Important Request
النتائج 1 إلى 2 من 2
    الصورة الرمزية مصطفى مشرفه
    مصطفى مشرفه
    مصطفى مشرفه غير متواجد حالياً
    Given: 6
    Important Request
    Engine & Drivetrain Performance Math - Volume One
    Part 1 ( Chapters 1- 5 )
    ( Crucial Engine Parameters )
    Chapter - 1 Cylinder Block Deck Height
    Chapter - 2 Engine Displacement
    Chapter - 3 Bore -to- Stroke Ratio
    Chapter - 4 Rod -to- Stroke Ratio
    Chapter - 5 Rod Angularity
    code RP-134-1
    Part 2 ( Chapters 6 - 8 )
    ( Great Piston and Cylinder Volume Info )
    Chapter - 6 Piston Displacement
    Chapter - 7 Cylinder Volume -Versus- Crank Angle
    Chapter - 8 Average Piston Speed
    code RP-134-2
    Part 3 ( Chapters 9 - 12 )
    ( Featuring: "Dynamic Compression Ratio" !!! )
    Chapter - 9 Instantaneous Piston Speed
    Chapter - 10 Static Compression Ratio
    Chapter - 11 Dynamic Compression Ratio
    Chapter - 12 Air Mass Efficiency
    code RP-134-3
    Part 4 ( Chapters 13 - 16 )
    ( Pressure! Torque! Horsepower! & A Huge Camshafts
    Chapter That Calculates Valve Timing & Valve Events! )
    Chapter - 13 Brake Mean Effective Pressure(BMEP)
    Chapter - 14 Brake Torque
    Chapter - 15 Power / Horsepower / Brake / Horsepower
    Chapter - 16 CAMSHAFTS(Principles, Valve Timing, & Valve Events)
    code RP-134-4
    Part 5 ( Chapters 17 - 21 )
    ( Carburetor Air Flow Illustrated; Overall Gear Ratios;
    Drivetrain & Vehicle Speeds )
    Chapter - 17 Carburetor Air Flow
    Chapter - 18 Drivetrain -- Overall Gear Ratios
    Chapter - 19 Transmission Output Shaft Speed
    Chapter - 20 Rear End -- Axle Speed
    Chapter - 21 Maximum -- Vehicle Speed
    code RP-134-5
    ISBN
    0-9643024-5-4 (For Volume One )
    مصطفى مشرفه
    Given: 6
    ياجماعه ياريت حد يرفع لينا الكتب ديه وجزاكم الله كل خير
    اللهم هب لي نفسا مطمئنه تؤمن بلقائك وترضى بقضائك وتقنع بعطائك
    مصر ستظل ارض العروبه والاسلام رغم انف الحاقدين
