فرامل السيارات الثقيلة (الشاحنات و الحافلات):
صفحة 7 من 8 الأولىالأولى ... 3 4 5 6 78 الأخيرةالأخيرة
النتائج 61 إلى 70 من 78
  1. [61]
    lesnar_f5
    lesnar_f5 غير متواجد حالياً
    جزاك الله خيرا
  2. [62]
    ابو عمر التكريتي
    ابو عمر التكريتي غير متواجد حالياً
    Given: 10
    شرح ممتاز لكن اتمنى لوكان هناك توضيح بالصور
  3. [63]
    المهندس احمدالعابد
    المهندس احمدالعابد غير متواجد حالياً
    الصورة الرمزية المهندس احمدالعابد
    رائع
    المهندس احمدالعابد
  4. [64]
    ابوحريره
    ابوحريره غير متواجد حالياً
    ربنا يجعله لك في ميزان حسناتك
  5. [65]
    فراس الجابري
    فراس الجابري غير متواجد حالياً
    Given: 8
    مشكور بارك الله بك اخي العزيز و جعله الله في ميزان حسناتك
    لاحول ولا قوة إلا بالله العلي العظيم
  6. [66]
    فراس الجابري
    Given: 8
    A retarder:-is a device used to augment or replace some of the functions of primary friction-based braking systems, usually on heavy vehicles.
    Friction-based braking systems are susceptible to 'brake fade' when used extensively for continuous periods, which can be dangerous if braking performance drops below what is required to stop the vehicle – for instance if a truck or bus is descending a long decline. For this reason, such heavy vehicles are frequently fitted with a supplementary system that is not friction-based.
    Retarders are not restricted to road motor vehicles, but may also be used in railway systems. The British prototypeAdvanced Passanger Train (APT) used hydraulic retarders to allow the high-speed train to stop in the same distance as standard lower speed trains, as a pure friction-based system was not viable.
    Retarders serve to slow vehicles, or maintain a steady speed on declines, and help prevent the vehicle 'running away' by accelerating down the decline. They are not usually capable of bringing vehicles to a standstill, as their effectiveness diminishes as vehicle speed lowers. They are usually used as an additional 'assistance' to slow vehicles, with the final braking done by a conventional friction braking system. As the friction brake will be used less, particularly at higher speeds, their service life is increased.
  7. [67]
    وائل فاروق
    وائل فاروق غير متواجد حالياً
    مشكورررررررررررررررر جداااااااااااااااااااااااااااااااااا
  8. [68]
    احسان الشبل
    احسان الشبل غير متواجد حالياً
    الصورة الرمزية احسان الشبل
    عااااااااشت ايدك على المجهود الرائع
    الأصدقاء الحقيقون يصعب إيجادهم ، يصعب تركهم ، ويستحيل نسيانهم
  9. [69]
    nashat fattah
    nashat fattah غير متواجد حالياً
    بارك الله فيك
  10. [70]
    automotive
    automotive غير متواجد حالياً
    موضوع رائع ومجهود متميز
