحفظ مثل هذي الصور على جهازي
    lord of revenge
    lord of revenge غير متواجد حالياً
    الصورة الرمزية lord of revenge
    actually it is very good
    I saw the second link and it was very clear
    thanx
    Where There Is a
    .....WILL
    There Is a WAY
    م محمد حمدى السيد
    م محمد حمدى السيد غير متواجد حالياً
    مشكووووووووووووووووووووور كتير كتير انيماشن رائع فعلان
    عباس الثاني
    عباس الثاني غير متواجد حالياً
    مشكور وبارك الله بيك
    مهندس مملووح
    مهندس مملووح غير متواجد حالياً
    شكرا شكرا على الموضوع الحلو
