كتاب Stability of Structures
النتائج 1 إلى 10 من 28
    سنا الإسلام
    سنا الإسلام غير متواجد حالياً
    Received: 257
    اليكم هذا الكتاب
    وهو منقول للأمانة من أحد المنتديات
    محتويات الكتاب
    1 Buckling of Elastic Columns by Equilibrium Analysis 3
    1.1 Theory of Bending 4
    1.2 Euler Load, Adjacent Equilibrium, and Bifurcation 5
    1.3 Differential Equations of Beam-Columns 9
    1.4 Critical Loads of Perfect Columns with Various End Restraints 12
    1.5 Imperfect Columns and the Southwell Plot 19
    1.6 Code Specifications for Beam-Columns 27
    1.7 Effect of Shear and Sandwich Beams 30
    1.8 Pressurized Pipes and Prestressed Columns 35
    1.9 Large Deflections 38
    1.10 Spatial Buckling of Beams under Torque and Axial Force 46
    2 Buckling of Elastic Frames by Equilibrium Analysis 53
    2.1 Stiffness and Flexibility Matrices of Beam-Columns 54
    2.2 Critical Loads of Frames and Continuous Beams 61
    2.3 Buckling as a Matrix Eigenvalue Problem and Use of Finite Elements 74
    2.4 Large Regular Frames 78
    2.5 Postcritical Reserve in Redundant Trusses 86
    2.6 Postcritical Behavior of Frames 89
    2.7 Built-Up Columns and Regular Frames as Columns with Shear 102
    2.8 High Arches 108
    2.9 Long-Wave Buckling of Regular Frames 118
    2.10 Continuum Approximation for Large Regular Frames 129
    3 Dynamic Analysis of Stability 144
    3.1 Vibration of Columns or Frames and Divergence 144
    3.2 Nonconservative Loads and Flutter 151
    3.3 Pulsating Loads and Parametric Resonance 162
    3.4 Other Types of Dynamic Loads 170
    3.5 Definition of Stability 174
    3.6 Theorems of Lagrange-Dirichlet and of Liapunov 178
    3.7 Stability Criteria for Dynamic Systems 184
    3.8 Stability of Continuous Elastic Systems 187
    3.9 Nonlinear Oscillations and Chaos 189
    4 Energy Methods 199
    4.1 Positive-Definite Matrices, Eigenvalues, and Eigenvectors 199
    4.2 Potential Energy for Discrete Elastic Systems 207
    4.3 Bifurcation Buckling at Small Deflections 216
    4.4 Snapthrough and Flat Arches 227
    4.5 Large-Deflection Postcritical Behavior and Types of Bifurcation 238
    4.6 Koiter's Theory, Imperfection Sensitivity, and Interaction of Modes 261
    4.7 Catastrophe Theory and Breakdown of Symmetry 270
    4.8 Snapdown at Displacement-Controlled Loading 278
    4.9 Incremental Work Criterion at Equilibrium Displacements 294
    5 Energy Analysis of Continuous Structures and Approximate Methods 305
    5.1 Indirect Variational Method and Euler Equation 306
    5.2 Beam on Elastic Foundation 314
    5.3 Rayleigh Quotient 323
    5.4 Timoshenko Quotient and Relations between Various Bounds 331
    5.5 Bound Approximation for Columns, Frames, and High Arches 339
    5.6 Rayleigh-Ritz Variational Method 348
    5.7 Galerkin Variational Method 356
    5.8 Method of Successive Approximations and Lower Bounds 358
    5.9 Nonlinear Problems; Large Deflections of Columns 361
    6 Thin-Walled Beams 370
    6.1 Potential Energy and Differential Equations 371
    6.2 Axial-Torsional Buckling of Columms 381
    6.3 Lateral Buckling of Beams and Arches 384
    6.4 Beams of Arbitrary Open Cross Section 392
    6.5 Large Deflections 401
    6.6 Box Girders 408
    7 Plates and Shells 419
    7.1 Classical Plate Theory 420
    7.2 Differential Equation and Strain Energy 422
    7.3 Buckling of Rectangular Plates 431
    7.4 Large Deflections and Postcritical Reserve of Plates 440
    7.5 Axisymmetric Buckling of Cylindrical Shells 449
    7.6 Shallow or Quasi-Shallow Shells 453
    7.7 Nonlinear Analysis of Shell Buckling and Imperfections 466
    7.8 Sandwich Plates and Shells 474
    II Inelastic, Damage, and Fracture Theories
    8 Elastoplastic Buckling 485
    8.1 Perfect Columns or Structures and Shanley's Bifurcation 486
    8.2 Imperfect Columns and Structures 506
    8.3 Effect of Residual Stresses 513
    8.4 Metal Columns and Structures: Design and Code Specifications 517
    8.5 Concrete Columns and Structures: Design and Code Specifications 532
    8.6 Perfectly Plastic Large-Deflection Buckling, Impact, and Blast 556
    8.7 Geometric Tensile Instability, Localization, and Necking 569
    9 Creep Buckling 584
    9.1 Viscoelastic Stress-Strain Relations 585
    9.2 Viscoelastic Buckling 590
    9.3 Viscoplastic Buckling 597
    9.4 Buckling of Aging Viscoelastic Structures 603
    9.5 Effect of Creep Deflection on Concrete Column Strength 615
    9.6 Nonlinear Creep and Long-Time Strength of Concrete Structures 619
    9.7 Creep Buckling at Finite Deflections 623
    10 Stability of Inelastic Structures, Bifurcation and Thermodynamic Basis 633
    10.1 Thermodynamic Criteria of Stable State 633
    10.2 Thermodynamic Criteria of Stable Path 650
    10.3 Application to Elastoplastic Columns and Broader Implications 658
    10.4 Critical States of Stability and Bifurcation 670
    10.5 Stability at Infinitesimal Loading Cycles 680
    10.6 Drucker's and Il'yushin's Postulates for Stable Materials 685
    10.7 Stability of Frictional Materials and Structures 693
    11 Three-Dimensional Continuum Instabilities and Effects of Finite Strain Tensor 706
    11.1 Finite Strain 707
    11.2 Stresses, Work, and Equilibrium at Finite Strain 715
    11.3 Incremental Equilibrium and Objective Stress Rates 720
    11.4 Tangential Moduli at Large Initial Stress 726
    11.5 Stable States and Paths for Multidimensional Continuous Bodies 732
    11.6 Column or Plate with Shear: Finite-Strain Effect 734
    11.7 Surface Buckling and Internal Buckling of Anisotropic Solids 741
    11.8 Consistent Geometric Stiffness Matrix of Finite Elements 748
    11.9 Buckling of Curved Fibers in Composites 750
    12 Fracture as a Stability Problem 760
    12.1 Linear Elastic Fracture Mechanics 760
    12.2 Nonlinear Fracture Mechanics and Size Effect 772
    12.3 Crack Stability Criterion and R-Curve 782
    12.4 Snapback Instability of a Crack and Ligament Tearing 788
    12.5 Stable States and Stable Paths of Interacting Cracks 798
    12.6 Crack Spacing 816
    13 Damage and Localization Instabilities 829
    13.1 Wave in Strain-Softening Materials 830
    13.2 Series-Coupling Model for Localization Due to Softening 845
    13.3 Localization of Softening Damage into Planar Bands 857
    13.4 Localization of Softening Damage into Ellipsoidal Regions 869
    13.5 Localization of Softening Damage into Spherical or Circular Regions 880
    13.6 Localization in Beams and Softening Hinges 887
    13.7 Friction: Static and Dynamic 902
    13.8 Bifurcations Due to Interaction of Softening Damage Zones 907
    13.9 Size Effect, Mesh Sensitivity, and Energy Criterion for Crack Bands 914
    13.10 Nonlocal Continuum and Its Stability 921
    13.11 Constitutive Equations for Strain Softening 937
    رابط التحميل
    رابط اخرللتحميل
    eng abdallah
    eng abdallah غير متواجد حالياً
    الصورة الرمزية eng abdallah
    Received: 12
    جزاكِ الله خيراً مهندسة أميرة
    و بالتوفيق و التميز دائماً
    سنا الإسلام
    Received: 257
    اقتباس المشاركة الأصلية كتبت بواسطة eng abdallah مشاهدة المشاركة
    جزاكم الله خيرا على مروركم الطيب وبارك الله فيك
    متغيبة عن الملتقى
    str
    str غير متواجد حالياً
    Given: 6
    الاخت المهندسة اميرة
    شكرا لك على الكتاب الجميل ولكن بعد ان تم التحميل اود ان اسالك عن البرنامج الذي يفتح الملف لاني لم استطع فتح الملف بعد التحميل
    [IMG][/IMG]
    anass81
    anass81 غير متواجد حالياً
    الصورة الرمزية anass81
    Received: 672
    Given: 722
    اقتباس المشاركة الأصلية كتبت بواسطة str مشاهدة المشاركة
    جرب هذا البرنامج
    http://www.free-ebooks.cc/apps/WinDj....0.1-Setup.exe
    str
    Given: 6
    شكرا لك مهندس انس ومبروك حصولك على الماستر وان شاء الله عقبال للدكتوراه
    شكرا لك مهندسة اميرة حيث اني عرفت من كيفية تحميل قارئ الملفات
    [IMG][/IMG]
    أبوجبل
    أبوجبل غير متواجد حالياً
    أميرةة بارك الله فيك
    وجعله الله في ميزان حسناتك
    Abo Fares
    Abo Fares غير متواجد حالياً
    Received: 344
    Given: 291
    قبل التحميل، ومن خلال قراءة المحتويات... كتاب مهم جداً أختي أميرة، بارك الله بك..
    بيستاهل التقييم، حتى لو قبل التحميل :)
    لك تحيـــــــاتي..
    سنا الإسلام
    Received: 257
    اقتباس المشاركة الأصلية كتبت بواسطة فلاي آش مشاهدة المشاركة
    جزاكم الله خيرا وبارك الله فيكم جميعا
    متغيبة عن الملتقى
    سنا الإسلام
    Received: 257
    اقتباس المشاركة الأصلية كتبت بواسطة anass81 مشاهدة المشاركة
    جرب هذا البرنامج
    http://www.free-ebooks.cc/apps/windj....0.1-setup.exe
    جزاكم الله خيرا وبارك الله الله فيك
    متغيبة عن الملتقى
