different between non preloaded bolts or preloaded bolts
النتائج 1 إلى 2 من 2
    ADWYCIVIL
    ADWYCIVIL غير متواجد حالياً
    please can you tell me which type we used in design anchor bolt
    non preloaded bolts or preloaded bolts??
    and what's the different between them
    thanks
    من مواضيع ADWYCIVIL :
    engco
    engco غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة ADWYCIVIL مشاهدة المشاركة
    thanks
    in some sources you will see that the main difference is only fatique. if fatique exist you will need preload in anchorage, and this fatique doesn't cover the earthquake.
