تصميم الشدة الخشبية ولله الحمد و المنة
النتائج 1 إلى 10 من 10
    هلوتس
    هلوتس غير متواجد حالياً
    طريقة و معادلات تصميم الشدة الخشبية
    Design calculations:
    1- design of decking
    Weights:
    O.W = 900 * 0.025 = 22.5 kg/m²
    Weight of concrete = 25*25 = 625 kg/m²
    Live loads ( ready mix with concrete pump) = 240 kg/m²
    Total dead loads = 647.5 = 650 kg/m²
    Live loads = 240 kg/m²
    Total loads in sq. meter = 890 kg/m²
    Moments = WS²/ 10
    = 890 * .4 ²/10 = 14.24 kg.m
    Max. shear force = .6 w s = .6*890*.4 = 213.6 kg
    F1,2 max. stresses on outer fiber = M/I*Y = M/S where S = I/Y
    ,S =bh³/ (12*h/2) = bh²/ 6 = 100*2.5²/6 = 104 cm³
    F max. = 14.24 * 10 ² /104 = 13.69kg/cm² O.K
    Qmax. = 1.5 Q/A = 1.5*213.6 / (100*2.5) =1.28 kg/cm² O.K
    2 – design of joists :
    Weights:
    O.W = 900 * 0.025 = 2.25 kg/m´
    Weight of decking = 1.10*650*.40 = 286 kg/m´
    ( ready mix with concrete pump) = 1.10*240*.40 = 105.6 kg/m´
    Total loads = 393 kg/m´
    Mmax = Wl²/10
    =393* .7²/10 = 19.3kg.m
    Max. shear force = .6 w s = .6*393*.7 = 165kg
    F1,2 max. stresses = M/I*Y = M/S where S = I/Y
    ,S =bh³/ (12*h/2) = bh²/ 6 = 100*2.5²/6 =41.6 cm³
    F max. = 19.3 * 10 ² /41.6= 46.4 kg/cm² O.K
    Qmax. = 1.5 Q/A = 1.5*165 / (12.5*2.5) =7.92kg/cm² taken 1"*5"
    3- Design of wailing:
    Weights:
    O.W = 900 * 0.025 *.2 = 4.5 kg/m`
    Loads = Rj = 1.10 *393 *.7 = 302 kg
    Mmax = 45 kg.m
    Max. shear force = 302 kg
    ,S =bh³/ (12*h/2) = bh²/ 6 = 20²*2.5/6 = 166.6 cm³
    F max. = 45 * 10 ² /166.66= 27 kg/cm² O.K
    Qmax. = 1.5 Q/A = 1.5*302 / (25 *2.5) =7.25kg/cm² O.K
    Design of prob:
    load on prob :
    Pp = 1.15 (2Rj + Ww*Lw)
    = 1.15 (2*302 + 4.5*.7 ) = 699 kg
    Fpb = 70 (1- Lb/80 bp) Lb = 185 cm
    Fpb = 70 (1-185/(80*7.5)) = 48.4 kg/cm²
    Area required = 699 /48.4 = 14.4 cm²
    3"*3" prob is sufficient @ 700 mm in two direction O.k
    هلوتس
    باقى الملفات
    الرسومات التفصلية لمكونات الشدة
    4 Not allowed!
    هلوتس
    استخدمات انواع الاخشاب : -
    اللتزانه :- تطبيق السقف –- تجاليد العمود—جوانب و قيعان الكمرات
    الموسكى :- العراقات – تطاريح الكمرات – الاسقف – الحطات – احزمة الاعمدة
    العروق الفليرى :- القوائم و البرندات
    العبد الفقير
    العبد الفقير غير متواجد حالياً
    عضو فائق التميز
    الصورة الرمزية العبد الفقير
    Received: 19
    بارك الله فيك ولكن هذه على أي كود
    العبد الفقير إلى رحمة الله الواسعة...
    وتعر من ثوبين من يلبسهما*** يلقى الردى بمذمة وهوان
    ثوب من الجهل المركب فوقه*** ثوب التعصب بئست الثوبان
    وتحل بالانصاف أفخر حلة*** زينت بها الأعطاف والكتفان
    واجعل شعارك خشية الرحمن مع*** نصح الرسول فحبذا الأمران
    نونية ابن القيم
    السهيكي
    السهيكي غير متواجد حالياً
    الصورة الرمزية السهيكي
    [بارك الله فيك وجزاك عنا احسن الجزاء
    المهندس ابوعادل
    المهندس ابوعادل غير متواجد حالياً
    الصورة الرمزية المهندس ابوعادل
    الاخ الكريم هلوتس
    من مراجعتي لاحظت ان جميع الخشب بسماكة 2.5 سم
    اظن ان التطبيق سيكون صعبا ؟؟
    engabogabr
    engabogabr غير متواجد حالياً
    Received: 12
    جزاكم الله خيرا اخي الكريم
    محمد دهشورى
    محمد دهشورى غير متواجد حالياً
    عضو متميز جداً
    الصورة الرمزية محمد دهشورى
    Received: 47
    Given: 194
    مشكوووووووور جداجد وجزاك الله كل خير
    ان الله لا يغير ما بقوم حتى يغيروا ما بانفسهم
    mohamedisam
    mohamedisam غير متواجد حالياً
    الصورة الرمزية mohamedisam
    Given: 18
    رد: تصميم الشدة الخشبية ولله الحمد و المنى
    شكرا على المجهود الرائع
    mohamedisam
    Given: 18
    رد: تصميم الشدة الخشبية ولله الحمد و المنة
    مسألة في تصميم القوالب :
    صمم القوالب الخاصة بالواح السطح الخرساني سمك 150 مليمتر و عرضها بين العتبات 4.7 مليمتر , مستخدماً الالواح الخشبية للسطح سمك 25 مليمتر و عارضات خشبية سمك 50 مليمتر.
    افرض ان :
    الحمل الكلي للخرسانة = 3.6
    الحمل المتحرك=1.9
    total load = 5.5 kn/m^^2
