معلومة عن عمل pressurizaion fan لمصعد
صفحة 2 من 2 الأولىالأولى 1 2
النتائج 11 إلى 14 من 14
    moamar_1970
    moamar_1970 غير متواجد حالياً
    this eqn. is for the closed doors leaking to the lobby
    Flow in Cubic Meter per sec=.825 *A *(Delta P) power 0.5
    A leakage area from the clearance between the door and its frame = .0022 Sq.M for each Meter length from the permieter
    if there is some doors opened
    flow in cubic meter per sec= No of doors * area of each* 1m/s(Velocity)
    Add those two amounts so you can get the total flow required by your fan
    Hope that i answered you
    moamar_1970
    pressure diff should be in Pascals
    this discussion is extracted from
    www.engineeringtoolbox.com
    Thank you
    Allah is the Greatest, There is No Allah, But Him, The only one and Mohammad is his Messenger
    issam.alhiti
    issam.alhiti غير متواجد حالياً
    شكرا للجميع وللاخ الزناتي على المشاركة الجميلة
    عصام الهيتي
    بن القاسم
    بن القاسم غير متواجد حالياً
    Given: 3
    الله يجزيكم الخير
