Compressors in short words
النتائج 1 إلى 10 من 12
    الصورة الرمزية lord of revenge
    lord of revenge
    lord of revenge غير متواجد حالياً
    SALAM 3LIKM WA RA7MAT ALLAH\
    بسبب استفساري السابق عن الكمبريسور واوناعه
    فاني الحين حصلت اجوبتي واحب اطرحها كمشاركة تتحدث عن الكمبريسور بنبذة مختصرة وان كان في اي استفسار فاني موجووود ^_^
    ملاحظة:: مشاركتي ستكون بالانجليزية
    ابدأ
    As every body know, it is good to know more in science.
    here I want to talk briefly about five types of compressors ( small definitions and small decriptions about the difference between them)
    first of all
    !!WHAT IS COMPRESSOR??
    Compressor: mechanical device that increases the pressure of a gas by reducing its volume.
    Types of compressors
    the main four compressors are:
    1. Centrifgal compressor
    :Definition:
    Centrifugal Compressor use an impeller (rotating disk ) in a shaped housing to force the gas to the rim of the impeller, increasing the velocity of the gas. A diffuser (divergent duct) section converts the velocity energy to pressure energy
    (as can be seen in second picture) .
    :Prpperties:
    Generally used where a high flow and lower pressure head is required
    __________________________________________________ ____________
    2. Reciprocating compressor
    :Definition:
    It compresses gas by the action of a piston moving in a back-and-forth motion within a cylinder
    :Prpperties:
    Mainly used where high pressure head is required at a low flow
    Larger, noisier, and more costly than comparable rotary
    compressor.
    3.Rotary compressor
    :Definition:
    In Rotary Compressors the gas is compressed by the rotating action of a roller inside a cylinder
    the main parts in this compressor are
    roller, cylinder, suction port, discharge port ans spring wich attached to motor to keep pushing the roller
    :Prpperties:
    very efficient
    Smaller and
    less noisier
    4. Axial Compressor
    :Definition:
    It is a dynamic rotating compressor that use arrays of fan-
    like aerofoil to compress the fluid
    The arrays of aerofoils are set in rows, usually as pairs: one rotating and one stationary. The rotating aerofoils, also known as blades or rotors, accelerate the fluid. The stationary aerofoils, also known as a stators or vanes, decelerate and redirect the flow direction of the fluid, preparing it for the rotor blades of the next stage
    :Prpperties:
    used for a high flow rate
    high efficiencies
    Expensive
    Can be found in medium to large gas turbine engines, in natural gas pumping stations, and within certain chemical plants
    هذه هي النبذة البسيطة التي احببت ان اشارك بها
    واتمنى انها كانت مفيدة ومفهومة
    lord of revenge
    oh my god
    there is no any replaying!!!!
    Where There Is a
    .....WILL
    There Is a WAY
    مهندس o0o
    مهندس o0o غير متواجد حالياً
    شكرا اخوي علىالمعلومات الحلوه
    qu_mech_eng
    qu_mech_eng غير متواجد حالياً
    أحييك أخي على مشاركتك التعريفية بالكمبرسرات، ملحوظة صغيرة، السنترفيجال كمبريسورز، تستخدم للضغوط المتوسطة والفلو المتوسط نسبياً إذا ماقورن بالأكسيال.. وقد أوردت في مشاركتك بأنه للضغوط العالية، هناك حالات خاصة تستدعي بأن يكون الكمبريسر من النوع البرميلي، ليتحمل الضغوط العالية barrel type casing.. ومن أهم الشركات المصنعة للكمبرسرات السنترفيجال.. Elliott و Nuovo Pignone ..
    تحياتي للجميع..
    lord of revenge
    اقتباس المشاركة الأصلية كتبت بواسطة مهندس o0o مشاهدة المشاركة
    شكرا اخي مهندس o0o على الرد والمرور سررت كثيرا بمرورك
    Sincerely
    Where There Is a
    .....WILL
    There Is a WAY
    lord of revenge
    Thumbs up
    اقتباس المشاركة الأصلية كتبت بواسطة qu_mech_eng مشاهدة المشاركة
    تحياتي للجميع..
    you are right my brother qu_mech_eng about the centrifugal compressors are used in mid flow and mid pressure
    but in my preneting I said the axial comopressors are more efficient
    but as you said it better to metion it clearly
    my best regards
    and I liked your passing soooo much dear
    Where There Is a
    .....WILL
    There Is a WAY
    د.محمد باشراحيل
    إستشاري الملتقى
    Received: 127
    Given: 15
    That is a vey simple description of the types of compressors and usefull,as well
    keep up the good work.
    There are two sites that have some information about Compressors
    تصميم التربينات والضواغط
    http://www.arab-eng.org/vb/t135091.html
    الموسوعة الشاملة للـ "Gas Turbines & Compressors"
    http://www.arab-eng.org/vb/t52498.html
    You may extract some technical and engineering formulae
    and shed light on them
    Best Regards
    lord of revenge
    Cool
    اقتباس المشاركة الأصلية كتبت بواسطة د.محمد باشراحيل مشاهدة المشاركة
    Hi
    د.محمد باشراحيل
    It is honour for me to be replaied by you sir
    as you sad i did simple decriptions
    to get the idea
    and your first link to that powerpint is goooood for deep information
    Best Regards
    your second link is very helpful and I like such these videos .
    It is excelent way to fix information in mind
    I am soo glad for your passing here
    Sincerely
    Where There Is a
    .....WILL
    There Is a WAY
    م محمد حمدى السيد
    م محمد حمدى السيد غير متواجد حالياً
    مشكوووووووووووووووووووووووووووور
    lord of revenge
    Talking
    اقتباس المشاركة الأصلية كتبت بواسطة م محمد حمدى السيد مشاهدة المشاركة
    welcome
    eng. محمد حمدى السيد for passing
    ^_*
    Where There Is a
    .....WILL
    There Is a WAY
