اروع ما وجدت لتصميم الوصلات المعدنية
صفحة 1 من 6 12 3 4 5 ... الأخيرةالأخيرة
النتائج 1 إلى 10 من 57
    زعيم الاسكندرية
    زعيم الاسكندرية غير متواجد حالياً
    Received: 262
    Given: 264
    اعزائى الأخوة والزملاء
    السلام عليكم ورحمة الله وبركاته ،،،
    Limcon v3.55 Limit States Analysis & Checking of Steel Connections
    info:
    Limcon V3 is a powerful design aid for a range of steel connection types.
    Features include:
    Checking to AISC LRFD, BS 5950, or AS 4100.
    Shear, moment, HSS connections and splices.
    AISC multiple-row moment end plate connections.
    Bolt and weld groups.
    Virtual reality view of connections.
    Integrated detailing with DXF output.
    SI metric or US customary units.
    Professional support.
    Install Instructions:
    1- Install "limconv3_demo_us.exe"
    2- Install Update "@limcon3.exe" using Password 3155
    3- Overwrite "Lmc3.exe"
    Working until 30.09.09
    screenshots:
    Download:
    Code:
    http://rapidshare.com/files/23875501...on355.rar.html
    http://www.4shared.com/file/10877313...limcon355.html
    بعد طول انتظار وترقب حثيث
    هذا الكراك يجعل البرنامج مفتوحا طوال الوقت
    استمتعوا باوقاتكم ولا تنسونى من دعائكم
    Download "DateFake" here (145kb only):
    Code:
    http://www.fileden.com/files/2007/9/29/1469193/DateFake.rar
    Instructions:
    1. Extract and place the 2 small files in your Limcon/Program directory.
    2. Now just click on DateFake.exe and this screenshot will come out :
    *Note that the program to run should be set to Lmc3.exe
    3. Just click Ok and your Limcon should run. Do your stuff..and when you close Limcon, Datefake will also close. Easy!!
    4. Finally make a shortcut of DateFake.exe in your desktop (rightclick,SendTo->MakeShortcut)
    5. Rename the shortcut to, say LimconX
    6. Now change the icon of the shortcut to match the Limcon icon (right click,Properties->ChangeIcon->Browse and go to Limcon Directory and choose Limcon3.exe to use its icon)
    There you go! Now you have LimconX icon that will lunch Limcon (fullversion) everytime. Simple problem :)
    تعليمات تشغيل اضافية عن استخدام ويندوز فيستا
    انقر بالماوس يمين وشغل البرنامج كمسئول ان كنت تستخدم ويندوز فيستا مع ملاحظة انه يجب قبل تنصيب البرنامج اعادة التاريخ قبل 30/09/2009 ويتم تفعيل الكراك الأصلى ثم الكراك الثانى
    عند ظهور القائمة لا تنتظر اكثر من ثانية واحدة للنقر على ok
    اذا كنت تستخدم ويندوز اكس بى فله كراك خاص به هذه روابطه
    Download Links:
    Code:
    http://www.4shared.com/file/136967555/108fd87a/LC_v355090630_xpsp3.html
    http://www.mediafire.com/download.php?mym0mcjtmim
    Password:
    Code:
    CivilEA
    Hey don't forget to say thanks!
    mhany80
    mhany80 غير متواجد حالياً
    الصورة الرمزية mhany80
    أسف لقد بحثت عن كراك و لم أجد له
    شكرا على المعلومة القيمة
    محمد 977
    محمد 977 غير متواجد حالياً
    تسلم الأيادي على التميز
    مشكوووووووووووووور
    تسلم ايدك
    الف الف شكر من صميم القلب
    زعيم الاسكندرية
    Received: 262
    Given: 264
    Code:
    http://www.fileden.com/files/2007/9/...3/DateFake.rar
    Instructions:
    hassananas
    hassananas غير متواجد حالياً
    Received: 224
    Given: 6
    مشكوووووووووووووور
    تسلم ايدك
    مجدي بكري
    مجدي بكري غير متواجد حالياً
    Dear Alexandria Boss,
    You Always come with the most surprising gifts. Go Ahead. Gazak Allah Khairah. Dr. Magdy
    زعيم الاسكندرية
    Received: 262
    Given: 264
    اقتباس المشاركة الأصلية كتبت بواسطة مجدي بكري مشاهدة المشاركة
    dear alexandria boss,
    you always come with the most surprising gifts. Go ahead. Gazak allah khairah. Dr. Magdy
    دائما ترفع من روحى المعنوية د/ مجدى
    لك جزيل الشكر ووافر الاحترام
    سنا الإسلام
    سنا الإسلام غير متواجد حالياً
    Received: 257
    جزاكم الله خيرا وبارك الله فيك
    تم اضافة رابط الكراك الى المشاركة الاصلية
    متغيبة عن الملتقى
    mohy_y2003
    mohy_y2003 غير متواجد حالياً
    الصورة الرمزية mohy_y2003
    Received: 350
    Given: 439
    جزاكم الله خيراً يازعيم
    والله يعطيك الف عافيه
    والله يرحم والديك
    ويعينك علي مسئولية الشعب الملقاه علي عاتقك ههههههههه
    الإمام محمد الغزالي
    كناعنة
    كناعنة غير متواجد حالياً
    بارك الله فيك وجزاك خيرا ووفقك لما يحب ويرضى
