How centrifugal pumps work
النتائج 1 إلى 2 من 2
    الصورة الرمزية فيتامين
    فيتامين
    فيتامين غير متواجد حالياً
    A centrifugal pump works by the conversion of the rotational kinetic energy, typically from an electric motor or turbine, to an increased static fluid pressure. This action is described by Bernoulli's principle. The rotation of the pump impeller imparts kinetic energy to the fluid as it is drawn in from the impeller eye (centre) and is forced outward through the impeller vanes to the periphery. As the fluid exits the impeller, the fluid kinetic energy (velocity) is then converted to (static) pressure due to the change in area the fluid experiences in the volute section. Typically the volute shape of the pump casing (increasing in volume), or the diffuser vanes (which serve to slow the fluid, converting to kinetic energy in to flow work) are responsible for the energy conversion. The energy conversion results in an increased pressure on the downstream side of the pump, causing flow.
    حسين على عيد
    حسين على عيد غير متواجد حالياً
    الصورة الرمزية حسين على عيد
    شرح مبسط ولكن ننتظر المزيد عن الموضوع
