برنامج safe v12.1.1 اخر اصدار كامل بالكراك
النتائج 1 إلى 10 من 22
    جولدن بوى
    جولدن بوى غير متواجد حالياً
    الموضوع منقول
    • The use of mixed units has been implemented throughout the program for all
    input, display, and reporting. This is under user control, including the option to
    use consistent units. For example, you could mix feet for coordinates, ksi for
    stress, and in2/ft for rebar area per length. Similarly, in the metric system
    you could use meters for coordinates, MPa for stress, and mm2/m for rebar area
    per length.
    • DirectX graphics mode is now available for all drafting, modeling, and display purposes. DirectX provides faster 3-D graphics on machines with a capable
    graphics card. The Standard graphics mode is compatible with all machines and
    remains the default.
    • The Architectural Layer tracing for importing DXF/DWG files has been
    significantly enhanced for object recognition, speed, and ease of use.
    • Dimension lines now automatically adjust with the movement of associated
    grid lines and objects.
    • Tendon high and low points are shown in plan views as distances from the top or bottom of the slab.
    • T-beams and L-beams can now be explicitly specified as being inverted.
    • Wide beams can now be converted to equivalent thicker slabs when desired.
    • Temperature loading has been added, including the ability to specify different temperatures above and below the slab (temperature gradient).
    • Distributed lateral forces and moments can now be applied to beams, and distributed lateral forces can be applied to slabs. These lateral loads can also be imported from ETABS.
    • Analysis of cracking deflection has been enhanced to include the effects of
    creep, shrinkage, and axial loads.
    • Design combinations can easily be converted to nonlinear load cases for
    uplift calculation.
    • Integrated wall forces are now reported as reactions.
    • Distinct middle and column design strips have been implemented for R/C design, which improves design reporting and detailing. Full-width column strips are
    normally used for P/T design.
    • User-specified reinforcement may be defined. Design can take this into account
    and report the additional rebar needed, if any, to meet code requirements.
    • Punching-shear design has been enhanced to account for edges and corners,
    with user overwrites provided for additional control.
    • One-way shear design has been added to the design strips for all codes.
    • For design using FEM results (rather than design strips), the effect of P/T upon strength design has now been implemented. FEM-based design is an effective alternative to strip-based design when strips cannot be easily or
    reasonably defined.
    • The effect of P/T upon design can now be ignored in local regions for both
    strip-based and FEM-based design.
    • The automation and user-control of beam sections used for analysis and design
    has been enhanced to better consider the interaction with the slab.
    • Chinese design code and language translation have been implemented for users
    with a Chinese license.
    • Usability, control, and reporting have been significantly enhanced for the
    Detailer, including single-level Undo/Redo.
    • A comprehensive set of keyboard shortcuts has been added for power users.
    • Overall enhancements for usability, speed, look and feel have been implemented throughout the program.
    Download the Standalone installation for SAFE V12.
    Download the Network installation for SAFE V12.
    Download the
    License Manager installation to serve licenses over a network - Required for Network installations.
    Download the full DVD for SAFE V12 – Standalone, Network, License Manager, and Watch & Learns.
    OR From
    MIRRORS:
    crack
    من المرفقات
    اثبات البرنامج
    من مواضيع جولدن بوى :
    التعديل الأخير تم بواسطة سنا الإسلام ; 2010-11-06 الساعة 04:34 AM
    Hany Ahmed Omar
    Hany Ahmed Omar غير متواجد حالياً
    Received: 73
    Given: 239
    مشكور يامعلم
    بس لينك الكراك مش شغال اثناء التحميل بيفصل
    ياريت تشوف لنا الموضوع ده لانك عارف برنامج من غير كراك
    جولدن بوى
    اقتباس المشاركة الأصلية كتبت بواسطة Hany Ahmed Omar مشاهدة المشاركة
    مشكور يامعلم
    شكرا على الرد
    بس انا مش معلم انا مهندس مدنى
    و بالنسبة للكراك فهذا رابط اخر علشان خاطر عيونك
    http://www.mediafire.com/download.php?z1350jjngnz
    Hany Ahmed Omar
    Received: 73
    Given: 239
    على فكرة كلمة معلم في لبنان لما تقال للمهندس بتكون عنده اكبر واحلى 100 مرة لما تقوله
    يابشمهندس
    وعموما شكرا يا بشمهندس
    جولدن بوى
    اقتباس المشاركة الأصلية كتبت بواسطة hany ahmed omar مشاهدة المشاركة
    يابشمهندس
    ههههههههههه
    مكنتش اعرف
    المعلم عندنا فى مصر بيكون تاجر - صاحب حرفة هكذا
    و شكرا على الرد يا بشمهندس
    fihonil
    fihonil غير متواجد حالياً
    الف شكر يا باشا بدور علية من زمان
    م.صلاح-سورية
    م.صلاح-سورية غير متواجد حالياً
    جزاك الله كل خير وبارك فيك
    م.طاهر
    م.طاهر غير متواجد حالياً
    الصورة الرمزية م.طاهر
    Received: 11
    Given: 64
    اقتباس المشاركة الأصلية كتبت بواسطة fihonil مشاهدة المشاركة
    كويس ان المهندس جولدن بوي معلقش علي كلمة باشا ديه وقالك احنا مش قاعدين في قسم البساتين هنا ههههههههههههههههههههههه
    يا جماعه كلنا اخوات ومفيش فرق بيننا وبين بعض والحوار ابسط من كده كتير
    بالتوفيق للجميع
    a1h1m1e1d2000
    a1h1m1e1d2000 غير متواجد حالياً
    الصورة الرمزية a1h1m1e1d2000
    Received: 12
    Given: 10
    شكرا جزيلا اخي الفاضل
    محمد جمال قطب
    محمد جمال قطب غير متواجد حالياً
    Received: 11
    Given: 5
    جزاك الله خيرا.
    سبحان الله
    والحمد لله
    ولا إله إلا الله
    والله أكبر
    ولا حول ولا قوة إلا بالله.
    سبحان الله وبحمده & سبحان الله العظيم
