Graphic Reports in P6
النتائج 1 إلى 3 من 3
    الصورة الرمزية المفكرةالعربيه
    المفكرةالعربيه
    المفكرةالعربيه غير متواجد حالياً
    تم إيقافه لمخالفة القوانين
    helpthem
    helpthem غير متواجد حالياً
    Received: 10
    graphic report
    Salem aleikoum
    you can do it very easy with P6 the S-curve and histogramme can be used if you have introduced a budget or resources for activities
    and then look on menu bar you'll see view and then you have show on bottom
    you have a differents option
    for exemple you choose activity usage profile
    you'll see a graphic if you have introduced budget or resources.
    On graphique clic right button on your mouse and you have differents option to ajuste and to show a curves and histogramme
    Good luck
    and salem aleikoum
    arch_hleem
    arch_hleem غير متواجد حالياً
    الصورة الرمزية arch_hleem
    thanks,
    but the question is how can I change the presentation option.... the question is generally expanded to all p6 output.... where am really suffering on how to change the bar chart thickness where its not sufficient enough... the same issue can be raised again when I want to change the Value on the X , Y Axis or change the number of the Horizontal or Vertical Line That Could be Appeared on the Histogram.
