ممكن مساعده الي يعرف لبرنامج المحاكاة arena
النتائج 1 إلى 2 من 2
    abod888
    abod888 غير متواجد حالياً
    السلام عليكم ورحمة الله لجميع الاعضاء
    عندي مسأله ببرنامج arena ومو عارف احل المسأله على البرنامج ياليت الي يعرف يساعدني
    المسأله
    . Develop a model of a simple serial two-process system. Items arrive at the system with a mean time between arrivals of 10 minutes, with the first arrival at time 0. They are immediately sent to Process 1, which has a single resource with a mean service time of 9 minutes. Upon completion, they are sent to Process 2, which is identical to (but independent of) Process 1. Items depart the system upon completion of Process 2. Performance measures of interest are the average numbers in queue at processes and the total time in system of items. Using replication length of 10,000 minutes and 5 replications compare the results for the following input distributions:
    (a) Exponential inter-arrival times and exponential service times
    (b) Constant inter-arrival times and exponential service times
    (c) Exponential inter-arrival times and constant service times
    (d) Constant inter-arrival times and constant service times
    Consider first 500 minutes as warm-up period. Animate your model. Show the result graphically.
    صناعي1
    صناعي1 غير متواجد حالياً
    الصورة الرمزية صناعي1
    Received: 19
    Given: 3
    أهلا بك اخي، المسألة غير معقدة. وبالتأكيد يمكنك حلها.
    اليك هذا الرابط و به توضيح جيد لاستخدام ارينا
    http://www.arab-eng.org/vb/t113602.html
    اتمنى ان تستفيد من الموضوع، وفقك الله
