Automatic Control
النتائج 1 إلى 2 من 2
    الصورة الرمزية أحمد رأفت
    أحمد رأفت
    أحمد رأفت غير متواجد حالياً
    Received: 11
    Given: 14
    Automatic Control
    Automatic Control
    التحكم الألى
    control means measuring the value of controlled variable of the System & applying the manipluted variableto the system to correct the devation
    Type of Control
    Open Loop Closed Loop
    Open Loop Control System :also called a non-feedback controller, is a type of controller which computes its input into a system using only the current state and its model of the system.
    A characteristic of the open-loop controller is that it does not use feedback to determine if its input has achieved the desired goal. This means that the system does not observe the output of the
    processes that it is controlling
    Closed Loop Control System : The output of the system y(t) is fed back through a sensor measurement F to the reference value r(t). The controller C then takes the error e (difference)between the reference and the output to change the inputs u to the system under control P. This is shown in the figure. This kind of controller is a
    closed-loop controller or feedback controller.
    lolos
    lolos غير متواجد حالياً
    تم إيقافه لمخالفة القوانين
    hi rafft انا احمد الديب رابعه طاقه
    الموضوع جامد ايميلى
    eng_deebo
    bhit
